Old 06-23-2021, 08:05 AM #1
crawlingjunk's Avatar
crawlingjunk crawlingjunk is offline
crawlingjunk will become famous soon enough crawlingjunk will become famous soon enough
Trd fox suspension spacer lift
I have seen spring preload spacers. But I think that it will sacrifice the ride of fox shocks. Is there a reason I couldn’t use top hat spacer to get the lift I want. Use 1 inch top hat spacer to get a 2 inch lift, and clock the top hat 45 deg on the struts so the bolts line up on the correct sides
Would that work and keep the ride quality?
crawlingjunk is offline   Reply With QuoteReply With Quote
Old 06-23-2021, 09:16 AM #2
Stephencovar Stephencovar is offline
Stephencovar will become famous soon enough
After a ton of research and self reflecting (lol), I ended up going with the Westcott Design’s Fox Lift Kit. Jeff Westcott has about 20+ years experience with Toyota. He specifically designed the lift kit to work with the Fox suspension. Everyone’s review’s I’ve read states that the ride quality improved and that it’s the way the TRD Pro should’ve come from the factory. I haven’t received my kit yet but I believe I’ll have it by next week. I’ll report back when it’s all installed.
Westcott Design’s has a few videos on YouTube about the lift. There is one in particular where he talks about it being at full flex and the suspension itself isn’t bottoming out and hits the bump stop. That right there is what sold me. Well, that and Jeff seems like a genuine, hard working person that believes in their product.
Stephencovar is offline   Reply With QuoteReply With Quote
Old 06-23-2021, 10:57 AM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Although I don't have a TRD w/Fox, I have spacers that go on the top of the front strut, between the strut and the frame (from Rough Country). The ride quality is the same, shock travel is the same, spring compression is the same. The only difference is the spindle is moved down a couple inches.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-23-2021, 11:32 AM #4
That’s what I’m thinking. You are not preloading the spring. Only thing it bottoming out the shock. But that can be fixed with bump stop drop.
Old 06-23-2021, 09:30 PM #5
With the spacer between the strut and the body mount, the spring/strut length is the same, thus as you stated, there is no spring preload.
The wheel down travel is limited by the shock, but that travel distance is the same with or without the spacer.
Like wise, the wheel up travel is limited by the bump stop at the top of the shock, but that travel distance is also the same, with or without the spacer.
Old 06-24-2021, 01:37 PM #6
Ok so with 2 inch corn fed spacer. It rode stiff as hell. Didn’t like it. So I put in 1 inch top hat spacer and rides smooth and plush. Only issue is the UCA is contacting one coil at full droop on drive side only. That can be fixed with new UCAs.
hat , lift , ride , spacer , top
Spacer lift on top of suspension lift Rushingman 4th Gen T4Rs 12 09-21-2016 10:03 PM
fs 4th gen 4runner oem complete suspension with toytec 3" spacer lift central Cali 2vonku For Sale: Suspension/Wheels/Tires 1 02-01-2016 05:40 PM
**SOLD** toytec 2.5'' spacer front lift and rear 1.5" spacer lift 4Runner8 Classifieds - buy & sell (no commercial ads please) 1 08-10-2010 06:06 PM
Spacer vs Suspension lift???? gunny1001 3rd gen T4Rs 6 11-08-2009 12:25 PM
Cornfed 2" rear Spacer, Ready Lift 2.25" Front Spacer bt216 Classifieds - buy & sell (no commercial ads please) 18 08-08-2009 05:40 PM
