Old 01-20-2020, 01:01 PM #1
FamousAv8er's Avatar
FamousAv8er FamousAv8er is offline
FamousAv8er is on a distinguished road
Exclamation Drivers Side Interior Ground Points OR Bolt Spec
I was planning to use a drivers seat bolt as a ground but the bolt is painted. I need one of two things.
I either need locations where I could possibly ground my amp. This would need to be near the drivers seat.
OR
I need to know the specs of the drivers seat bolts so that I may buy an unpainted one.
Please and thank you!
Daily Driven '17 T-Force T4R - Baja Flat Rack - 5100s
odo: 80,000
FamousAv8er is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 03:47 PM #2
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
You could take some sandpaper to the factory bolt to expose bare metal; however I’d suggest running a ground under the plastic door trim, through the firewall, and back to the battery.. it’s not hard and only takes a few minutes. I wouldn’t want to use a body ground for audio equipment, but that’s me. Good luck!
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 04:00 PM #3
The bolt is M10 x 1.25 x 30mm
odo: 80,000
Old 01-20-2020, 04:08 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Grounds should always be as short as possible. You can always create your own if necessary. You can test with a meter first by scratching off a little paint and then test to a known good grounded location. 2 ohms max for a good ground with a zero'd meter to compensate for the leads. If you meter doesn't have a zero function then touch the leads together on the lowest ohms scale and note the reading. Then subtract that from any readings you take.
Once you have a spot, you can remove the paint necessary (burnish the contact area around the hole) and either install a bolt to make a ground stud to attach a lug (best way) or tap a hole. Either way, good contact between cleaned surfaces is key. Once complete, re-test to confirm result of less than 2 ohms. Your ground connection then can be covered to prevent corrosion. Nail polish works well here and can easily be removed and reapplied if necessary. If you're interested in a ground stud buildup let me know and I'll post the required hardware and stacking.
Old 01-20-2020, 08:26 PM #5
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
2 ohms is a pretty shitty ground IMO.
That would be like having 800ft of 14 gauge wire in your ground path!
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 12:41 AM #6
Space King's Avatar
Space King Space King is offline
Space King is a jewel in the rough Space King is a jewel in the rough Space King is a jewel in the rough
Space King's Avatar
2ohms is pretty garbage for a ground path.
"Sometimes I sit and think. Sometimes I just sit."
Space King is offline   Reply With QuoteReply With Quote
Old 11-20-2021, 06:50 PM #7
Farzad_K Farzad_K is offline
Farzad_K is on a distinguished road
I just did a ground continuity test between the nearest 12v accessory port (in the center console box) and one of the bolts of the rear seat and I do get continuity, which is the same as measuring resistance with my MM, and I get about 0.1 ohms which is the smallest that my MM can measure.
Farzad_K is offline   Reply With QuoteReply With Quote
bolt , drivers , ground , seat , specs
ground points skkiii_whhaattt 3rd gen T4Rs 36 12-05-2023 04:13 PM
Big 3 Ground points? ZoomSpeed Engines / Suspension / Wheels / Tires / Audio / Accessories 7 05-12-2022 06:36 PM
Ground points? Several minor electrical issues da.hs 4th Gen T4Rs 0 01-29-2017 05:11 PM
Wanted: Drivers side black rear side plastic bumper Griswald Want to Buy/Trade 0 08-31-2015 02:05 PM
ground points skkiii_whhaattt Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-27-2006 04:39 AM
