Old 01-24-2020, 12:01 AM #1
delloro's Avatar
delloro delloro is offline
delloro will become famous soon enough delloro will become famous soon enough
delloro's Avatar
What is this part and can it be removed?
It's in the rear spring. Is it a bump stop?
I am putting aftermrket rear springs in this weekend, not sure if this part is still needed.
48302-35050 - Toyota Parts Deal
delloro is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 12:25 AM #2
spartacus's Avatar
spartacus spartacus is online now
spartacus is a jewel in the rough spartacus is a jewel in the rough spartacus is a jewel in the rough spartacus is a jewel in the rough
spartacus's Avatar
[url=https://www.toyotapartsdeal.com/oem/toyota~spring~sub~assy~hol~48302-35050.html?Make=Toyota&Model=4Runner&Year=2015&Submodel=&Filter=()&Location=rear-spring-shock-absorber,,48302]48302-35050 - Toyota Parts
It's the rear spring seat where the spring meets the frame it sits between the rear coil and the metal perch. As far as I know you would need it for after market springs as well.
spartacus is online now   Reply With QuoteReply With Quote
Old 01-24-2020, 01:06 AM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is online now
daytonaviolet is a jewel in the rough daytonaviolet is a jewel in the rough daytonaviolet is a jewel in the rough daytonaviolet is a jewel in the rough
Itís also dampens the metal to metal noises
daytonaviolet is online now   Reply With QuoteReply With Quote
Old 01-24-2020, 01:52 AM #4
delloro's Avatar
delloro's Avatar
I cut the top off of mine to install airbags.
If they don't function as bump stops, why are they so tall?
Old 01-24-2020, 04:36 AM #5
02SE 02SE is offline
02SE has a spectacular aura about 02SE has a spectacular aura about
When they started installing them in the 3rd gen 'Runners, the idea was that it acts as an overload spring of sorts. The idea was to lessen the sag when heavily loaded. You can remove it if you want.
02SE is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 09:41 PM #6
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
These are Toyota Rear Spring Upper Isolators (Original Equipment).
Original Equipment Toyota Upper Spring Insulators (SPRING SUB-ASSY,). Used to delete the Air Suspension bags and replace with traditional Coil Springs. Not needed if you are putting on coil springs.
Genuine Toyota 48302-35040 Spring Seat Sub-Assembly
Amazon.com: Genuine Toyota 48302-35040 Spring Seat Sub-Assembly: Automotive
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. Youtube Chan flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
needed , part , rear , removed , weekend
Removed shelf, part number needed.. Hailmagnet 4th Gen T4Rs 2 09-04-2018 09:18 PM
Removed Crossbars, removed caps too! rktroutbum 5th gen T4Rs 12 11-11-2015 07:24 AM
Roof Rack Removed- OE filler plate part number? PAULUNM 4th Gen T4Rs 3 11-09-2012 02:04 PM
Was that post related to welding a cast iron part removed? jow 4th Gen T4Rs 0 11-20-2011 04:06 PM
