Old 01-24-2020, 03:15 PM #1
FamousAv8er's Avatar
FamousAv8er FamousAv8er is offline
FamousAv8er is on a distinguished road
Non JBL w/Nav Rear Speaker Voltage
Im to troubleshoot my system. Could anyone please tell me the output voltage I should be seeing for my left and right rear door speakers (+ & -)?
I have a non JBL with Nav.
Daily Driven '17 T-Force T4R - Baja Flat Rack - 5100s
odo: 80,000
FamousAv8er is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 03:34 PM #2
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
There is no "set" voltage that speakers should see. They'll see voltage when they need to play sound.
llDemonll is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 03:46 PM #3
Im referring to the voltage (possibly range) I should be seeing if I test the speakers incoming wire.
for more information Im troubleshooting a powered sub that taps into the rear door speaker wires.
odo: 80,000
Old 01-24-2020, 04:23 PM #4
that's a really odd way to set up a subwoofer. it should be on it's own channel and not adjustable based off the front/rear fade of the head unit
Old 01-24-2020, 04:27 PM #5
This is a powered sub so not a standard setup (Kicker HS8) but thank you for the response.
odo: 80,000
Old 09-07-2021, 06:17 PM #6
RichRebel RichRebel is offline
RichRebel is on a distinguished road
fwiw i have a powered sub power by power inverter and tapped into rear speakers
for audio and sounds great. Only wish I could get 400 watts from inverter so I could use a larger sub.
RichRebel is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 01:34 AM #7
4Rums 4Rums is offline
4Rums will become famous soon enough
To get any consistent (and relevant) values, you should specify the test tone to use (60 Hz? ) and what "volume" should you set in the head unit. The voltage will increase as you turn up the volume. I don't have a stock system, so I can't help you.
4Rums is offline   Reply With QuoteReply With Quote
Old 11-10-2021, 10:32 PM #8
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
It sounds like something we used to call a "Passive Subwoofer" system for home audio.
Montego Murph is offline   Reply With QuoteReply With Quote
Old 11-11-2021, 12:47 PM #9
Ripper238's Avatar
Ripper238's Avatar
Non JBL still has a powered amp for the rear. So be cautious.
I had to completely re-due my system because that hidden amp was causing all kinds of issues.
Old 11-11-2021, 02:00 PM #10
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
What year did you run into this? I didn't run into any issues with my 17 and I have the premium (Non-JBL) sound with the extra speakers all powered off the HU
Old 11-11-2021, 03:44 PM #11
Ripper238's Avatar
Ripper238's Avatar
2019 Off Road Premium. I tried a AX-DSP to drop down the power to my new amp but due to the higher power of the rear stock amp it caused tons of issues.
They sell a harness for the rear that will correct the over power issue from the rear amp.
door , jbl , rear , speakers , voltage
Rear Door / Rear Hatch Speaker Adapters ForeRunnerSi 5th gen T4Rs 5 02-21-2018 08:49 AM
Rear window, rough idle, low voltage farmerjon 3rd gen T4Rs 4 12-13-2016 11:28 AM
5-1/4 Rear Speaker Install - How To snowninja 3rd gen T4Rs 7 02-03-2016 11:05 AM
Some Help With Rear Speaker Install... LetsGoHokies! Engines / Suspension / Wheels / Tires / Audio / Accessories 6 07-05-2007 11:39 PM
rear speaker replacement medium pimpin Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-08-2006 10:37 AM
