Rear Shock Mount installation questions
Replaced the rear shocks with 5100s this weekend and added a 1.5" Cornfed spacer on the springs. (did front 5100s last week at 1.75") Getting everything back together with the new spacers, using only floor jacks and stands, was a little tricky. I noticed, once everything was buttoned back up, the top shock mount bushings looks a little wonky. Is this something to be concerned about? Something I need to take apart and fix? They look fine from the bottom.
Also, when reattaching the rear sway bar link I noticed the little rubber boot on the link had a small tear. Not sure if I did it during disassembly/reassembly, or if it had been like that a long time. Again, how concerned should I be about that. Because TBH Im not.
