01-29-2020, 12:37 PM
#91
Banned
Real Name: Mark
Banned
Real Name: Mark
This was confirmed to me by a Toyota shop manager. It’s a commission system. Faster work = more jobs = more money. Even if the managers may not like it they have to do it this way, that’s the business model they’re dealt. Oil changing is the job given to the new inexperienced guys, although they’ve all gone through a training course and have been “certified”. (It wouldn’t surprise me if certification was done by watching a PowerPoint presentation).
I took my new 4R in for its first four dealer services of oil change/tire rotation, etc. and they screwed something up each time. It took more of my time to get each one resolved. I do my own routine maintenance now.
01-29-2020, 12:55 PM
#92
Originally Posted by RusPro17
... mechanic I use all the time had him do the second oil change and he pointed out to me that the dealership never changed the oil filter …
How did he know the filter wasn't changed? Was it crushed? I kept the last oil filter installed by the dealer when I did my first oil change. I'll compare it with the oil filter I installed when I change oil again.
01-29-2020, 07:41 PM
#93
Originally Posted by Rondigs
Did my first oil change on the 4Runner last night. And throughout the whole process was wanting to go burn the dealership to the ground. First issue, my skid plate was missing a 12mm bolt. The second issue... the plastic oil filter canister would NOT come off! I was shaking trying to put all the muscle I had into it. Since it was my first oil change with the new plastic canister, I started second guessing myself and did some research to make sure I was on the right track. Yup, I was using the really nice motiv (spelling?) 64mm wrench and lefty loosey. It would not budge. Then, Unfortunately I had to get a breaker bar. And yup like breaker bars do, it broke one of the plastic tabs off! At this point, I was pretty pissed. Ended up, folding a piece of paper and putting it between the socket and canister and thankfully it came off. I was able to change the filter and reused the canister. However, I’ll need to replace it in the future.
Moral of the story: service techs (some... maybe not all) do not care about your vehicle like you do. All they know is use the impact wrench on everything and good enough will get by.
I had a similar experience with the plastic canister on my 4Runner too after taking it in for the free service. I broke a tab because it was so tight which put hole in the canister. It would not come off. I called the dealership to have them tow it and replace the canister. I asked if they hired a gorilla to do that work and have not been back for service since.
2016 TEP
01-29-2020, 10:09 PM
#94
Back in the 90's, my office closed down a couple of repair shops. It started with a complaint by the base commander that his oil hadn't been changed at the on-base garage.
We sent through a series of prepared cars with simple problems (loose battery terminals, oil leak because of a loose drain plug - those kinds of obvious things) and saw what the customer was charged. The oil leak was a head gasket job and so forth. We went in one night and copied all of the data on the concession's computers and raided him the next morning.
The German police raided his house and found lots of parts. He ordered parts cheap through his on-base shop but was running a repair shop downtown specializing in American cars. We found one alternator that he bought for $35 that he sold for $650.
He went to German jail for several years.
Funniest part was that he probably did the oil change on the base commanders car (an old diesel Toyota pickup), but the base commander (who wasn't a car guy) checked his oil several hundred miles later and found it dirty.
Now, I always mark the car before going in for service - the oil filter if I can see it easily or plop some mud over a bolt holding on the belly pan - marking the screw first. If the mud and mark are still there then they didn't pull off the cladding.
When in trouble - obfuscate
01-30-2020, 04:25 AM
#95
Wait ,what, 4runner has Plastic oil filter housing ????
Is this a joke?
01-30-2020, 06:52 AM
#96
Is this a joke?
You think that is bad- some vehicles have plastic oil pans now.
The Toyota plasic oil filter housing is easily replaced with an aluminum OEM Toyota one for under $20 if it bothers you.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
01-30-2020, 07:26 AM
#97
Real Name: Don
Real Name: Don
If I recall because it was quite a few years ago when I had my 15 Tacoma. I think there are certain numbers on them from factory install does them.
01-30-2020, 09:15 AM
#98
Is this a joke?
My ‘69 Honda CB750 has a plastic cam chain guide. It might be time to get used to plastic in modern engines.
01-30-2020, 11:26 AM
#99
Is this a joke?
It’s protected by the front skid plate too and can’t really be hit and hurt unless a severe hit happened.
2016 TEP
01-30-2020, 12:23 PM
#100
I love a good "do not go to the dealer for an oil change" thread.
Same shit over and over since the beginning of car forums.
01-30-2020, 06:30 PM
#101
Real Name: Ted A Hamilton
Originally Posted by patkelly4370
With 1,500 Toyota dealerships in the United States I'm guessing that not all of them have drooling morons for mechaics.
For every one forum member there must be hundreds or thousands of Toyota owners.
So we are, and aren't, hearing a subset of a subset, and only hearing the negative stories.
Of the many occupations I've had, I was a mechanic. I was always conscientious that my work, my craft, affected the lives of thousands. But I also know that not everyone takes pride in their work. I have seen that in all of the fields I have worked in and been a consumer of.
That said, I do as much of my own vehicle maintenance as possible.
"Man bites dog" is a headline. "Dog bites man" isn't even a story (unless currently it was a pitbull)
I hear ya. It can happen anywhere. I have confidence in the dealer I deal with based on years of use. Service guy I deal with always takes me back to show me the issue if one exists. You just have to develop a good relationship with the service folks regardless if dealer or not.
For example, I had my dealer install my front hitch receiver and the mechanic came out and said he did not have a torque wrench to properly torque bolts. Loaned me a vehicle to go get my wrench.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
01-30-2020, 07:38 PM
#102
Is this a joke?
Yes it is plastic but you can replace it with a metal Toyota housing or other after market metal housing. Toyota Part N 15620-31060. take the stem out of your plastic housing and replace the shorter one in this part and you are good to go.
Here is a link:
Metal Oil Filter Housing Upgrade + Motivx Tools Oil Filter Wrench
01-30-2020, 08:35 PM
#103
Originally Posted by kfs-4runner
I was just looking at this at Auto Zone.
01-30-2020, 08:46 PM
#104
Good info . Thanks
01-30-2020, 08:58 PM
#105
Has leaked for others in the past.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
