Old 06-26-2020, 01:56 PM #121
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by itr1275 View Post
Lately, I've been going to Skips Tire on Cottle Rd. for most of the maintenance of the 2011 T4R (sold) and they haven't caused any extra problems that I know of. Done when it's supposed to be and reasonable cost too.
Most dealers techs are paid book time, which means they get paid something like 3/10ths or 4/10ths (18 mins or 24 mins) for an oil change. If they get it done in 6 mins, they still get paid for the entire time it's billed. Just encourages sloppy work on short jobs.
Since 90% of the customers never look below the window line they can bugger it up all they want and make it the next guys problem.
What really pissed me off about the lugs is that I could have been on the train and gotten a flat 60 miles from an auto parts store. 3 broken lugs on one wheel is sort of an issue.
True.
The oil changers never met a bolt they couldn't use an air tool on. Result: crossed threads on skids and drain bolts, and over torqued wheel lug nuts.
Solutions: Find a competent independent mechanic, or DIY. If you do use a dealer at least check the their work before you leave.
Old 06-27-2020, 02:47 PM #122
4FL 4FL is offline
4FL will become famous soon enough 4FL will become famous soon enough
4FL 4FL is offline
I go to the dealership, too many idiots in independent shops around Miami to weed through to find that one good one. I figure at least if the dealership screws up, I am better off dealing with them than some independent shop in trying to fix the screw up.
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 03:36 PM #123
jcpastor10 jcpastor10 is offline
jcpastor10 is on a distinguished road
Originally Posted by Dynamo View Post
The parts numbers you are looking for are:
51403-60020 (without dynamic suspension)
or
51403-60030 (with dynamic suspension)
Whichever applies to you, driver & passenger side use the same part number. They are less than $80 each from here.
Anyway, these are the front braces that the splash shield bolts on to. The braces themselves are just bolted on so they are easily replaced when the splash shield mounting holes get stripped or messed up.
Oh yes!! I had taken them off alrdy after i took off the splash shield. Thank you so much
Sent from my SM-G973U using Tapatalk
jcpastor10 is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 03:40 PM #124
or
How would i know if i have dynamic suspension or not? Im running stock suspension.
Old 06-27-2020, 03:45 PM #125
Originally Posted by moorei2 View Post
I had similar issue with my 2016 4Runner. When i went to take off skids for 1st time (have used dealer up until that point for oil changes), a couple of the splash guard screws just snapped. It gave me an excuse to get RCI skid and their splash guard (other aftermarket companies also make splash guard). RCI splashguard uses different bolts and attachment points than stock does. You may want to see if their splash guard would work with stock skid. Others here may know the answer.
Yeah im looking at maybe getting one from Victory 4x4. Its running me abt $300+ to get their front skid plate. And with the installation, you hve to take those 2 front braces off and uses different holes to put a bolt and a nut to hold the skid plate.
Old 06-27-2020, 05:28 PM #126
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Dynamic suspension (KDSS) will have a pump with lines running to it located on the frame rail on the driver side towards the front, like by the driver door. It's on the outside of the frame so you can easily see it if you take a quick look under there.
Check this thread: How do I know it has KDSS?
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 05:11 PM #127
4runruner 4runruner is offline
4runruner is on a distinguished road
Very helpful - thanks you.
4runruner is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:58 PM #128
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
ALL FLUIDS GUIDE: Beginner Fluid Maintenance
This guide makes it much harder to make excuses about why we can't change our own fluids! LOL
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 04:30 PM #129
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Do not go to dealership for oil change!
Went to dealership for my 2nd oil change and tire rotation. They did the rotation since I marked the tires to make sure. When I crawled under the 4R, I noticed something hanging off. It turned out to be an easy fix, but I will never go back to a dealership. The simplest thing to do and they screw it up. I’m assuming they changed the oil, but I have no idea.
2022 4 Runner SR5 Premium--For Sale:ConsoleVault safe, HikeIt throttle controller
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 07:14 PM #130
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I suggest calling back and sending pictures to upper management. They may apologize and offer something to compensate. It's OK to tell them you will not return. They can take the feedback and improve (or not).
