Old 01-31-2020, 04:44 PM #1
KF4R2011 KF4R2011 is offline
KF4R2011 is on a distinguished road
Lighting and Ranch Gates
Guys, I tried to see if anyone would/could do this and got mostly radio silence. I called some local stereo shops to see if they could do this and was told they weren't interested. I do a fair amount of towing and usually am prepping at night before going out the next day. I have to go through some manual opening ranch gates (at night) and am in need of a way to light up the area behind my 4R with the backup lights. I don't want external/removable units. After going through a gate or while loading the trailer I just want to have that rear area lit up. Does anyone have some ideas? Tonight I have to go through 2 gates to get a zero turn and they cannot be left open due to animals using the pasture... then I have to go back through the same 2 gates on the way out... at night... any help with a solution would be very appreciated.
KF4R2011 is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 05:42 PM #2
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
Why not something like these small Baja lights ? (or there are maybe hundreds of alternatives.)
LED Auxiliary Lights | High Quality LED Lighting | LED Lights Off-Road | Baja Designs
Install these in the rear, wire them to a switch added to your dash. I'm sure there are pictures of rigs here with such mounted, a little search might give you some good ideas.
Toffees is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 05:43 PM #3
keph13 keph13 is offline
keph13 is on a distinguished road
Both rear light assemblies are fairly easy to access behind panels. The safest option would probably be a double pole double throw relay, where one channel uses the NC terminal to keep the stock functionality, and the other channel uses NO to trigger the lights. Then you'd need to run wires up under the dash - people have used add-a-fuse to tap off the AUX fuse above the pedals, and you can buy switches that snap into the dash online.
Not knowing your level of expertise, let me know if you want me to go into more detail on any of the pieces.
EDIT: I guess you could also use a normal relay, with the stock wiring through NC and the same +12 signal going to the switch and the NO - that will keep from any weird loops happening. This was all assuming one side - you'd want one on each side. I've run wires across the top of the back, it's pretty easy - just pop the plastic fasteners in the headliner off, and potentially the trim pieces on the back piller - you'll have enough room to shove things around.
The mainentance doc that's floating around has connector layouts, if you want to try to build this as a pigtail that goes between the stock plug and the light - then it would be reversible if you sell it.
I might actually try to do this at some point, now that I've thought about it a bit. I'll post here if I do.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 06:29 PM #4
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Can you clarify what you mean by external/removable units?
An internally mounted led bar comes to mind, Mount it on the ceiling and crack the rear window when you flip them on.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 06:37 PM #5
@JSparky - want to maintain stock look... no addons if possible @keph13 - I work in a mechanical design department so I'm familiar with what you're saying.... I just don't normally do the soldering/wiring/practical side of the job.
Old 01-31-2020, 07:14 PM #6
JSparky's Avatar
JSparky's Avatar
Got it, so regardless of mounting location it’s really the wiring that’s the barrier?
Seems like there’s gotta be an independent electrician who can do this near you, especially if you provide a complete, fused and relayed harness.
For a single light the wiring is super simple. If you order from a reputable brand they’ll include a nice relayed wiring harness, although for a rear mount you may have to lengthen the leads (or specify a custom length).
Maybe give CE a buzz, I’ve worked with this group several times and I highly recommend them. Tell them what you want to do and they should be able to put together a custom harness. LED Light Relay Kits – CE Auto Electric Supply
This group should also work with you, never used them but I’ve heard good things, maybe others can chime in. They have OEM style switches for a clean install. Wiring Harness - Single Leg– Cali Raised LED
If you were in the bay area I’d help ya out, with all the parts this would be an easy install. Trickiest part would be deciding how to mount the lights to the interior of the ceiling. You’d have to pull the headliner down to see if there are any studs or brackets you can utilize. This sounds like a fun project!
Old 01-31-2020, 08:41 PM #7
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
Skip the relay and just use a simple diode to prevent any possible back flow to the reverse light controller while energizing the second switched wire. It’s probably not needed but it’s a super cheap part for some piece of mind.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 08:53 PM #8
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
I'm not sure that any lights the back of your 4R will help. Depending on the trailer, you may need lights on the back of that.
As I understand what you do, is drive up to the gate, open it (you need to light up the front), drive through, stop and close the gate (you need lights at the rear) and repeat at the second gate.
Disregarding your other desires (hidden, looks stock etc.), I'd think that you need some sort of a spotlight in the front and some light bar on the trailer.
If you agree with those "needs", then let's see if the collective group here an figure out how to hide them.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 09:56 PM #9
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
XTR LP REVERSE LIGHT SYSTEM HIGH OUTPUT LED BACK UP LIGHT
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 10:15 PM #10
Rightside Up's Avatar
Rightside Up Rightside Up is offline
Rightside Up will become famous soon enough Rightside Up will become famous soon enough
I would cut the bumper and put in small LEDs.
One towards the end of each bumper.
Also I imagine he needs the lights to make sure livestock isn’t going to
be heading out the gate behind him as he goes through.
2018 ORP Barcelona Red
Dobinsons 2.5”/1.5” lift with springs and shocks.
Diff. Drop.
Pro Comp UCAs.
RSG angled sliders.
Rightside Up is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 10:31 PM #11
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
I know you don't want external but these are tucked out of the way? Easy to tap the trailer hitch wires, comes on auto in reverse or at will with an extra switch. They also have a in bumper mount I've seen on a couple runners in this forum
ForRun is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 05:52 PM #12
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
Not trying to be sarcastic or an ass, but why not just keep it simple and get a headlamp for like $20.
I don't think you'd be able to mount something on the 4Runner that would shine bright enough to cast enough light over a trailer unless you get a rear facing lightbar. And unless the 2014+ reverse lights are better than my 2010's they will be worthless as task lighting.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 08:33 PM #13
When I have a trailer, it’s a flat utility type that only comes up maybe to the brake lights and is totally open. With or Without a trailer the reverse lights are plenty bright to help with illuminating the gate I passed though so I can reattach the chain. A headlamp could work for some things but it will not work when loading my 60” zero turn into the trailer at night. I need to see the deck as I load. I mow for a side job. So I work my day job Friday, that night I load up to mow.
Yes. Each time go through a gate it must be immediately closed in order to not let cows out. @ForRun the trailer would block those. The lights need to be at least at the level of the taillight assemblies
Old 02-01-2020, 09:08 PM #14
This is the setup.
Lighting and Ranch Gates-d151c5a7-c36b-415d-b0ab-4357caca02f0-jpg
Old 02-01-2020, 09:28 PM #15
cb1111's Avatar
cb1111's Avatar
This is the setup.
Doesn't everything fall out?
area , due , gates , night , ranch
FS: 4th Gen V8 Gates timing belt kit $100 stir_fry_boy For Sale: T4R Items 3 03-30-2017 11:47 PM
FS: 4th gen V8 BNIB Gates Timing Belt Kit blackoutt For Sale: T4R Items 4 08-16-2016 08:34 AM
oem vs gates timing belt..? kennyb3030 3rd gen T4Rs 5 12-19-2009 08:53 PM
Shame on Prof.Gates Thai Off Topic 16 07-31-2009 09:03 PM
