Old 01-17-2020, 03:49 PM #1
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
Question OME BP51 Suspension Damage?
I didnt run my finger over the chrome shaft but it looks like one of my BP51's is leaking oil (Front driver side). If you look closer it may look like the chrome shaft is cracked, but I forgot to run my finger over it just to see if it was just oil build up or really cracked. Guess ill do that now, to see if the shaft is smooth.
Anyones BP51's leaking or leaked in the past, cracked shafts?
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 03:56 PM #2
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Im only running rears on mine but no issues. However I have heard leaks and build quality issues are prevalent on these which is what stopped me from running them up front on my build. Thankfully ARB has great warranty and support.
Check IH8mud and tacomaworld for threads on BP-51 issues with these...
El Dusty is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 04:13 PM #3
propain's Avatar
propain's Avatar
I'm wondering if ARB/OME will send me 2 front shocks instead of 1. Would be nice if they did that. Waiting for their reply.
Old 01-17-2020, 04:30 PM #4
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
that looks like oil buildup on the limit of your normal stroke.
If you're running those without boots in a salty environment, there could be pitting on the shafts which progressively got worse. This will damage your wiper seal and main seal, letting contaminates in.
Those need to be rebuilt with new shafts. Run coilover wraps next time to keep all the winter grime out.
costs should be close to the following:
(each coilover)
$25 for seal kit
approx $75 for a new shaft
Shock oil and nitrogen $20
While you're at it, I'd replace the lower spherical bearings when the shocks are off. I think the OME's use COM10T. You could upgrade these to stainless if you'd like.
They should be about $15 each
I'm not sure what labour would be.... but internal bypasses with all the seal replacements and fresh oil, and bearings should be about 1 hour per coilover.
Anyway, welcome to rebuildable shocks. I wouldn't expect that to be a warranty issue, it's time for a rebuild.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 04:35 PM #5
nb rob's Avatar
nb rob's Avatar
actually,
how long have you had them on your vehicle?
Old 01-17-2020, 04:36 PM #6
propain's Avatar
propain's Avatar
Originally Posted by nb rob View Post
actually,
Since July 2017. Who would Rebuild these shocks? Would I remove them and send them to ARB USA to rebuild? I don't think anyone around my way can do the rebuild. Maybe 1 or 2 places might, but i know they never worked on OME BP51's.
Old 01-17-2020, 04:56 PM #7
nb rob's Avatar
nb rob's Avatar
I would contact filthy motorsports. If they can't help, they should be able to tell you where to send them.
You may or may not need shafts. Likewise, you may or may not need some internal honing....those prices were just ballpark. I'm in Canada, so I get most of my parts through summit or manufacturers if needed.
I've done a few truck sets, and then I bought Amsoil from a UTV guy, and the next thing you know, I've done seals and shafts for a few full sets of UTV coilovers. I'm sure there's other guys like me out there covering the cost of their nitrogen and spring compressors.
Hopefully you can get some coilovers together to put on while they're being rebuilt.
Good luck!
Old 01-17-2020, 05:12 PM #8
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Can these be rebuilt in the states?
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 12:28 AM #9
vipers28 vipers28 is offline
vipers28 is on a distinguished road
Yes at their corp in Auburn, WA. or so I am told.
vipers28 is offline   Reply With QuoteReply With Quote
Old 01-23-2020, 04:41 PM #10
propain's Avatar
propain's Avatar
The tech support team at ARB USA is outstanding.
No rebuild required. They are sending me a new coilover shock to replace the damaged one. This saves me, the customer a lot of downtime. I can't thank them enough.
I do recommend OME BP-51 if you are in the market for a new suspension system. Not because they are replacing my coilover, because their shocks are really tough and can handle the weight of an overland vehicle. Especially if you have additional weight in the front, bumper & winch setup.
Thanks ARB USA!
Old 01-23-2020, 05:54 PM #11
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Huh. They are literally just across the RR tracks from me. Never even knew it.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 01-23-2020, 06:43 PM #12
nb rob's Avatar
nb rob's Avatar
Thanks ARB USA!
impressive and good to know! Thanks for the update.
Old 01-24-2020, 11:22 AM #13
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
That's unlikely. A warranty covers the part in question, unless they know there's a build issue with an entire production run and replace them all under a recall, but I doubt they'd do that.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 02:46 PM #14
Lots of cool thing in and around Auburn!
It's not a store front either so you can't go and shop there.
Old 01-24-2020, 02:46 PM #15
honda250xtitan honda250xtitan is online now
sheesh thats awesome they're sending you a replacement.
honda250xtitan is online now   Reply With QuoteReply With Quote
bp51s , cracked , leaking , oil , shaft
Totally confused by suspenson options, Down to Radflo or BP51 SendInTheCavalry Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-27-2019 11:09 AM
OME BP51 vs others... stephan07 5th gen T4Rs 12 10-04-2017 12:31 PM
Just ordered OME BP51 for 5th Gen propain 5th gen T4Rs 10 06-30-2017 10:58 PM
2/1 Cornfed = Damage to Suspension keylay31 4th Gen T4Rs 28 11-26-2007 09:25 PM
02 4runner accident suspension and steering damage jesman1484 3rd gen T4Rs 13 11-03-2007 06:08 PM
