Old 01-16-2020, 03:28 PM #16
2112 R's Avatar
2112 R 2112 R is offline
2112 R will become famous soon enough 2112 R will become famous soon enough
2112 R's Avatar
+1 for interest in this. Installing a 3" rear lift in a few weeks
2112 R is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 03:36 PM #17
dom42 dom42 is offline
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
The height won’t really matter. It’s your shocks that will be the limiting factor. So if they are 25 3/4” - 26” fully extended measured from center of lower eyelet or bolt up to the top of the lower bushing at the pin top mount on the frame. If you can get that spec before hand then you should be good. I’m pretty sure no one really makes anything longer then that anyway for the kdss because no one has been able to pull more then that prior to this part.
Sonoran steel zig zag bar is maxed out at 25 1/2”. And any more with that setup the kdss will invert itself. Mine still has more to go.
dom42 is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 03:43 PM #18
Phade Phade is offline
Phade is on a distinguished road
Wow, this is well done. Nice work on this.
Phade is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 03:59 PM #19
notoriouslyKEN notoriouslyKEN is offline
notoriouslyKEN will become famous soon enough
Very interesting. Tagging for later as this looks good.
notoriouslyKEN is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 06:57 PM #20
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Sub'd
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 09:47 PM #21
pwflaherty87's Avatar
pwflaherty87 pwflaherty87 is offline
pwflaherty87 is on a distinguished road
Can't wait to hear some reviews from multiple rigs. I'll definitely be ordering this with my lift
Sent from my SM-G973U1 using Tapatalk
2020 Superwhite TRD ORP
- Dobinsons 302/700 725/701 // JBA UCAs
- 285/70r17 Nitto Ridge Grappler SL // Spidertrax // Trail wheels
- LFD Ruggedized Crossbars // Weathertech // Canvasback
pwflaherty87 is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 10:09 PM #22
nice work man.
Old 01-16-2020, 10:30 PM #23
enginerd4ni's Avatar
enginerd4ni enginerd4ni is offline
enginerd4ni is on a distinguished road
KDSS Lean?
I went down this path in 2016 after installing Icon Stage 6 and getting some major KDSS lean. I tried all the KDSS tricks like bleeding, calibrating, etc. Nothing helped, still leans. The next step was making extension blocks like these. I couldn't figure out the optimum block height so I settled on 50% of the lift height, 3" * 0.5=1.5" Then I lost access to my CNC and moved it to the back burner. I'm curious about your block height and underlying calculations. Do you think this would fix the KDSS lean? My research and understanding of the mechanism suggest it should help but I never completed my blocks to test it out. By the way, my Icon track bar still rubs. I'm so glad you made this work and are going to sell some. I'll buy a set!
2013 TE: Build Thread Adventure Thread CBI Front and Rear Bumpers, Bud Built→(Beefy Sliders, Aluminum Skids, Diff Skid), Custom Grille w/ Rigid D2 Driving, Warn Xeon 10, Icon Stage 6, Gobi Stealth, Safari, ARB Front Locker, and lots of fun custom stuff from Ascend Overland
2005 LJR: Clayton 5.5, LS swap, NV4500, Atlas 4-speed, Revolution Gears, Chromoly and RCV shafts, Reid Racing Knuckles for Dana 44, ARB lockers F/R, GenRight tube frame, Ascend Overland 48" Drawers
enginerd4ni is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 10:35 PM #24
oldschoolpl510 oldschoolpl510 is offline
oldschoolpl510 is on a distinguished road
I'm in for one for the GX
oldschoolpl510 is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 11:41 PM #25
Maximize your KDSS + extended travel shocks
The blocks don’t do anything for kdss lean. It simply lowers it 1.25” down.
Edit: dang I just woke up and figured something out about how I can fix the kdss lean. I’ll need to mind f’it a little more and make something.
Old 01-17-2020, 12:01 AM #26
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
No No No you get out of here with your GX
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 12:08 AM #27
Ratpack's Avatar
Ratpack Ratpack is offline
Ratpack will become famous soon enough
Ratpack's Avatar
This is awesome, I have a sonoran steel bar already, do you think it would interfere if I added these as well? If not im in for a pair.
