Old 07-09-2020, 03:02 AM #196
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Originally Posted by TheWraith View Post
This will still work with stock suspension .
Maybe I'm confused here
on stock height suspension, wouldn't these blocks throw off the balance of the KDSS system with the sway bar somehow?
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 11:20 AM #197
dom42 dom42 is offline
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
It basically just puts it in a different rotating axes.
Not needed for a kdss 4runner if you don’t actually have extended travel shocks that allow the issue to happen. “Stock height “ doesn’t matter because one could have a coil that’s sits at stock ride height but allows for more droop passed what a stock coil can do ( if you have the shocks that allow it ). Once you droop out a specific length the issue of the contact between sway bar and pan hard bar make contact. And that’s where the blocks fix it.
And then trying to achieve more down travel would require the stage 2 part of what I’m working on.
dom42 is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 11:35 AM #198
TheWraith's Avatar
TheWraith TheWraith is offline
Real Name: Justin
TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light
TheWraith's Avatar
Real Name: Justin
After having many conversations and being school by Dom. And wheeling in some very rutted out sections lately. Made me want more downward travel.
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
TheWraith is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 08:24 PM #199
Just try to not sacrifice up travel to gain down travel.
Put it this way. And this is not to you. It’s for every1. If you build a setup that is designed to go fast. That setup will do very well everywhere. Design a setup for crawling ( ie more down travel, little up travel? And it will crawl but will suck out in the open.
Old 07-09-2020, 08:28 PM #200
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
Installed and running with Icon Stage 2...
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 02:14 PM #201
Rmcrom Rmcrom is offline
Rmcrom is on a distinguished road
Looking forward to the KDSS-lean adjuster.
Rmcrom is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 04:39 PM #202
geofox784's Avatar
geofox784 geofox784 is offline
geofox784 will become famous soon enough geofox784 will become famous soon enough
geofox784's Avatar
So what is the final consensus on the part number for the bushing? It looks like some people said that 48818-60080 is not the correct number, but some posts were edited so it is hard to tell.
Edit: 48818-60080 is the wrong size.
15' Grey Trail Premium - My Build Thread
geofox784 is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 04:53 PM #203
usdmej usdmej is offline
usdmej will become famous soon enough
At the same time I have a fix for the front kdss sway bushing mis alignment. This idea will eliminate that whole factory bushing. Poor Design for anything more then stock travel.
please get this to market!
usdmej is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 05:21 PM #204
geofox784's Avatar
geofox784's Avatar
Can anyone confirm what the max amount of extension is that these will be compatible with? I'm looking at having ordering a pair of these, but they have a whopping 25.020 extended length and require extended brake lines.
Old 08-11-2020, 06:28 PM #205
Where is that measurement taken from. If it’s from center of lower eyelet to top of the bottom bushing ( where it rest on frame) then those will work.
Old 08-12-2020, 12:08 AM #206
or are those the tundra shocks? a lot of the "long" travel shocks require you to use a bump stop drop which defeats the purpose of a longer travel shock lol.
Old 08-12-2020, 04:47 PM #207
geofox784's Avatar
geofox784's Avatar
Not sure. Whatever fox uses to measure. Straight from their website. After reading through this thread a second time it definitely looks like these will work just fine.
Old 08-12-2020, 04:57 PM #208
geofox784's Avatar
geofox784's Avatar
They are the tundra shocks. It’s what accutune recommends for a non KDSS kit and it comes with longer brake lines. They reach max compression 1.6” sooner than stock, but they have 2.5” more max extension vs stock. The other option is to get the kit they recommend for KDSS 4runners, which is the standard 4Runner shock from fox. Compared to the tundra shock it has an extra .5” of compression travel, but it has 1.5” less max extensio.
So is it really worth it to get an extra .5” of compression, but by doing so you are sacrificing 1.5” of extension?
Old 10-09-2020, 04:04 PM #209
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Installed mine yesterday evening. The install is fairly simple.....except when you have a C4 diff skid. I got to the driver bolt of the swaybar and the damn bolt wouldn't go back in. I worked and worked until I realized the problem was the C4 mount was not lined up correctly so the bolt was hitting it and wouldn't go in. I finally came to the conclusion I was going to have to remove the bolts on the top of the diff skid and swing it down. Problem was, after I installed my gas tank skid the bolts are not reachable. So I had to remove the gas tank skid, remove the top bolts on the diff skid and swing it down, then I was able to get the bolt into the swaybar and through the diff skid mount. Then of course I had to put that all back together. This was probably an idiots guide to installing these things as it took me 5 hours, partly because I had the 4Runner on the ground (so that my cheap a$$ jack would work) and it was really cramped and it took me a while to figure out what the problem was. Without the diff skid this would have been really easy.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 10-09-2020, 04:09 PM #210
geofox784's Avatar
geofox784's Avatar
Any reason you unbolted the sway bar at the axle mounts instead of just removing the 4 bolts that go through the spacers? I have the C4 skid as well and never had any reason for it to get in the way during the install.
full , kdss , stock , track , travel
FS - Icon 2.0 Extended Travel Rear Shocks - Bellevue WA jlstick2 For Sale: Suspension/Wheels/Tires 4 07-31-2018 08:50 PM
FS: Icon Extended Travel Coilovers & 2.0 Rear Shocks - Excellent, Denver, CO rumbleph1sh For Sale: Suspension/Wheels/Tires 7 07-05-2018 10:40 PM
Icon coilivers Standard travel vs Extended travel BOFFROAD 4th Gen T4Rs 5 11-23-2015 01:57 AM
ICON Extended Travel vs. 'Normal' travel coil-overs? snowy 4th Gen T4Rs 9 06-21-2013 06:49 PM
Bilstein 7100 extended travel rear shocks with resi omegaonne For Sale: Suspension/Wheels/Tires 1 06-06-2012 03:20 AM
