Old 01-21-2020, 04:48 PM #1
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
Arrow Do not go to dealership for oil change!
My mistake was going to the dealership for an oil change.
1.) they put in the wrong oil. then they said they put in the right oil after draining the wrong oil.
2.) they loosened the transmission instead of the oil pan nut. Had atleast 1 pint of tranny fluid on my driveway after coming home from the dealer.
I couldnt find a transmission dipstick on the 5th Gen to check how much tranny fluid i really lost, so now i have to go back to the dealer and tell them either to top it off, or, drain and replace all the tranny fluid.
Never going back to the dealer for an oil change.
I think my RCI Skidplates confused them on where the oil drain plug was. Why would they even touch my tranny. The tranny drain plug was loose, had to tighten it up.
*pissed*
Next time i go to my local mechanic for Mobil1 oil change or do it myself.
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 04:55 PM #2
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
the 5th gen has no transmission dipstick. they will need to do a fill and use techstream to check the fill level.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 05:07 PM #3
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Tow it
Have it towed on their dime and tell them you will call Toyota and report it.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 06:08 PM #4
Matze's Avatar
Matze Matze is offline
Real Name: Matt
Matze will become famous soon enough
Matze's Avatar
Real Name: Matt
On top off all the trouble I would cause at the dealership and a report to Toyota I would have them clean my driveway!
Get that notified by Toyota in case you have some trouble with engine or tranny down the road
Pretty sad that you’re not even save at the dealership - morons everywhere!
2020 black ORP
Matze is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 07:20 PM #5
t0y0ta4R's Avatar
t0y0ta4R t0y0ta4R is offline
t0y0ta4R is on a distinguished road
t0y0ta4R's Avatar
There are a number of individuals off Antman's oil change thread advising most not to use the dealer for the free oil changes. Some light reading if you have time: Oil Change 5th Gen: How To- LOTS of PICS! - Toyota 4Runner Forum - Largest 4Runner Forum
I'm in the market for a 2021 4R
Preference: 4x4 Limited in Magnetic Gray Metallic
Options: Sliding rear cargo deck
Accessories: All weather Floor Liners & Cargo Tray Package, Exhaust Tip Chrome and Mudguards.
t0y0ta4R is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 07:22 PM #6
samson904 samson904 is offline
samson904 is on a distinguished road
It's becoming increasingly difficult to find competent people anywhere these days. If you want it done right...
Sent from my SM-G975U using Tapatalk
samson904 is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 07:48 PM #7
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
new 4runner owners did drain the transmission. when doing the oil change.
now the drain plug on the engine is under the engine !!! very weird a Toyota floor sweeper messed with the wrong drain plug...
NOW over all the decades I do most all my vehicle work is, because they break stuff and they do not care..
a long time ago back in the 1970's I had firestone auto shop replace my transmission fluid/filter .. well the dum azz did not put the gasket on ? I looked under the car and a puddle of tranny fluid ..that job on a 1970 sedan was not complicated ..
todays world it is complicated and hard access to do work on vehicles.
your problem call them and tow it to the dealership .. report to Toyota that they failed to mess up your runner .. get documents to cover your azz.
catrains is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 09:16 PM #8
propain's Avatar
propain's Avatar
Thank you for contacting Toyota Motor Sales, USA, Inc. Your case is filed at our headquarters office under your name and file #***********.
If you have any further questions, please contact us at 800-331-4331. Our hours of operation are 7:00 a.m. to 7:00 p.m. CT Monday through Friday and 7:00 a.m. to 4:30 p.m. CT Saturday.
Told them I want the truck towed back to the dealer and fixed. Hopefully the dealer won't sabotage my 4 runner. It's bad enough they put in non synthetic engine oil when I been using fully synthetic oil, and loosened my transmission drain plug.
Let's see what the dealer offer's. I should get a call from them in the morning.
PS: off topic, I had new tires installed last week and I couldn't be more happy with the way they ride. 100% improvement over the Nitto Trail Grapplers.
Old 01-21-2020, 09:41 PM #9
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Damn sorry it happened. way too many stories like that. Not just Toyota! I can vouch Jeep and ford dealers have same darn problem! Had a ford dealer put close to 13 qts in my old truck, dumb chits
ForRun is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 09:52 PM #10
Mark4runnar's Avatar
Mark4runnar Mark4runnar is offline
Mark4runnar will become famous soon enough
dealer overhangs
I am sorry to hear this, but have several similar stories. I never take mine to a dealer unless it's work I can not perform.
Mark4runnar is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 10:12 PM #11
obxbird obxbird is offline
obxbird is on a distinguished road
One main issue is that they hire just about anyone to change oil and rotate tires. These are NOT Toyota or ASE certified techs... they get OJT when hired and put out on the quick lube line to change your oil.
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
obxbird is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 10:31 PM #12
AcrylicSauce's Avatar
AcrylicSauce AcrylicSauce is offline
AcrylicSauce is on a distinguished road
Damn that sucks, that’s why I do all my 4Runner’s oil changes myself.
AcrylicSauce is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 11:16 PM #13
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
You've got a list of mods a paragraph long and don't change your own oil? Drain plug, not a "lug nut".
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 12:04 AM #14
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
This thread is scary.
I had my first of a year of free services last month. I haven’t seen any oil in my driveway. Yet. However, the ditz behind the service counter tried to charge me for the service, even though I presented them the coupon upon check in. Hopefully the shop full of ditzes put in synthetic oil and not the oil and kitty litter on the floor.
I am older and not mechanically inclined, haven’t changed my own oil since the days when you opened a car’s hood and actually could seen an engine. Now I’m too arthritic to get down on my snow covered driveway and crawl around under my Runner.
My local Pennzoil dealer has been getting my business for years and the family has never done me wrong. Maybe I’ll skip going in for my next free service and go to my usual shop.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 04:35 AM #15
49Runner 49Runner is offline
49Runner will become famous soon enough
I think my RCI Skidplates confused them on where the oil pan lug was. Why would they even touch my tranny. The tranny lugnut was loose, had to tighten it up.
*pissed*
Next time i go to my local mechanic for Mobil1 oil change or go direct @ Mobil.
I have the RCI Skid Plate... there is literally “1” hole that gives you access to the oil plug and “1” access plate to the filter. I changed the oil today in my driveway in 15 deg/snow... it’s stunning that they screwed this up.
As everyone is saying, do it yourself. Get a 14mm deep socket, a 6” extension, go buy the oil filter tool from Oriely’s, pick up a plug gasket, oil and filter and spend 30 minutes doing the job right. You’ll be glad you did.
49Runner is offline   Reply With QuoteReply With Quote
change , dealer , fluid , oil , tranny
Did the dealership really change my oil?? dannyg 4th Gen T4Rs 26 03-08-2017 05:21 PM
Dealership Oil Change - Total Time? Jayhawk5G 5th gen T4Rs 28 04-12-2016 03:42 PM
Oil leak after dealership oil change MuddyButt 3rd gen T4Rs 14 06-04-2015 01:18 PM
Oil Change Price at Toyota Dealership ice2000 4th Gen T4Rs 26 06-19-2011 12:51 PM
Dealership Oil Change reds10 5th gen T4Rs 9 05-21-2011 07:12 PM
