Old 02-25-2020, 10:47 PM #46
Catong Catong is offline
Catong is on a distinguished road
I can tell you the 2020 sr5s don't. But I did talk to my local viper alarm dealer he said all smartkeys can be programmed with a module coming out around April. So if you didn't want any of the fancy stuff you can still use your stock key and get remote start / turn off lock etc. The viper I have on my 15 Tacoma from viper is way fancier and I rarely use the extra shit.
Catong is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 11:29 PM #47
John300k John300k is offline
John300k is on a distinguished road
Originally Posted by jp.vegas View Post
Yeah, no. My 2020 has it standard, not optional.
I work at a Toyota dealer, very few come with remote start from the factory. The only thing new is other models now come with push button start, not to be confused with remote start.
John300k is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 11:42 PM #48
Agtoad Agtoad is offline
Agtoad is on a distinguished road
Remote start is useful when truck camping and you want a bit of heat, saves jumping into the drivers seat.
Agtoad is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 04:44 AM #49
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Every Pro, every Limited. I’m not confused.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 10:07 PM #50
joshers22 joshers22 is offline
joshers22 is on a distinguished road
Originally Posted by Jmoretti13 View Post
Hey bud,
New to the forum... but can you give me some hint or maybe a video that you used to find the DCM wire you spliced? Trying to install my kit right now on my 2020 TRD ORP.
Thanks in advance.
Pm you
joshers22 is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 02:07 PM #51
Chrisb009 Chrisb009 is offline
Chrisb009 is on a distinguished road
Anyway to prevent the vehicle from shutting off when opening the door - short of not opening the door?
-Chris
2020 4Runner Limited, 2018 RAV4 SE, 2008 F450 KR, 2003 Silverado 2500HD D/A
2018 Kawakasi KLR650, 2009 Kawasaki 650R, 2007 Yamaha FJR1300
2013 40' FR 5th Wheel Toy Hauler, 2021 20 ft HD Car Hauler
1985 CJ7 Awaiting Restoration
Mahindra 2645 Cab pst
Chrisb009 is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 02:13 PM #52
-Chris
That's been a "feature" of the Toyota OEM remote start system forever. I've never seen an option to do that besides installing an aftermarket system.
Gone
Old 02-29-2020, 03:16 PM #53
steelevo steelevo is offline
steelevo is on a distinguished road
The manufacturer does this for a reason, to prevent theft, more on this below.
Aftermarket systems will allow the car to run, unless you open the hood or push on the brake pedal. The hood will generally use an oem switch wire or aftermarket hood switch and a wire tapped into the brake wire. You will generally unlock the doors, get in the car, put your key in the ignition, turn it to the run position, push on the brake to deactivate the remote start, and just start driving. The reason the car does not shut off, after pushing on the brake, is because the key is now in the run position.
Now, let's look at the aftermarket system from a theft perspective. You start your car, thief breaks the window and jumps in, forcefully turns the ignition to the run position, pushes on the brake, and drives off. The car will continue to run until shut off. The transponder in the key is only needed to start the car, not to keep it running. Some installers will use an existing programmed transponder and will secure it under the dash somewhere.
With the OEM system, you start the car, unlock the door, the car shuts off, you get in restart the car, and then start driving.
OEM system from a theft prospective. You start the car, thief breaks the window, climbs in without opening the door, forcefully turns the ignition to the run position, pushes on the brake, and the car shuts off. The OEM system will not allow the car to go anywhere without a restart. The brake pedal is another safety feature that will shut the car off if pressed. Sure the thief can disconnect the brake pedal wiring, but now the shift lever won't function without the brake signal. Even if they somehow get passed all of that, the car automatically shuts off after 10 minutes and will require a restart.
I installed aftermarket remote starts for many years, as a career. They can be bypassed and allow your car to be started by thieves easily. It has been a few years, so I'm pretty sure that some of the new aftermarket systems are better at slowing thieves down, but it will still make your vehicle more vulnerable. Just my 2 cents on the subject.
steelevo is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 06:36 PM #54
Yeah I get why they do it.
These days, it's just as likely that someone clones your keyless entry key signal and takes off with the car. No muss, no fuss.
Gone
Old 02-29-2020, 08:44 PM #55
trey99ek trey99ek is offline
trey99ek will become famous soon enough
I just picked up my 2020 ORP, no factory start. I am gathering the necessary items to put a compustar unit on it. I just need a relay and a hood pin. I took it off my 4th gen so I need new ones. They make a basically plug and play harness. I'll keep you guys posted if anyone wants to go that route.
I prefer the aftermarket units for the range. I have the 1 mile antenna and it's nice being able to start it from my office at work, 5 minute walk to the car and it's warm.
2008 Sport Edition - GONE
2020 TRD ORP
trey99ek is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 09:49 PM #56
That’s one good thing about the factory remote start. The app will let you start it from anywhere.
Gone
Old 03-02-2020, 10:16 PM #57
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Makes sense but I prefer to leave it running. Someone wants it that bad they can have it. Does Lexus do this also? I know Ford and Jeep oem stays running
ForRun is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 03:39 PM #58
GW17 GW17 is offline
GW17 is an unknown quantity at this point
Now that is a good explanation, Thank you.
GW17 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:31 PM #59
adrtoy adrtoy is offline
adrtoy is on a distinguished road
Has anyone installed, or had installed a remote start from 12 volt solutions? The dealer finally did mine and it only works from around 10 yards making it pretty much worthless.
adrtoy is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 05:05 PM #60
frasc frasc is offline
frasc is on a distinguished road
Does it have it's own remote or does it use the factory fob?
frasc is offline   Reply With QuoteReply With Quote
building , online , option , remote , wondering
2020 Plug and Play remote Starter IS DONE!! gshadow325 5th gen T4Rs 0 01-04-2020 12:38 AM
2020 Plug and Play remote Starter almost here gshadow325 5th gen T4Rs 2 12-30-2019 08:43 AM
RFID Keyless Entry, Push Button Start and Remote Start BFLAN 5th gen T4Rs 41 04-17-2012 09:36 PM
Remote Start or Security + Remote Start dheeter 4th Gen T4Rs 3 12-29-2008 05:49 PM
2006 4Runner SR5 remote start w/factory remote?? brantatchison Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-04-2006 12:18 PM
