Old 01-24-2020, 11:05 AM #1
propain's Avatar
propain propain is offline
propain is on a distinguished road
propain's Avatar
Question Spacer behind Front Lower Control Arm looks like it has a gap. Normal?
When im under the runner, i usually look all around for anything out of place. I noticed this a while ago but really didnt think it was a big deal, or is it?
The washer attached to the front passenger side, back of the lower control arm seems like it has a gap in it. Is it a problem? Water will enter and rust the lower control arm from the inside out? Should get it fixed? or, not a problem?
The driver side washer on the LCA seems to be sealed a little better.
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
propain is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 11:56 AM #2
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
It's normal. That is how the factory bushings are.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 01:07 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
If you have never had those adjust bolts/sleeves out and you are still able to get them out, good idea to take them out, grease them up good and reinstall or you'll be cutting them off someday when they can't be adjusted for alignment because they are rusted in place.
At least true on 4th gen.
Old 01-24-2020, 01:50 PM #4
propain's Avatar
propain's Avatar
Good idea. I do usually spray the bolts and inside that gap with silicone based spay this way it don't rust out.
This spring I may get the whole under carriage rust proofed with either powder coating or use the Rust-Oleum Rust Reformer which instantly converts rust to a protected paintable surface first then use the Rust-Oleum Undercoating Pro Grade Rubberized Black spray.
I should of done this as soon as I bought the runner, but rust isn't too bad so far.
arm , control , lower , side , spacer
WTB: 3rd Gen Front Lower Control Arms LCA CB3G_GM Want to Buy/Trade 10 10-29-2020 07:55 PM
SOLVED: Is This Normal for Lower Control Arm? 4Runner4Leon 3rd gen T4Rs 44 11-26-2019 06:25 PM
Rear lower control arm bushings. Normal movement? 99Runnr 3rd gen T4Rs 0 01-06-2016 06:48 PM
Need front lower control arm!!!!!! richyrich307 Classifieds - buy & sell (no commercial ads please) 0 01-23-2011 11:48 AM
Front looks lower than Rear... Normal ? AlphaQup 4th Gen T4Rs 7 04-27-2006 12:12 PM