Ratpack is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 12:08 AM #28
Will we need extended brake lines??
Old 01-17-2020, 02:00 AM #29
Moreno Moreno is offline
Moreno will become famous soon enough Moreno will become famous soon enough
Originally Posted by dom42 View Post
Of course ppl are going to say oh I could have or would have came up with that Maximize your KDSS + extended travel shocksMaximize your KDSS + extended travel shocks. Maximize your KDSS + extended travel shocks
Maximize your KDSS + extended travel shocksMaximize your KDSS + extended travel shocksMaximize your KDSS + extended travel shocksMaximize your KDSS + extended travel shocks
That’s full droop with extended travel king shocks that measure 25 3/4” from center of lower eye to frame at the top where the pin top lower bushing rest. That’s 1/4” more then what’s available. And if one wanted to, you can run even longer as there still room for the system to swing and doesn’t come close to inverting the kdss system which will basically pull the plunger out the kdss shock.
Ok this my version of how to maximize the kdss equipped 4runners that have a lift and extended travel shocks. I know there’s that Sonoran steel zigzag track bar. But it just wasn’t for me. Plus the tolerances are tight. If you don’t run stock length links or if your axle isn’t in same location as stock, things will crash into each other. I personally didn’t like that , and the look of it. It could also have better joints as well. Totally not taking anything away from it as it’s an awesome idea. It just wasn’t for me.
Originally I was going to do my own version of a bent track bar ( and did ) but when I was test fitting it, a light bulb went off in my head. I got together with a long time friend Don Thuren ( thuren fabrication ) and came up with this. It works like a charm.
Here’s a link to my instagram so you can see a video on it.
Dom R on Instagram: “Here we go.... prototype kdss drop!!! Posting for time stamp while lawyers put together and file the patents. .. This is my fix for the…”
You can now run a straight track bar. Even the stock one which I have on the truck now. With that said I’ll make a straight track bar that utilizes more superior joints then what factory comes with. If you know about factory style bushing / joints. You know that it’s not designed for anything longer stock suspension travel.
This post is for a time stamp!!! Maximize your KDSS + extended travel shocks
More pics
Full droop. Extended travel King shocks
Full bump/
Compression. You can see that it’s still higher then the fuel cell.
Full articulation . Yes that’s a harbor freight floor jack. Don’t hate lol.
Edit
I forgot to post pic with the spare tire to show the amount of room there is. I’m not sure but can somewhat confirm if it looks like there’s more room now with the drop piece I made.
Ride height on 2” lift.
Full droop.
Price range???????
Moreno is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 04:48 AM #30
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
I will have enough for 100 trucks In about 30 days. They will be 6061 t6 billet smooth glossy black powder coated. And I will have some raw version as well and might play around with some anodizing.
This was my question, I can see the prototypes look 3D printed. Do they require extended bolts?
Powdercoat is definitely more durable than plain anodize, though it will change the dimensions and tolerance slightly. Plus it's UV stable (though you won't really need to worry about anodize dye fading when it's under the truck, away from sunlight).
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
full , kdss , stock , track , travel
FS - Icon 2.0 Extended Travel Rear Shocks - Bellevue WA jlstick2 For Sale: Suspension/Wheels/Tires 4 07-31-2018 08:50 PM
FS: Icon Extended Travel Coilovers & 2.0 Rear Shocks - Excellent, Denver, CO rumbleph1sh For Sale: Suspension/Wheels/Tires 7 07-05-2018 10:40 PM
Icon coilivers Standard travel vs Extended travel BOFFROAD 4th Gen T4Rs 5 11-23-2015 01:57 AM
ICON Extended Travel vs. 'Normal' travel coil-overs? snowy 4th Gen T4Rs 9 06-21-2013 06:49 PM
Bilstein 7100 extended travel rear shocks with resi omegaonne For Sale: Suspension/Wheels/Tires 1 06-06-2012 03:20 AM
