Old 01-24-2020, 09:35 PM #61
BlakeA BlakeA is offline
BlakeA will become famous soon enough
Originally Posted by centuridude View Post
After a "Routine" oil change / tire rotation service, as I was leaving the dealership, the front-right tire came off. They FORGOT to tighten the lug-nuts!!
Fortunately the damage was minimal - they had to replace the TRD wheel because it was scratched on the inside. On the bright-side, I had them give me the "damaged" wheel and I plan on using it as a second spare for long off-road trips.
The dealer left loose lug nuts after a brake job on my old Gen 3. Felt weird driving it home and when I got in my driveway, I found the passenger rear tire with barely finger tight lug nuts. Wheel just flopping around. They comped the brake job by way of apology. They have also left skid plate bolts broken and loose.
I’ve got the two year Toyota care on my new 2019 (different dealer) that I’m going to take advantage of since my brother has used them for his Tundra for several years with no complaints.
I’ll still crawl under and check it out when I get home though.
BlakeA is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 09:53 PM #62
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
Crawl under and check it out at the dealership. It may be too late by the time you get home.
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 09:58 PM #63
radog radog is offline
radog is on a distinguished road
that toyota care is beautiful
radog is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 11:19 PM #64
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
The identical thing happened to my boss. He took his Tacoma (Tundra?) in for an oil change rotation to Koons Toyota in Tyson's Corner (Northern VA/DC burbs). At the first traffic light (within sight of the dealership), his driver's side front wheel came off. A cop was a couple cars behind him and started yelling at him to move his car (it was rush hour). He points to the front of his car with major'ish body damage and sitting on a rotor that is half folded under and asked "I'd love to. Why don't you help by lifting up the front of the car and I'll drive it over to the side of the road"
Koons ended up ordering him a new one (it was impossible to find a red manual tranny), gave him high retail on his and sold the new one at actual cost minus military discounts. I think he paid a couple of grand and got a two or three year newer car. They obviously gave him a loaner in the meantime.
I thought that was a one off, but yours is the third one I know of. The first was a brand new Jeep that made it a mile before the wheel fell off.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 12:45 AM #65
Blue 4ever Runner's Avatar
Blue 4ever Runner Blue 4ever Runner is offline
Real Name: Jim
Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light
Real Name: Jim
May I suggest we start naming these crappy dealers who this type of lousy work? It might be a bit of a heads up to other members and avoid some headaches. On the flip side, if anyone gets truly good service from a dealer that could be mentioned also. Just a thought.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
Blue 4ever Runner is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 01:47 AM #66
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
The closest Toyota dealer to me, where I bought my 4runner, is over an hour away in Lake Havasu City.
The only reason I might go there would be during spring break.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 01:49 AM #67
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
Over the 22 years I’ve owned my 3rd gen I’ve had a couple of issues with stealerships f’ing things up while doing simple maintenance.
Once they put 8 quarts of oil in my engine. There have been numerous times where I’ve seen the “tech” not know to remove the front skid plate in order to change the oil filter. And just recently I needed a new battery. However, replacing the battery sets off the alarm. The alarm is not an OEM. Between 1997 and 2002 Gulf States Toyota installed third party alarm systems in their vehicles. Anyway, over the years I’ve needed to replace my battery and different shops have done it no problem. But at Toyota of Boerne TX the tech can’t turn off the alarm. So what does he do? HE LITERALLY RIPPED IT OUT!! Yep. Put it in the passenger seat. Then my service rep told me since it was not an OEM alarm they could not reconnect it. I was pretty livid to say the least. Not only was the alarm system gone. But the doors no longer locked. I took some time to calm down and asked my service rep to please try and reattach the alarm system so at least my door locks would function. She agreed and they successfully reconnected the alarm.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 03:59 AM #68
yota1976's Avatar
yota1976 yota1976 is offline
yota1976 is on a distinguished road
yota1976's Avatar
Originally Posted by propain View Post
Dude, go to a Mobil1 and get it done there if you can't change it yourself.. This thread isn't meant to scare you but to create awareness. If you do a search on T4R you will see there are many mishaps at the dealership. But I think this one takes the cake. The only thing a dealer should do is recall work or something under warranty.
It used to be local mechanics were grease monkies and dealerships did quality work. Now it seems reversed.
I can do mechanic work. I just thought I'd let them change the oil because of the free 2 year service plan. I'll probably consider doing it myself now.
2019 TRD Off Road, Barcelona Red, Predator Steps, Sprint Booster V3
yota1976 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 12:58 PM #69
Mopar2 Mopar2 is offline
Mopar2 is on a distinguished road
I do all of my own maintenance.
Do not go to dealership for oil change!-img_2713-jpg
Mopar2 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 09:33 PM #70
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
The irony is that they piss test their employees too. I smoke every day and have never messed up any vehicle while performing maintenance. In fact I ran circles around my coworkers. I was so tired of dealing with morons that I quit after 21 years at the same place. Only stayed to get my benefits payed 100% for life. We should not be surprised, look at the idiots running this country. That should be enough evidence.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 11:38 PM #71
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
On my very first dealer oil change they overfilled the engine, over tightened the filter, and broke off the skid plate bolt. Service manager brought the tech in who worked on it (a grizzled old dude, not a young scrub) and he said straight faced “it was like that when he brought it in here”.
1000MPH is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 12:19 PM #72
Tuco Ramirez's Avatar
Tuco Ramirez Tuco Ramirez is offline
Tuco Ramirez has a spectacular aura about Tuco Ramirez has a spectacular aura about
Marijuana is a memory loss drug, so maybe you just don't remember...
When you have to shoot, shoot....don't talk.
#black4runnersmatter #myprodoesntclunk
Tuco Ramirez is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 12:05 PM #73
I have a memory like an elephant. No issues there. I could testify in any forum about how people love to spew their wisdom without having any experience. The courts are full of paid testimonials that send people to jail based on nonsense. It’s sad, but as long as they speak and dress well their believable.
2016 TEP
Old 01-27-2020, 01:19 PM #74
Apparently weed is the weakest thing you are smoking these days.
Old 01-27-2020, 02:17 PM #75
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Originally Posted by radog View Post
that toyota care is garbage
fixed
change , dealer , fluid , oil , tranny
Did the dealership really change my oil?? dannyg 4th Gen T4Rs 26 03-08-2017 05:21 PM
Dealership Oil Change - Total Time? Jayhawk5G 5th gen T4Rs 28 04-12-2016 03:42 PM
Oil leak after dealership oil change MuddyButt 3rd gen T4Rs 14 06-04-2015 01:18 PM
Oil Change Price at Toyota Dealership ice2000 4th Gen T4Rs 26 06-19-2011 12:51 PM
Dealership Oil Change reds10 5th gen T4Rs 9 05-21-2011 07:12 PM