DougR is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 07:28 PM #131
Banned
Real Name: Mark
Banned
Real Name: Mark
After my 2nd free oil change a similar thing happened to me. The two front bolts were missing from the front skid plate. It was just dangling by the two rear facing ones. I gave the service manager hell and never went back.
These occurrences will never end. Think about the average dealer and how they handle personnel. You hired a new inexperienced guy, where do you put him to learn? Oil changes. Where they also make more money the faster they work and cram more oil changes into their work day.
Old 05-09-2021, 08:48 PM #132
Mark4runnar's Avatar
Mark4runnar Mark4runnar is offline
Mark4runnar will become famous soon enough
Originally Posted by propain View Post
My mistake was going to the dealership for an oil change.
1.) they put in the wrong oil. then they said they put in the right oil after draining the wrong oil.
2.) they loosened the transmission instead of the oil pan nut. Had atleast 1 pint of tranny fluid on my driveway after coming home from the dealer.
I couldnt find a transmission dipstick on the 5th Gen to check how much tranny fluid i really lost, so now i have to go back to the dealer and tell them either to top it off, or, drain and replace all the tranny fluid.
Never going back to the dealer for an oil change.
I think my RCI Skidplates confused them on where the oil drain plug was. Why would they even touch my tranny. The tranny drain plug was loose, had to tighten it up.
*pissed*
Next time i go to my local mechanic for Mobil1 oil change or do it myself.
sorry to hear this -- I will never go back to a dealer for oil / filter change....... the 5th gen is the most complex oil / filter change I have ever done.I have 115lkon the 4runner and have done oil / filter every 5000 miles....guess what I am now an expert. I have a killer garage at the summer house in RI. I will show you how to do it if you want to swing by.
Mark4runnar is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 10:16 PM #133
Dreeves Dreeves is offline
Dreeves is on a distinguished road
*pissed*
When I did go to the dealer for my first few “free” oil changes I specifically spoke to the service manager about stripped skid plate bolts, oil leaks and mega torqued on oil filter assemblies. I told him I could not believe all the comments on the internet about low quality service from dealerships. I never had a problem, maybe that helped😫😫
Dreeves is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 10:29 PM #134
Yea, i couldnt make up this story if i tried. Spent most of my morning today power washing my driveway in 40F degree weather. Jesus... baking soda & dish liquid... over and over a few times....i swear, i better not have a fresh oil stain tomorrow morning or else i will flip out.
** If you noticed it says (6) qt of Mobil1 on the service ticket above.
*** Now look at what it says above on this service ticket.. (6) qt of 0w20 BULK OIL-W and 1 qt of Mobil1. What are they using 0w20 BULK OIL-W for? Makes me think they drained all my Mobil1 Oil, added their shitty synthetic blend, and added 1 quart of Mobil1? I'm Confused
Oil on the top, Tranny fluid on the bottom...courtesy of Sansone Toyota.
Another reason to not go to a dealer. No business in my trunk. 😫😫
Old 05-10-2021, 07:50 AM #135
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I go to the dealer for every oil change, just to buy the oil and filter. Parts counter guys recognize me and are selling me the Toyota oil for less than I can get the "other oils" and the filters for like $4. They also sell me the cabin and engine air filters for $20. Parts guys are "usually" pretty cool on deals and price match. Service guys, different story. I try to do all of my own work if I can.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
change , dealer , fluid , oil , tranny
Did the dealership really change my oil?? dannyg 4th Gen T4Rs 26 03-08-2017 05:21 PM
Dealership Oil Change - Total Time? Jayhawk5G 5th gen T4Rs 28 04-12-2016 03:42 PM
Oil leak after dealership oil change MuddyButt 3rd gen T4Rs 14 06-04-2015 01:18 PM
Oil Change Price at Toyota Dealership ice2000 4th Gen T4Rs 26 06-19-2011 12:51 PM
Dealership Oil Change reds10 5th gen T4Rs 9 05-21-2011 07:12 PM
