Old 01-16-2020, 10:11 PM #1
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
Rear Brake Line Keepers....
Crawling around under the truck today chasing a rear end squeak. Located the culprit and it was the rear brake line rubbing on the top of the keeper loop. To my dismay the brake line hose now has notch in it (both driver and passenger) from where it has been rubbing on the keeper. I tried bending it so that the hose would sit in the middle of the loop, but still rubbed. How bad of an idea is it to just remove the keeper loops?
Rear Brake Line Keepers....-img_4814-jpg
shrub1 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 05:33 AM #2
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
There was another thread about this squeak problem a few weeks ago. One solution is to bend the loops and/or position them via the bolts to make the cable tube centered and parallel in the loop. I did that then lubed the tube with white lithium grease. No squeaks after I did that.
I would think that the tubes are really needed to keep the cables in the correct routed bent position for the brakes. If they weren’t there the cables would flop around, drop down, and possibly catch on something while off-roading. If I recall, there is an additional rubber sheath-like tube over the actual brake line where it goes through the tube. Is that what got worn through? Maybe you can rotate that a little bit to get the worn area away from the metal edge of the keeper. Then try a silicone lube or grease wherever contact is made.
Old 01-17-2020, 11:41 AM #3
shrub1's Avatar
shrub1's Avatar
I think I am going to remove the keepers and use heavy duty zip tips to keep the lines up. My bigger concern that just the squeak is the rubbing and notching into the brake lines the rubbing on the metal loop has created. I've bend the loop into various positions, but there is still contact with the brake line.
brake , hose , keeper , line , rear
Rear Center Line installation and other SS brake line info tv4184 4th Gen T4Rs 7 07-10-2023 04:33 AM
Brake line over rear shocks? LIVEVIL 3rd gen T4Rs 8 04-26-2018 10:46 PM
WTB: Rear axle hard brake line 3rd gen J-money$$$ Want to Buy/Trade 4 11-12-2015 06:46 PM
Rear brake line extension Spish 3rd gen T4Rs 7 03-17-2011 07:25 PM
All Pro Offroad Extended Rear Brake Line... surf185 Classifieds - buy & sell (no commercial ads please) 0 06-05-2008 01:53 AM
