Old 01-22-2020, 08:18 AM #16
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
Originally Posted by jbtvt View Post
You've got a list of mods a paragraph long and don't change your own oil? Drain plug, not a "lug nut".
The runner only has 16800 miles on it. This was my 2nd oil change. I use Mobil1 Extended Performance. 15 degrees out. Didn't feel like doing it. Next time I'm going to do it.
I hope these scumbags don't need to remove my skid plates to fill up the tranny fluid. Cause then I got to worry about them stripping bolts and putting them back together without F'ing it up.
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 09:29 AM #17
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough BadTrainDriver will become famous soon enough
Originally Posted by propain View Post
It's bad enough they put in non synthetic engine oil when I been using fully synthetic oil
I was not even aware that 0W30 is made in non synthetic.
Edit: I meant 0W20.
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 10:45 AM #18
enyce enyce is offline
enyce is on a distinguished road
Problem with the dealerships performing oil changes it's usually a "general service" tech with little to no knowledge of automotive repairs. Unfortunately most shops do not have lead techs or service mgr. to oversee newbies doing low level automotive repairs.
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
enyce is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 10:46 AM #19
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
Quick check on my Napa ProLink and the closest I can find is a synthetic blend 0w20 from Valvoline, but otherwise it's all synthetic. So I'm puzzled, too.
And absolutely nothing non-synthetic in 0w30. But I don't use that weight.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 12:15 PM #20
propain's Avatar
propain's Avatar
I'm here at the dealership. They also found out the tech did not tighten the oil filter which was also leaking. Said they have to add a quart of Mobil1 and tighten it up.
As for the tranny, they need to drop the tranny, and fill it all back up because they don't know how much tranny fluid was lost. Said their master mechanic is doing the work.
Jesus Christ, what a F'ing nitemare. All this because I took the runner at the dealership for an oil change.
Old 01-22-2020, 12:15 PM #21
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I can almost guarantee they are not greasing the spider and slip yoke joints. And if they are, I bet they don't use the specified greases.
I started doing my own oil changes many miles ago, after having them done at the dealer for at least 100k miles. When I went to grease those joints, the factory black paint was still on the zirk fittings, grease would not go in until I picked it off. Once I got the grease pumping, there was a ton of air in them. Not to mention the cross threaded skid plate bolts. Pretty lame.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 12:23 PM #22
propain's Avatar
propain's Avatar
Edit: I meant 0W20.
They put in the wrong weight. A non synthetic.
Old 01-22-2020, 01:23 PM #23
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
They're having to drop the tranny to fill it up?
08TxRunner is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 01:46 PM #24
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
You'd might as well mention the name of the dealer.
Old 01-22-2020, 01:52 PM #25
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Their master mechanic needs to do a full service and the service manager needs to recheck everything.
You also need to figure out what you want from them as compensation. I could see some bits from the parts counter since I'm not sure you want them to service your car - although I'm sure they'll treat you like a king in the future.
I trust you're in a loaner.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 02:13 PM #26
rcb22 rcb22 is offline
rcb22 is on a distinguished road
what dealer is this?
when I first got my 4runner, I took it to the one in queens. I had an appointment and they still told me itd be 4-6 hours. They also wouldnt disable the seatbelt warning beep, even though my manual said it was an option. After this I noticed 5 sales guys and mechanics in and around my truck checking it out. I told them to get the hell out and left.
Took it to a dealership upstate where I have a cabin and it was night and day difference. Amazing folks at the Kingston dealership.
rcb22 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 02:29 PM #27
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
… As for the tranny, they need to drop the tranny, and fill it all back up because they don't know how much tranny fluid was lost. Said their master mechanic is doing the work.
There are posts on this forum that discuss changing ATF. It is not necessary to remove the transmission to top off the fluid. The 2010 factory manual does not specify transmission removal for ATF fluid change or check level.
DougR is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 03:03 PM #28
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
You do not need to drop the tranny to change the fluid, what on earth is this dealer doing? Also, it is not a lug bolt, it's a bolt.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 03:20 PM #29
propain's Avatar
propain's Avatar
They just drop the tranny pan. Not the whole transmission.
Old 01-22-2020, 03:21 PM #30
02SE 02SE is online now
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Yeah, it's usually NOT the highly qualified guys doing oil changes. Hopefully the guy doing the work now is conscientious.
I will be doing all the servicing on my new 5th gen myself.
02SE is online now   Reply With QuoteReply With Quote
change , dealer , fluid , oil , tranny
Did the dealership really change my oil?? dannyg 4th Gen T4Rs 26 03-08-2017 05:21 PM
Dealership Oil Change - Total Time? Jayhawk5G 5th gen T4Rs 28 04-12-2016 03:42 PM
Oil leak after dealership oil change MuddyButt 3rd gen T4Rs 14 06-04-2015 01:18 PM
Oil Change Price at Toyota Dealership ice2000 4th Gen T4Rs 26 06-19-2011 12:51 PM
Dealership Oil Change reds10 5th gen T4Rs 9 05-21-2011 07:12 PM
