Old 01-17-2020, 04:41 PM #1
oncewaspfd oncewaspfd is offline
oncewaspfd is on a distinguished road
Do I need a second battery?
I plan on installing a 32" LED light bar behind my grill. Will I need a 2 battery setup or will 1 battery work?
oncewaspfd is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 04:45 PM #2
samwhich's Avatar
samwhich samwhich is offline
samwhich has a spectacular aura about samwhich has a spectacular aura about
samwhich's Avatar
Unless you plan on it always being on, one battery will be just fine...and by always I mean even when your tuck is turned off.
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
samwhich is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 05:12 PM #3
jhguth jhguth is offline
jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light jhguth is a glorious beacon of light
1 will work
jhguth is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 05:20 PM #4
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama has a spectacular aura about DannyLlama has a spectacular aura about
DannyLlama's Avatar
Real Name: Danny
From everything I have read and reviewed, a second battery will come in handy if you are running crazy amount of high voltage equipment. IE winch + million lights + high preforming system.
Otherwise, get a good solid deep cycle battery and will you be golden.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg ball joint UCA's Fox 2.0 Resi rear W/ Icon 2" Springs. FN Wheels BFDs, Toyo Open Country A/ II Xtreme 285/65/18. Shrockworks custom sliders LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 05:25 PM #5
PK930's Avatar
PK930 PK930 is offline
PK930 is on a distinguished road
PK930's Avatar
Do you need dual? No. Not for that.
Do you want dual? Cause if that's the case, anything want can be a need. And sometimes, it ain't about the need...
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 05:42 PM #6
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
Dual Battery Thread
Old 01-17-2020, 11:15 PM #7
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck has a spectacular aura about Xtremluck has a spectacular aura about
Xtremluck's Avatar
The only real reason to get a second battery is to power equipment while the engine is off. So no you donít need it.
'12 Silver 4Runner SR5: 14+ facelift, Pelfreybilt front, CBI Rear, Warn M-8000S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, Icon CDCV suspension w/UCAs, OME 899, Nitto RG 285s, Full RCI Skids, Metaltech Sliders, Gobi Rack, ARB Awning, Rotopax,1up Hitch Rack
Xtremluck's 2012 SR5 Build Thread
Instagram - @Aperture20
Xtremluck is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 05:06 PM #8
It's all 12V (nominal) voltage
If you meant high amperage then a second battery is just a band aid to fill short periods of time when you are drawing more than your charging ability (for example, very long hard winch pulls). If your lighting or other accessories exceed your alternator, you need an upgraded alternator not a battery.
Old 01-19-2020, 07:29 AM #9
Thanks for the advice everyone.
bar , battery , grill , light , setup
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
Anyone using the $26 Summit Racing SUM-G1201 battery tray for 31M battery? jicko 5th gen T4Rs 3 04-27-2015 12:24 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information CBR_GUY_IA TSB 0 07-12-2009 09:30 PM
