02-04-2016, 01:27 AM
Ideas to prevent rodents from eating our wiring
I found this on an agricultural site. Repelling Wire-Eatin... | Maintenance & repair | Agriculture I have used the fabric softener sheets with some success when I visit my some in the country in the Arizona desert. I have never heard of the rodent repellants talked about in the article.
02-04-2016, 01:33 AM
I have tried peppermint oil. Sprayed it in the corners of the engine compartment.
02-04-2016, 11:07 AM
I've pulled countless mice n rats out of my Prius....I find that leaving the hood open at night keeps em out of the engine compartment, of course weather conditions will dictate if that's possible. Rodents need overhead cover from predators. When its the season (spring/summer), I'll leave baited traps by the inside of the tires at night. I catch something just about every night.
02-04-2016, 12:36 PM
Real Name: Dave
Real Name: Dave
Rodents in your engine compartment
The article has a few good tips. It's mostly about farm equipment that's more open. There have been a number of posts here about rodents getting into the ventilation system. In the California Sierra Mountains there are marmots, about cat-sized animals, that damage radiator hoses. It disables the vehicle to the point where you can't drive out for repairs. They keep chicken wire handy and wrap the underside of the engine compartment.
Rodent control in outside areas is mostly natural. Remove ivy and other ground cover around structures. Keep animal feed, dog food or bird food in closed buckets or barrels. Pick fruit from trees as soon as it's ripe and pick up all ground fruit. Remove any water sources (easier in dry So Cal than if you live in a wetter climate with a creek in your yard). You get the idea.... keep the rodents from living around your property.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
02-04-2016, 01:10 PM
Your grandmother used it...
We have an MR2 Spyder that we store during the winters in a garage at our house on the lake. We won't see it or touch it for 3 or 4 months. The garage is a warm place for mice to find shelter in the winter. The first year, they got into the "Frunk" and reproduced. There were droppings and it smelled like urine. They chewed up a $300 backpack that I left in there. Thankfully, that's all they did.
Now when we store the car every year, I use mail envelopes to contain 5 to 6 MOTHBALLS. I get mothballs from Wal-mart(easy). I put an envelope at the bottom of every wheel(4). I put one envelope in the "Frunk". I put two envelopes in the engine compartment where every you may think would be an area where they would shelter. So that's seven. A box from WalMart will last you a lifetime. NOTE: Never keep mothballs inside the car. It will smell for months after. There's nothing to take out the smell, not even steam.
Anyway, because they are in a sealed envelope, the only thing that escapes is the camphor vapor(smell) and everything is kept clean. THE CAMPHOR IS WHAT KEEPS THEM AWAY. We had not found any indication of mice in or around the car since we started using mothballs. We just throw away the envelopes in the spring when we pick up the car.
If you use the car daily and you get mice, you might want to put up traps.
02-04-2016, 09:17 PM
There you go:
02-04-2016, 10:01 PM
I had the same issue with rats that ate some wiring in the engine compartment. The damage was minor and I put out some traps and caught two rats. Next time I'm thinking about getting one of these Rid-A-Rat strobe lights. I hear they work pretty good.
http://www.amazon.com/Packrat-Rodent.../dp/B00D2AQYI2
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
02-05-2016, 09:15 PM
Real Name: JR
Real Name: JR
or live in an area where temps are below 32F for 4-6 months solves your problems
80 PhoenixLJ/84 CelicaGT/84 & 87 Cressida/89 Toy Truck 2wd/91 Cressida x 2/93 Paseo/96 Protege/98 4Rv6/04 4R Sport v8/06 Taco AC v6/07 Sonata SE v6/09 Rav4 v6/10 Legacy 3.6R/12 Taco DC v6/09 Avenger SXT/09 Corolla XLE/14 4R LE/14 Rav4 XLE/15 Camry XSE/16 Taco DC v6 Sport/16 Highlander XLE/18 Tundra Plat/18 Santa Fe Ult
2014 4R LE Classic Silver Build Thread
E5-Exhaust Tip / MF-Mudflaps / R6-Running Boards / 2Q-All Weather Mats / 3P-Paint Protection Film
02-06-2016, 10:13 AM
Mothballs. I had the wiring harness eaten by squirrels... Twice! This happened in a previous vehicle. I put a small cloth sack with a few mothballs in the engine compartment. Never had any other problems. The only time I smelled it was when I opened the hood when the engine was hot. That only lasted a few months.
02-06-2016, 01:05 PM
X2 ... I've used Mothballs and it seems to work. We also have a cat!
02-06-2016, 10:36 PM
Red fox urine works great I work for a Toyota dealership in pecan country and it solved our squirrel issue. Just wear a rubber glove put a little on a q-tip and apply on wires.
05-27-2016, 06:13 PM
I just installed the rid-a-rat flasher in the engine compartment, after my 4R wires were chewed. My first rid-a-rat flasher was successful in keeping packrats from nesting in a shed, but someone I know used the rid-a-rat flasher for several years before it failed her. One advantage is that the flasher doesn't wear out like odorants. When I'm in packrat territory, I add in Critter Ridder, a pepper-based odorant that comes as liquid spray and solid granules.
My other vehicle has 6 aluminum wheels, is powered by a nuclear generator, and uses a laser to vaporize rocks on Mars.
05-27-2016, 06:27 PM
Living out in the country in South Central Kansas, we get all sorts of critters. I have a tractor, riding mower and old truck I keep in a large building / workshop; along with our 4Runner and Tundra that we keep in the garage. There is a product sold in the Co-ops here called Bar Bait. It looks like a big bar of soap and can be broken up if desired. Mice, rats, etc nibble on this and then go to seek water. It's a poison and will kill whatever eats it; so if you have pets then it needs to be out of their reach. Never had a problem with wires being eaten though.
05-27-2016, 08:53 PM
Real Name: Steve
Real Name: Steve
I've used drier sheets with success in my MGA in the garage. Several folks in our British car club swear that cutting up bars of Irish Spring soap into 4-5 pieces and spreading them through the car does the trick.
Steve - Northern Ohio, USA
2021 Toyota LC200 - 2017 Hiker Squareback Trailer - 1958 MGA Roadster
Wandering around on occasion, always lost
05-27-2016, 10:07 PM
ok, derail, but tell us about your 'other vehicle' please!
edit: i will say that we've used dryer sheets before, and it seemed to work...i'm pretty vigilant about keeping no clutter in the garage now, which definitely helps
2014 TE
BFG KO2 285/70 17, Icon Stage 2, Shrockworks front bumper, sliders, engine skid, 9.5 winch, FN counter steer type X
