03-04-2021, 05:36 PM
#76
Originally Posted by krhayes79
I have the C59-300 springs in the front and I have the OME MD springs in the rear (Dobinsons was out of stock so Mike offered these instead).
The ride felt like it was a boat. Stock feeling was definitely still there. Still had all the body roll when going over speed bumps and other dips in the road.
Was this with the rebound increased? I'm in the air with either the 296 or 300 springs. It's hard grasping 4" of stroke coming from 10.5" on the TJ. I hit 4" on a road dip lol... MRA atleast gives some comfort that I can firm it up. First and foremost I need too see how much travel I'm using now. I wonder how much ones be riding the bumps on washboard roads.
21 Silver Venture
18 Cement Tundra
04 TJ Rubicon
03-05-2021, 06:27 AM
#77
Do these come with a class to learn to use all the settings? haha
I've heard great things, and if I get an off road, I'll be giving you a call!
03-05-2021, 03:03 PM
#78
Real Name: Kelly
Real Name: Kelly
Originally Posted by jhguth
how's the reliability, anyone have a good amount of miles on these yet?
I only have 1k miles on mine, but so far so good. Only issues i had were my own fault from installing.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
03-05-2021, 03:09 PM
#79
Real Name: Kelly
Real Name: Kelly
I do not think this feeling had to do specifically with the rebound settings. I have not touched those but increase the LS and HS and the ride has significantly changed. TBH, I am not even sure if I personally would be able to feel a difference if I changed the rebound settings. That is something I am going to have to play around with when I have some time.
03-05-2021, 05:22 PM
#80
Too little rebound will cause it to bounce like no dampening. Too much rebound will cause a harsh ride as the shock will fight more to extend back.
21 Silver Venture
18 Cement Tundra
04 TJ Rubicon
03-05-2021, 05:32 PM
#81
I added the manuals that come with all MRA struts and shocks to my website last week. Here are the links where it explains how to set and adjust everything on them:
Dobinsons MRA Fitting Guide and Adjustment Explanation
https://exitoffroad.com/wp-content/u...ting-Guide.pdf
Dobinsons MRA Owners Manual and Tuning/Troubleshooting
https://exitoffroad.com/wp-content/u...r-Manual-2.pdf
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
03-14-2021, 09:47 PM
#82
Real Name: Carlo
Real Name: Carlo
After the install I was playing just with LSC and HSC leaving the Rebound at default. Softening the rebound had a big impact on the ride comfort for me.
03-15-2021, 09:46 AM
#83
Yeah, I found the same on mine too. Lower LSC and lower rebound definitely softens it up, better for crappy roads I've found
03-15-2021, 11:02 AM
#84
Real Name: Carlo
Real Name: Carlo
Agree. Something I need to try more is adjust HSC and LSC independently because so far I have always turned both at the same time to get a more soft/hard ride.
04-29-2021, 08:08 PM
#85
Real Name: Michael
Real Name: Michael
The upper & Lower rear trailing arms came a few weeks ago. Installed and set pinion angle, and got an alignment. Any up date on settings for these? I started with the Prado 150 settings.
Front LSC - 10, HSC - 7, REB - 18
Rear LSC - 5, HSC - 5, REB - 9
Just turned the rebound (front and back) down 2 clicks tonight and see how it goes.
04-30-2021, 10:53 AM
#86
I run the Prado 150 settings straight up. I've adjusted them up and down before, but find this to be the best setup for my vehicle, weight, and how I like it to feel.
05-05-2021, 09:45 AM
#87
Real Name: Michael
Real Name: Michael
Originally Posted by utctscanr75
Got mine one on yesterday. Feels really soft, but I haven't made any adjustments yet. Looking forward to reading what settings other are using as well. Highway settings and trail settings in particular.
How did you like the MRAs out in Moab? Did you play a round with the settings, any recommendations you would like to pass on?
05-05-2021, 09:58 AM
#88
Real Name: Bird Dog Overland
I basically turned the HSC and LSC settings all the way down while wheeling. They did great when rock crawling/off roading. Rode like a Cadillac, lol. I don't leave them like this for normal hwy driving though.
For normal Hwy situations, I've been using LSC of 13 and HSC of 7 with rebound about 1/2 way.
05-06-2021, 06:21 PM
#89
Real Name: Michael
Real Name: Michael
Thanks for the info. That was what I was thinking for the off-roading. I have been playing with the "normal" driving settings and I think I'm getting close. The rear end is harsh. I don't think I have enough junk in the trunk for the 701s. So I think I need to go down a spring size to the 677v.
05-07-2021, 09:35 AM
#90
Be mindful if you have the long travel setup, you'll need the long travel spring. In theory, the non long travel spring could fall out I was told. I have the 701s and they are great loaded or unloaded IMO.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
