Old 04-10-2020, 12:59 PM #46
agentcross agentcross is offline
agentcross will become famous soon enough
Also, install was super easy if you read the doc carefully. A video guide would be more efficient. The bottom bracket on the doc shows slotted top holes for ladder mounting whereas mine came with normal holes. I would preferred the slotted holes to make fitting/alignment easier
agentcross is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 03:13 PM #47
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of
Official Vendor
Real Name: Cam
Glad it went well. We plan to make an install video as soon as we can get back to work! The slots were moved from the bracket to the bottom of the ladder instead, so you have the same adjustability, they are just hidden now.
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 03:37 PM #48
I figured the video would be coming once things are normal! Ah cool. I thought they might have originally been in both places. Wasn’t really an issue though. This look is probably cleaner anyways!
Old 04-11-2020, 10:11 AM #49
watchman1513 watchman1513 is offline
watchman1513 will become famous soon enough
Odd, mine has slots on the top and the bottom.
Black 2016 SR5 - Black Rhino Ark - TerrainContact A/T
watchman1513 is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 10:14 AM #50
I got mine yesterday, installed in about an hour as well. Only thing I think it was missing was some rubber on the ladder itself where it touches the vehicle. Those parts will definitely get some movement, rub, and eventually scratch up and rust. But we improvised, and put some pieces in the way.
Old 04-15-2020, 11:16 PM #51
316drew 316drew is offline
316drew is on a distinguished road
I am not the most crafty with tools. This entire set up will take approximately 45-60 mins. Great craftsmanship and directions that are easy on the eyes. From top to bottom I have one complaint. I wish there was extra hardware. Just in case there was a miscount at the warehouse. With that being said, I had each and every piece of hardware. Maybe that’s their secret to keeping their prices so low, keep a meticulous count of every piece.
316drew is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 10:05 AM #52
ProfessorP's Avatar
ProfessorP ProfessorP is offline
ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough
ProfessorP's Avatar
What did you use between the mounting bracket “hooks” and the hatch to prevent rubbing and eventual rust?
Wish I was having an easy go installing my ladder. I’m going to try a third time, but my top bracket refuses to stay tight to the hatch. I’m extremely anal and good with my hands and tool use. I followed the instructions, but I’m not having any luck. In the past I’ve installed the Victory winch bumper and Warn winch, Victory roof rack, Victory sliders (with KDSS), Victory Molle rear window panels and my Dobinsons lift plus years of working on all my cars, trucks and boats. This simple ladder install is kicking my butt!
ProfessorP is offline   Reply With QuoteReply With Quote
Old 04-16-2020, 10:32 AM #53
The 3M tape was so thick it just hovers over the lift gate. Initially, I pull the hooks tight over the top of the rear door and held tightly until I lowered the 3M tape onto the body. Once the tape was set, the thickness of the tape allows the hooks to simply hover over the rear door. Close but no contact.
Old 04-16-2020, 10:38 AM #54
Whatever the issue contact Corey. He will walk you through. I was very reluctant to drill into the body. This was one of the things that turned me off about the ladder assembly. I measured 4x, and I cut once. I was pleasantly surprised by the end result.
Old 04-17-2020, 11:05 AM #55
2chains 2chains is offline
2chains will become famous soon enough
Thanks for the post. Didn't realize that drilling was involved for this install.
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
2chains is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 02:24 AM #56
I used the edge trip that it came with. The instructions tell you to use it there. The only part I had to improvise was the the near bottom of the latter that touches the hatch right above the very bottom of the ladder.
Old 04-19-2020, 02:26 AM #57
Here are some pics for example. The left side isn’t touching so the piece is there just in case of rub.
Old 04-19-2020, 11:37 AM #58
ProfessorP's Avatar
ProfessorP's Avatar
Are you saying that you used two small pieces of the longer thin edge trim on the hatch edge under the two hooks on the top bracket?
Unless I’m reading the instructions incorrectly, they don’t mention using anything between the small hooks on the top bracket and the hatch.
Here’s instruction number 2:
“2. Cut the smaller edge trim in half and install it on the bottom edges of the top bracket. Place the 3M tape squares across the front-most section of the bracket and remove the masking film. Measure 4.5” from the far left edge of the rain gutter as shown. Making sure that the hooked portion of the bracket is wrapped down around the tailgate and pulled backward as tight as possible, stick the top bracket down with the tape. You will want to make sure the hooked portion hugs the tailgate as closely as possible, so that it does not hit the body when the tailgate is opened.”
The smaller edge trim is the shorter thick one and it goes under the two side edges of the top bracket. Mine came pre cut into two short pieces.
The longer thinner trim was meant to go under the bottom bracket to protect the hatch bottom edge. Mine extended well beyond the bottom bracket.
I didn’t put anything under the ”hooks” at the top.
Am I missing something?
Old 06-30-2020, 07:46 PM #59
stay_tuned stay_tuned is offline
stay_tuned will become famous soon enough
This is exactly what i was wondering about if anyone else had the same issue. I will have to go find something like this to use as well
stay_tuned is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 04:05 PM #60
Victory 4x4 Hatch Ladder Prototyping
any help would be great the passenger side hook rubs against the body on the inside curve.
does anyone else have this issue? i’ve pulled it as tight as it goes and stuck it but still seems to rub against the body which i’m sure will cause rust Victory 4x4 Hatch Ladder Prototyping
hatch , ladder , prototyping , rear , victory
Victory 4x4 New Product Prototyping (Armor & Accessories) victoryrunner 5th gen T4Rs 360 06-29-2023 01:56 PM
Victory 4x4 New Products/Prototyping Victory 4x4 Lexus GX470/460 38 07-14-2021 10:58 AM
Victory 4x4 New Products/Prototyping Victory 4x4 4th Gen T4Rs 149 05-18-2021 11:43 AM
C4 Hatch Ladder orcaTRD For Sale: T4R Items 2 11-24-2019 12:56 PM
