Old 01-24-2020, 11:31 AM #1
obxbird obxbird is offline
obxbird is on a distinguished road
**Problem Solved* front end metallic clanking sound
Several threads have been posted here about that "clanking/metallic sound" coming from the front end. Mine ended up being LCA lower bolts not tightened to spec. Service manual states 129 pounds of torque... After the stealership had to replace my p/s LCA under warranty because of a stripped out eccentric bolt, which requires it to be realigned. They apparently didnt tighten up the lower bolts to spec. I had only about 80 pounds of torque on these bolts both d/s and p/s. Tightened to spec and the clank is gone. Problem solved.
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
obxbird is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 05:40 PM #2
Globetrotter78's Avatar
Globetrotter78 Globetrotter78 is offline
Globetrotter78 has a spectacular aura about Globetrotter78 has a spectacular aura about
Soooo much truth to this... Ive encountered several occasions over the years that a dealer under or over torqued (thus stripping) various parts on my vehicles.
**Problem Solved* front end metallic clanking sound-okay-say-tor-tor-fque-enb-spec-spec-67723285-jpg
*2018 White SR5 4x4, Icon 2.5 Exten Travel w/ res, JBA High Caster UCAs, 1.25 Spidertraxx, SSO Sliders and Bumper (on route), Icon Rebounds and 285/70 Falken Wildpeak A/Ts
*2013 Maserati GranTurismo Sport
*2013 Fiat 500 Abarth- the rocket powered go-kart!
Globetrotter78 is offline   Reply With QuoteReply With Quote
bolts , end , front , p/s , spec
Creaking/Clanking Sound Coming From Front End jordan_tm 5th gen T4Rs 18 11-16-2017 01:08 PM
Metal clanking sound on start up. Tucson4runner 3rd gen T4Rs 57 06-24-2016 12:01 AM
clanking rattling window solved Hongster 4th Gen T4Rs 0 09-10-2015 01:11 PM
Clanking sound from front end santanvalleydirt Classic T4Rs 19 08-19-2015 09:52 AM
