Old 01-25-2020, 07:26 PM #1
X29 INC's Avatar
X29 INC X29 INC is offline
X29 INC is on a distinguished road
X29 INC's Avatar
FrontRunner Quick Release Mount On Prinsu Rack
I searched and searched this topic till I grew old and weak, so I decided to post this.
When I called FrontRunner on Black Friday, I was told their quick release mounts weren't compatible with Prinsu's rack. While this is true with their factory screws, I decided to source my own bolts/washers/nuts to find a way.
FrontRunner Quick Release Mount On Prinsu Rack-img_6317-jpg
X29 INC is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 07:29 PM #2
X29 INC's Avatar
X29 INC's Avatar
Close-Up
FrontRunner Quick Release Mount On Prinsu Rack-img_6320-jpg
Old 02-19-2020, 02:09 PM #3
MattAK's Avatar
MattAK MattAK is offline
Real Name: guess..
MattAK is on a distinguished road
MattAK's Avatar
Real Name: guess..
Thinking of getting these and adapting them to mount to my Victory4x4 rack. How long are the brackets? Need to know how close the rails on the rack need to be so I can measure to see if I can get my rails close enough to each other.
Thanks!
'08 V8 Sport Galactic Gray
'16 TEP Magnetic Gray "Kylo" - SOLD
'01 SR5 Thundercloud Gray - SOLD
'94 SR5 Dark Blue Pearl - SOLD
Originally Posted by RysiuM View Post
I just look at them and say: you have no absolutely slightest idea what are you talking about. This is 4Runner.
MattAK is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 03:52 PM #4
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I wonder if the spacings on my SSO rack are close enough to do the same. I built a hoist/winch set up to easily get the tent up and down, but the factory attachments are absolutely garbage to try and use.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 08:52 PM #5
D1105 D1105 is offline
D1105 is just really nice D1105 is just really nice D1105 is just really nice D1105 is just really nice
I thought about those but I figured getting two extra crossbars would be easier. Plus the weight of the RTT is distributed to all the existing crossbars and the RTT is mounted as low as possible.
****EDIT**** I also sanded off about 2-3 mm from the crossbars attached to the RTT so it can just drop in without having to loosen the other cross-bars.....
Sent from my iPhone using Tapatalk Pro
17 TRDOR | Metal Tech OPOR sliders | Summit Wheels | Wildpeak 285/70/17 | 5100's / C59-302 w 1/4" plate driver's side / C59-505 w/ 10mm packer | Prinsu full rack/GOBI ladder | C4FAB lo-pro bumper w/high clearance | Sprint Booster | RoofNest Falcon RTT | Ellis Precision knobs | BPF molle panel | Rago center console molle
D1105 is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 10:36 PM #6
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Are these supposed to be mounted to the bottom of the crossbar, leaving all the weight on a few 1/4-20 bolts? I would think mounted to top would be the correct way, then the bolts only purpose is to keep them mounted in same spot.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 12:08 AM #7
MattAK's Avatar
Real Name: guess..
MattAK's Avatar
Real Name: guess..
One would assume so. If they fit between my cross bars then I figure I'll just get out the ol' drill press and make the correct holes to attach it on the top.
Old 10-11-2020, 12:33 AM #8
X29 INC's Avatar
X29 INC's Avatar
I believe you can do it either way, but I wanted to keep it as low profile and sleek as possible. I still haven’t had any issues with mine and the weight has never been an issue.
It’s probably just preference, although mounting it on top would definitely be the safer way to go.
Old 10-12-2020, 11:31 PM #9
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
Technically you can but after owning them when we had
our RTT on the Frontrunner rack I personally would not mount them below. The extra 1” of non-low-profile savings doesn’t seem worth the chance (especially since we had 200+ lbs of tent and a family of 4 sleeping in it).
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 02:53 PM #10
trailracing trailracing is offline
trailracing is on a distinguished road
Quick release mounted to top of Prinsu Rack
I added the Front Runner quick release to my Prinsu rack today. Had to buy new carriage bolts to fit the Prinsu track but it was very simple to setup. I installed a hoist in the garage to hold my Roofnest Falcon tent. I am able to easily take the tent on and off without a second person. I’ll post pics if I can get the files sizes small enough to satisfy this app.
trailracing is offline   Reply With QuoteReply With Quote
Old 11-23-2021, 11:54 AM #11
BigOleTree BigOleTree is offline
BigOleTree is on a distinguished road
So tired of fussing with my RTT hardware. Thought about spacers but even then, the time it takes to get everything hooked up is a massive PITA. Been thinking of getting these quick release mounts to use with my LFD crossbars. Seems like it would generally work without too much modification.
Has FrontRunner updated the design since OP's post? Looks like these would mount parallel to a cross bar instead of perpendicularly.
Quick Release Tent Mount Kit - by Front Runner | Front Runner
BigOleTree is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 12:30 PM #12
X29 INC's Avatar
X29 INC's Avatar
One of my buddies just bought a Prinsu rack with the Gen 2 Front Runner quick release mounts. The new version of the mounts need to be mounted on top due to the design. I’ll post additional pictures of how we made it possible. All you need is eight (8) “1/4-20 standard T-Nut & 1/2” screws” (plus washers). The cost $4 + $5 shipping. Stay tuned.
(COMBO-010-D) 1/4-20 Standard T-Nut & 1/2″ Screw | TNUTZ
decided , frontrunner , quick , rack , release
Prinsu Rack Hi Lift Jack Mount XPdriven Off-Roading 4 08-20-2023 08:47 PM
DIY Easy-removal/Quick release RTT bracket/mount ideas pheelmeh 5th gen T4Rs 11 06-05-2022 04:15 PM
Just a quick prinsu rack rant Jasonredwood 4th Gen T4Rs 10 09-03-2017 12:02 PM
jack mount for Prinsu roof rack Dorobuta General Discussions 2 06-27-2017 12:08 PM
Frontrunner Rack with T-Slot lightbar mount? TerraCrawler General Discussions 0 06-16-2017 04:19 PM
