Old 01-25-2020, 01:25 AM #1
petron5000 petron5000 is offline
petron5000 is on a distinguished road
Strange Power issue when starting.
So here’s a weird one on my 5th gen.
If I push the push button start all the way down and hold it, my 2012 Limited starts.
If I push it in but don’t hold it, like for accessories, I lose all power and I can’t push it again to start or even power the radio.
Now, if it wont power up and I open the hood and jiggle the positive terminal, I hear a click and the car gets power again. Clock resets to 1:00 and I can start the car again.
Battery is new. I do have a pedal commander and a hardwired radar detector but I don’t see how they’re causing anything.
petron5000 is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 11:21 AM #2
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Sorry no help other than clean, rough up (ie sand with coarse grit emery cloth) and tighten the battery terminals...
but resident e-wizard @rigtec may have an answer, he even has a 2012 Limited.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 04:04 PM #3
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Hi petron,
At first glance of your description of the trouble, I looks like one of the POS power lines are loose e.g., Battery POS terminal, or the other-end at the Alternator output cable/term, or at the Main fuse box under the hood; either the feed near the master cylinder, or coming out twds the battery... so there're four connections that could potentially be loose!
I would check those FIRST because just by you touching the POS cable, the trouble goes away; which involves all connection points that I've mentioned! If you check those 4 points and find nothing unusual, Next we pull the Push-Button Start trim panel out to examine the connections, and test the switch...
...no need for alarm, it just snaps out, IIRC, it's a part of the "Party-mode" button trim panel... I've had that out before, and it's no biggy! Be sure to come back and let us know what you find out after analysis! ...and thanks @jrandom for remembering me; you're very thoughtful! 'Best to you ALL'
rig, Cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 08:13 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
After reading this, I thought I'd mention another possibility that I've experienced. That is, each end of each connection is really two connections and therefore 2 places that can be the cause of the problem.
By that I mean each cable end has a terminal or lug bolted or crimped on (one connection) that is then connected to a battery post, alternator terminal, etc. (second connection). So you could have that terminal end properly connected to the battery post; but have a loose crimp right behind it where the cable connects to the terminal. Wiggling this would create the results mentioned above.
To check for this, you can disconnect from the battery, alternator, etc. and twist and pull on the crimped/bolted contact and see if it moves. Also check for corrosion that can wick under a loose or poorly attached contact.
If you end up replacing a length of cable, make the new section a little long; so you can re-terminate if necessary. 2 or 3 extra inches won't really make any electrical difference.
Old 01-25-2020, 08:38 PM #5
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
G'day "A-Team"
I know this is NOT directly relevant to petron5000's electrical issue, but I've covered sooo much of our Gen-5 electrical systems across time, that I thought to include this thread here because it covers much of the electrical theory that we "DIY'ers" Must deal with on a daily!
Having said that, I'm leaving this link here for anyone who may find it useful at some point in their travels and adventures in the future; "See below":
4Runner alternator upgrade (gen 5)
Hoping some may find this data useful!
rig, Cheers!
Old 01-28-2020, 01:37 AM #6
Somehow the positive battery terminal screw was loose. Turned it with a wrench about 4 times and no more issues!
Old 01-28-2020, 10:35 PM #7
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Now that's what I'm talkin' bout petron5000, Good job! 'Best'
~rig~ Cheers!
Old 01-28-2020, 10:48 PM #8
jrandom's Avatar
jrandom's Avatar
Simple fixes are the best fixes
2013 TE w/ KDSS Nav
don’t , hold , power , push , start
1997 4Runner SR5 with strange starting "issue" Reinout 3rd gen T4Rs 9 12-17-2019 12:43 AM
Strange starting problem PLEASE HELP! fxfourever Classic T4Rs 0 05-15-2014 03:36 PM
a strange kick when starting to drive gsnake 4th Gen T4Rs 14 08-11-2010 02:36 PM
Strange not starting...advice please lngbrdnpwdr Classic T4Rs 6 06-18-2007 08:42 AM
Strange Starting Problem Herd72 Problems & Warranty Issues 1 08-07-2005 04:36 PM
