Old 07-07-2020, 04:14 PM #61
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of
Official Vendor
Real Name: Cam
Originally Posted by stay_tuned View Post
any help would be great the passenger side hook rubs against the body on the inside curve.
does anyone else have this issue? i’ve pulled it as tight as it goes and stuck it but still seems to rub against the body which i’m sure will cause rust Victory 4x4 Hatch Ladder Prototyping
This has only been an issue a couple of times. There is adjustability in the hatch hinges themselves and a range of tolerances for the gap at the factory. It seems like some at the far end (or beyond) of that range are close enough for the ladder to rub. You can loosen the hatch hinge bolts, pull the hatch out to the furthest point in the adjustment, and tighten them back up.
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 04:49 PM #62
stay_tuned stay_tuned is offline
stay_tuned will become famous soon enough
Is there any documentation on how to adjust that bracket as when i see it im not sure how i can pull the whole hatch outward with it open.
Has anyone else had this issue?
stay_tuned is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 05:44 PM #63
trd6209 trd6209 is offline
trd6209 is on a distinguished road
I had a similar install issue with mine and I found that I made the problem worse when I plumbed up the ladder. When I installed the ladder in place with the edge of the top bracket at 4.5 inches and pulled everything down tight I had no rubbing. In that position the bottom of my ladder naturally kicked to the right slightly. When I squared it up and bolted it in place, the top bracket twisted away from the hatch on the left edge and rubbed. I was able to get it to stop rubbing by adjusting the ladder in as tightly as it would go, allowing the tension between the top and bottom brackets to hold the ladder singly in place. If I could have done it over I would have left the ladder to fall naturally and bolted it in place. The lean wasn't that noticeable and it was very tight when I clamped it in place.
Sent from my Pixel 3 XL using Tapatalk
trd6209 is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 09:00 AM #64
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
It will help to have a second person to hold the hatch. Loosen the bolts while the hatch is open. Use a pry bar (with a towel around it to protect your paint) to move the top of the hatch out from the body and then tighten the brackets back up. As long as you have someone else holding the hatch, you can also unclip one side of the hatch struts if they are fighting against you.
@victoryrunner
Old 07-13-2020, 07:08 PM #65
tried that but still rubbing, so already on it’s way back sucks i couldn’t get it to work as i really liked the ladder
Old 07-14-2020, 01:05 AM #66
bboy626's Avatar
bboy626 bboy626 is offline
bboy626 is on a distinguished road
bboy626's Avatar
I reinstalled the plate within 24 hrs when I noticed slight Plate scratch on driver side. During the reinstall, remove old tape and reapplied 3M tape. Prior to laying the plate flat, Stick 6 cardboard pieces between the plate and the roof. This really helped push the plate to the position where visually, u can tell it’s where u want it to be (away from the roof). With cardboard in place press down to get tape to stick. It’s not daily driver so I let the cardboard in olds for 2 days to keep plate in place. I also made sure to pull the ladder away from hatch best I could before tightening the ladder to the lower plate. This is for a c4 ladder but I think the mounting solutions are quite similar so hope it helps.
bboy626 is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 08:33 AM #67
Off-Camber Off-Camber is offline
Real Name: Brandon
Off-Camber is on a distinguished road
Real Name: Brandon
I had the same issue. I reinstalled the top plate 3 times pulling it rearward as hard as possible during install but it kept rubbing on the right hook. My OCD kept kicking in until I finally tried loosening the hinges based on the above post as it sounded super easy. Unfortunately it only got worse to the point the entire hatch was scraping the body. I removed the ladder and tried to get it back to my original pre-adjustment witness marks and I never could get it back. The 4runner has been at the body shop for the past 3 days with them trying to re-align the hatch and fix the body scrapes but they can only get it marginally better. They still have a few other options to try (new hinges and dropping the headliner to adjust the bolts under the headliner), though.
I emailed victory and they were responsive. I sent some pictures to Chris but haven't heard back since the last correspondence. Having dealt with Victory on other parts I have every inclination they will help me out with returning the ladder.
I will never install a ladder again to any hatch on any vehicle I have, though. In retro I love the ladder and concept but feel like the hatch is not designed for a 200lb guy and a 30lb ladder hanging on it. I'm planning to pick up the left side swing out with ladder for their bumper as soon as I get this remedied.
Brandon
Off-Camber is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 06:01 PM #68
taxzz's Avatar
taxzz taxzz is offline
taxzz will become famous soon enough taxzz will become famous soon enough
taxzz's Avatar
I wanted to comment here after installing my ladder last week. This is for my 4th gen, but something everyone should be aware of.
First, Victory quoted 3-4 weeks and it took 10. Second, they forgot rubber feet, and two bolts/nuts/washers from the kit. Not really sure how that happened, but they have since sent those out.
Upon install all seemed well, but after having it on the truck for a few days I noticed that the 'feet' that held it to the top of the hatch had 'let go' and caused scratching as if the hatch was not adjusted appropriately. The hatch had plenty of gap, the issue was that the 'feet' had not been bent enough from the factory to adequately hold the ladder in place.
I took it all apart, hit the feet with a hammer once each to give them more 'grip', and all is working as it should be.
Unfortunately my paint is damaged, and if I had a 5th gen I'd be more upset personally.
How the 'feet' were after a few days.
2007 Limited V8 | Apache AX2 and Dobinson 3" lift
2004 Limited V8 | Dobinson IMS Long Travel 3″ lift w/ SPC UCAs | Yoko 35x12.5/17 | Rear Locker | Front LSD !!!!FOR SALE!!!!
2004 SR5 V6 | Sold
taxzz is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 09:28 PM #69
4Runner45768 4Runner45768 is offline
4Runner45768 is on a distinguished road
Victory Ladder
Thank you everyone! I read everyone's comments because I actually installed the Victory ladder today. By chance anyone who what the 2 round rubber bumpers are for that comes with the hardware ?
4Runner45768 is offline   Reply With QuoteReply With Quote
Old 08-13-2021, 09:20 AM #70
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
The rubber bumpers are used on the 4th Gen upper bracket. They aren't needed on the 5th Gen!
@victoryrunner
Old 10-01-2023, 09:34 AM #71
21runna_cario 21runna_cario is offline
21runna_cario is on a distinguished road
how do you install it without messing up your truck? any updated installation video?
top plate scrapes the body just like in the above
in tailgate , the big washers started morphing on the outside. thanks
21runna_cario is offline   Reply With QuoteReply With Quote
Old 10-01-2023, 05:27 PM #72
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
manufacturers these days expect customers to be their beta testers..ROFL
Just get something tried and true, like a gobi.
Had a c4 ladder then went to a gobi ladder, never looked back.
Old 10-01-2023, 05:43 PM #73
home depot sells ladders too. ya clowns
Old 10-01-2023, 05:56 PM #74
mrblah's Avatar
mrblah's Avatar
Old 10-03-2023, 02:48 PM #75
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
Reach out to customer service [email protected] if you haven't already and they can help you out! They'll get some photos from you to see what the issue is.
@victoryrunner
hatch , ladder , prototyping , rear , victory
Victory 4x4 New Product Prototyping (Armor & Accessories) victoryrunner 5th gen T4Rs 360 06-29-2023 01:56 PM
Victory 4x4 New Products/Prototyping Victory 4x4 Lexus GX470/460 38 07-14-2021 10:58 AM
Victory 4x4 New Products/Prototyping Victory 4x4 4th Gen T4Rs 149 05-18-2021 11:43 AM
C4 Hatch Ladder orcaTRD For Sale: T4R Items 2 11-24-2019 12:56 PM
