Old 02-04-2020, 04:07 PM #1
jimgsmith jimgsmith is offline
Real Name: Jim
jimgsmith is on a distinguished road
Real Name: Jim
2 observations
I'm 2 months in on the 2020 T4R Venture (Canadian Edition) and I've noticed a couple strange things I thought I would mention:
1. There is a red spot on the tires, right where the valve stem is. Are the tires balanced so that the wheels don't need to be?
2. I set the tire pressure in all four tires to exactly 33 PSI (yes, I know its supposed to be 32 but I thought the ride was a little soft) and then I reset the TPMS to use the current pressure as the default. When I start driving, it shows all 4 tires as 33 PSI (good) but then something strange happens, and it is always the same. The front driver side tire is first to go up 1 PSI, then the rear driver side, then the front passenger, then the rear passenger. There is 1-2 minutes between each jump, and this starts all over again (after a little delay) with the front driver side going up another PSI. I get that they will all fluctuate, but its odd that is always follows this pattern.
Bonus observation: The Canadian version of the Venture has TRD Off Road on the C pillar, but the US version doesn't. Seems like a strange thing to change.
jimgsmith is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 04:16 PM #2
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
According to Yokohama, a red mark on a tire indicates the point of maximum radial force variation (RFV) and should be aligned with the wheel assembly's point of minimum radial run-out. A yellow mark indicates the point of lightest weight and should be aligned with the valve stem on the wheel assembly.
It's a starting point for whoever mounts the tire but the whole assembly should be balanced and checked for RFV after they are mounted.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 04:33 PM #3
shdw03 shdw03 is offline
shdw03 will become famous soon enough shdw03 will become famous soon enough
tire pressure normally fluctuate when the tires warm up, fronts normally before the rears or if you put more load on one side more than the other, that side will rise first. normally go up between 2-4 psi
shdw03 is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 08:39 PM #4
TomsPro TomsPro is offline
TomsPro is on a distinguished road
Yeah, hitting the brakes a few times will also warm the wheels/tires up as the rotor sheds heat. Maybe one side is grabbing a bit more than the other.
2018 blue Pro 4Runner
TomsPro is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 08:52 PM #5
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Originally Posted by jimgsmith View Post
...I get that they will all fluctuate, but its odd that is always follows this pattern.
The pattern is probably from the system refresh rate. It may not be as “real-time” / refreshed every micro second since anything not a catastrophic leak can readily be captured with readings every few minutes.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 01:12 PM #6
-E5J-'s Avatar
-E5J- -E5J- is offline
Real Name: J
-E5J- has a spectacular aura about -E5J- has a spectacular aura about
-E5J-'s Avatar
Real Name: J
Doesn't the left front axle spin while the passenger side does not while part time 4WD is disengaged? Axle spin could be creating more heat in front left first...
Just a thought.
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
-E5J- is offline   Reply With QuoteReply With Quote
front , psi , side , strange , tires
285 observations Stangboy 5th gen T4Rs 7 03-09-2017 11:24 PM
CAI Observations 05 AFE CAI and 14 TRD CAI Hadelson 5th gen T4Rs 3 07-30-2016 11:16 AM
Observations and questions mavrick1903 4th Gen T4Rs 6 09-05-2014 04:30 PM
ECT Mod Observations Robb235 3rd gen T4Rs 6 03-21-2013 10:29 PM
Lift kit observations Falls Off-Roading 27 12-02-2006 08:34 AM
