Old 01-14-2020, 06:10 PM #1
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
How Does the 2020 SR5 4WD System Operate ?
Im considering a 2020 SR5 Premium with a sunroof. Ive looked at the drawings on the Toyota parts site and I want to understand what happens when you engage and disengage part time 4 wheel drive.
There are 2 motors, one on the transfer case and one the front differential.
When put into 2 wheel high the front drive shaft is disconnected from the transfer case by the first motor.
The second motor disconnects the right wheel drive shaft from the front differential. The left wheel remains connected and when the vehicle moves the front differential will rotate and the front drive shaft (to the transfer case) will also rotate.
Is this correct?
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 12:17 AM #2
keph13 keph13 is offline
keph13 is on a distinguished road
Yes. I believe only part of the differential ends up spinning (the outside gear, maybe?). That's why Toyota recommends shifting into 4 once a month - to exercise the rest of the gears and get them coated in diff fluid.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 12:22 AM #3
Whippersnapper02's Avatar
Driver side axle is directly connected to the wheel so the spider gears are always turning and the passenger side shaft section before the ADD turns the opposite direction but the ring & pinion and front prop shaft don't move.
Engaging 4wd moves the collar from the diff side of the passenger shaft over the rest of the shaft.
Old 01-15-2020, 07:26 AM #4
Ok. Thank you very much.
Old 01-15-2020, 08:30 AM #5
yota1976's Avatar
yota1976 yota1976 is offline
yota1976 is on a distinguished road
yota1976's Avatar
I just recently found that out, about using 4WD once a month. I've had my 2019 TRD OR for 2 months now and didn't know that.
2019 TRD Off Road, Barcelona Red, Predator Steps, Sprint Booster V3
yota1976 is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 02:03 PM #6
Ucan2 Ucan2 is offline
Ucan2 is on a distinguished road
Your conversation is very insightful. I'm considering buying a 5th Gen with part time 4WD to flat tow behind a Motor Home.
Toyota doesn't recommend doing so. Is that more likely because the front drive system is still turning even though your disconnected at the Transfer case?
Were to put front tires on a dolly, would that alleviate front end concerns.
The rear-end to transfer case would then be all that's turning. As long as there is no differential lock on rear-end, I can't see there being a problem.
Anyone care to comment?
Ucan2 is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 02:25 PM #7
Space King's Avatar
Space King Space King is offline
Space King is a jewel in the rough Space King is a jewel in the rough Space King is a jewel in the rough
Space King's Avatar
Originally Posted by Ucan2 View Post
I'm considering buying a 5th Gen to flat tow behind a Motor Home. Your conversation is very insightful.
Toyota doesn't recommend doing so. Is that most likely because of the front drive system is still turning even though your disconnected at the Transfer case but still turning in the front end do to contact with road?
If I were to put front tires on a dolly that would aliveate front end concerns.
Rear end to transfer case would then be all that turning. As long as there is no differential lock on rear end I can't see there being a problem.
The reason Toyota doesn't recommend flat towing is because the pump in the transmission is driven off of the input shaft. So if the engine isn't running, neither is the pump. If the pump isn't running, the transmission isn't being lubricated properly. Without lubrication... things tend to go south.
Most automakers don't recommend flat towing anything with an automatic transmission. I think Jeep says it's safe if the transfer case is put in neutral... not 100% positive. Anyway, Fiat Chrysler not being known as the kings of vehicle longevity, take that advice with a grain of salt.
"Sometimes I sit and think. Sometimes I just sit."
Space King is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 03:05 PM #8
Trans Case & Towing
I was considering a model that had a manual (with shifter) Transfer case, so as to shift it into neutral. I would also leave the auto Trans in Park.
Its a great vehicle for everything I want to do, so I'm exploring this option as deep as I can.
Thanks for your comments.
Old 01-31-2020, 03:29 PM #9
Space King's Avatar
Space King's Avatar
Oh man, this thread might get good...
Old 01-31-2020, 03:42 PM #10
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
The manual is helpful regarding the exercising of the system - frequency and steps for enabling, but not with the level of detail about the how it works.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 03:44 PM #11
gdvan01's Avatar
gdvan01 gdvan01 is offline
Real Name: George
gdvan01 will become famous soon enough
gdvan01's Avatar
Real Name: George
'17 EssAre5Pee - Barcelona Red
Bilstein 5100's (fr-0) ~ Dobinson C59-302 front (2.5"), C59-505 rear (1.5") ~ JBA UCA's
Cooper Discoverer A/T3's - LT265/70R17 ~ Auxbeam 32", Rago brackets
XD HID's (low) LED's (high), LED swap in and out ~ Rear diff routed along fuel filler pipe ~ LFD 3/4 steel roof rack
RVA Toyota Trucks
gdvan01 is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 04:55 PM #12
ironguy ironguy is offline
ironguy is on a distinguished road
I'm not sure that is a great idea??
ironguy is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 05:14 PM #13
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
I think whether its a KNOB or Gear shifter, the transfer case still engages 4WD with an electronic actuator.
Daikon is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 06:27 PM #14
Space King's Avatar
Space King's Avatar
Oh here we go...
Old 02-04-2020, 06:22 PM #15
Question Trans Case & Towing
Since my question about towing with a T-case, I spoke to a service manager and read a couple articles reviewing the Part time 4WD drive on the 5th Gen TRD Off-Road. What is clear is the T-Case with manual lever shifted into neutral disengages the front wheel drive completely. Also it disengages T-case from the output shaft. Thereby isolating the drive axle aft to the Rear Differential and rear wheels. With out the rear diff being locked you have the needed sleep between rear tires while cornering etc.
Its my understanding that 5th Gen Toyota transmissions require a pump to circulate oil while running oiling moving parts. Without power no oiling, which is no dough why Toyo doesn't recommend flat towing. The transfer case would appear to depend on oil slinging for lubrication. Which would occur if rear wheels on the ground are turning the drive train up to the Transfer Case.
So in my infinite lack of wisdom, if front wheels of 4Runner are on a Dolly, Transmission is in Park with engine off, and Transfer case is in Neutral. You are basically free wheeling the rear drive train and oil T-case....just don't break something or I'm sure Toyota will not honer your warranty.
Any one care to tell me where my logic is faulty?
drive , front , shaft , transfer , wheel
Aftermarket JL Audio system install on a 2020 DryHeatAZ 5th gen T4Rs 22 01-05-2024 01:39 AM
2020 Pro - Road noise, sound system, and carplay/conference call performance point1 5th gen T4Rs 12 10-16-2023 03:19 AM
2020 4Runner: Anyone have any issues with the multimedia system? mrt6644 5th gen T4Rs 16 12-31-2020 10:13 AM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
Operate fine without Climate Control? RiverRat37 3rd gen T4Rs 0 10-19-2011 12:07 PM
