Originally Posted by Matteblack
I am looking to sway a 17x8 wheel with 10 offset to the same size but with 15 offset. I have a 3" lift with 285/70/17 tires and I'm wondering if the tires will rub on the UCA's? Thanks in advance!
I think you'll just have to measure and see. Do you have 5mm between your tires and your UCA? If not you'll rub. If you do all good
