Old 01-14-2020, 07:21 PM #1
Jtw13 Jtw13 is offline
Jtw13 is on a distinguished road
Leak on 2012 @ 124K
Hey, new here. I got the 4Runner last April and I didn't have this leak until recently, or at least it seems. I was hoping someone could help me and I know you can't diagnose over some picture but I've seen some really good info on here. Power steering? Timing cover? No noticeable symptoms while driving but recently it has started making an odd noise while coasting. If I had to explain it I'm not sure where to start, maybe a slight groan? It sounds like a fountain drink machine at a 711. I'm not using any oil at all and it doesn't appear that the power steering fluid is low either. It's on the left side and also in the front under the valve cover.
here is a link to a video I took of it
https://www.youtube.com/watch?v=hOiX...ature=youtu.be
Leak on 2012 @ 124K-3-jpg  Leak on 2012 @ 124K-2-jpg  Leak on 2012 @ 124K-5-jpg  Leak on 2012 @ 124K-6-jpg
Jtw13 is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 08:50 PM #2
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Can't really see where its at,you moved around a lot.
check to see if its coming out of the AC hoses, or AC compressor.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 09:06 PM #3
Yeah, it's definitely not the best video. It's right around where the dip stick tube runs on the left side. There's oil in the front too, under the valve cover.
Old 01-14-2020, 09:20 PM #4
TrkyMfns's Avatar
TrkyMfns TrkyMfns is offline
TrkyMfns is on a distinguished road
TrkyMfns's Avatar
Hard to tell due to the orientation etc, but it might be coming from your valve cover gasket and dripping down. I would start there.
Have an Avalon that I just replaced the camshaft seals, timing belt etc. It had oil all over the bottom of the engine and power steering hoses caked in oil and dirt. Turned out to be coming from higher up on the engine.
2011 SR5/P 4WD Blizzard Pearl - 285/70/17 Falken Wildpeak AT3/W - Bilstein 5100 Lift @ 2.5 - SPC UCA's - Two-Tone Katzkin Interior - 15% Lumar Pinnacle Ceramic Tint - Canvasback Liner - Husky Weatherbeater Liners - Phillips Interior LED's - Completely upgraded ICE.
TrkyMfns is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 09:51 PM #5
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
To OP: as everyone else replied, it is hard to say based on video and pictures you have… also you said that it is “on the left side around where the dipstick tube runs”… but the dipstick is on the right side of the engine… so is it on the right side?... if yes, than it could be valve cover (if you lucky) if not valve cover then it could be timing cover…
First thing I would do is to clean all old oil and see where it is coming from.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 10:12 PM #6
I'll do that and yes it's on the passenger side. I was speaking like I was standing in front of it. Sorry, it's got me flustered.
Old 01-14-2020, 11:26 PM #7
progress4m's Avatar
progress4m's Avatar
I understand, no worries. Try to clean it as best as you can so you can see fresh signs of the leak. Hopefully it is valve cover, if not, then there is a chance it is timing cover… repair is expensive and a lot of work. Those 4.0L engines have one weak spot: timing cover leak on the right (passenger) side, it is rare, but it can happened… sorry for possible bad news.
Old 01-15-2020, 05:58 PM #8
Yeah, I did a little reading up on the timing cover. It is rare like you said so that does give me hope. It might be the valve cover but it doesn't seem like it at all. I sprayed the heck out of it with break clean today so I'll keep checking. I did a little more looking, there's actually a decent amount of oil residue on the front side.
Old 01-15-2020, 11:38 PM #9
progress4m's Avatar
progress4m's Avatar
I do not have first-hand knowledge of timing cover leaks on 4.0 V6, but from what I know that leak starts at the place where block, head and timing cover meet (on the right side of engine), so I would try clean that area very well, make it “dry” with brake cleaner and then watch it, keep us posted and good luck!!!
Old 01-16-2020, 12:07 AM #10
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
It's a leak if it's dripping, what you have is "seepage". Keep an eye on your PS and oil level but I wouldnt worry too much. Could be valve cover, PS pump, timing chain inspection gasket, timing chain cover, or I think thete is an oil pressure sensor around there that can leak too.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 09:32 PM #11
For sure, thanks. I sprayed an entire can of brake clean on it and now I will continue to check it. I'm starting to think it's my ps pump.
Old 01-17-2020, 02:01 AM #12
w210210 w210210 is offline
w210210 is on a distinguished road
Way too early for a Toyota to have a leak ...
w210210 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 09:33 AM #13
BigE BigE is offline
BigE is an unknown quantity at this point
My money is on the oil sensor. 50 bucks for the part. DIY instead of dealer charge of 300. Happened 2011 Limited w 160k
2020 Trd Off Road - Magnetic Gray beginning stages of mods
2019 Trd Off Road - Magnetic Gray GONE
2011 Limited - Magentic Gray GONE @ 165k
2001 Sr5 Premium - Thunder Cloud Gray GONE @ 295k but should of kept
BigE is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 09:53 PM #14
That's what I said...
I will check that out for sure. That's on the list. It's snowing like crazy here so it'll have to wait.
cover , leak , power , recently , steering
FS: 2001 SR5 4x4 Silver 124k - NJ thaemcee2 For Sale: Vehicles 5 04-22-2017 10:02 AM
thoughts on this purchase? 01 with 124k rundrave 3rd gen T4Rs 7 03-07-2011 05:42 PM
2002 T4R Sport 3.4L V6 engine failure 124k jjones1033 Problems & Warranty Issues 2 12-04-2008 01:21 AM
