Originally Posted by DAF54
So if I am understanding the replies, I have open diffs in 2WD and 4HI? And in 4LO too unless I engage ATRAC or manually lock the rear diff?
atrac is still an open diffs, it applies brakes for traction control
you can lock your rear diff in 4lo, all other times you have open diffs
you can modify the vehicle to use the rear locker in 4hi, but if you're wheeling you should be in 4lo anyways
