Old 01-25-2020, 10:54 PM #1
scratchhax scratchhax is offline
scratchhax has a spectacular aura about scratchhax has a spectacular aura about scratchhax has a spectacular aura about
TIL my 3rd brake light flashes and other fun facts
My wife was following me home tonight and asked me "what are you doing to make your brake light flash that way" which of course immediately had me imagining bad ground wires, dying relays or loose bulbs. Turns out the 3rd brake light flashes 4 times before coming on solid in my 2019, I had no idea. That got me thinking about other little quirks and tidbits that I've been discovering on my rig since I bought it in August and thought it would be fun to share a new 4runner owners "huh, that's interesting" list.
1. That brake light flashes. nifty!
2. You don't have to hit the brakes to start the car, take it out of gear or really for any reason beside stopping the vehicle.
3. The ebrake is it's own set of drum brakes. Maybe this is more common than I know, but it's new to me.
4. The car isn't a hermetically sealed rolling computer, you can actually do things like (gasp) replace the radio and still be able to control your air conditioner!
5. The fender liners can make sounds that lead you to believe that you either have marbles in your head liner or you are receiving alien transmissions on your dashboard speakers.
6. If you don't have the gas cap perfectly sealed, the computer will disable traction control, MPG economy display, light up damn near every light on the dashboard and in general do everything to make you believe that you just killed your new car.
7. Somehow, the entire body and interior seem to be held together with only pop clips and nothing rattles or falls off. Seriously, how in the hell did they do that?
8. In general, there is a single wire you can tie to ground to override almost anything. Want to run your inverter at 400w all the time ? ground a wire. Want your locker available all the time? ground a wire.
9. I thought I would miss all the driver assist features that our forester has, but the only one I really miss is auto headlights. I'm so used to it that I've become the jerk you flash to let him know he's driving in the dark.
Overall pleased as punch with this little rig, GG toyota!
scratchhax is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 11:46 PM #2
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
The 3rd brake light flasher is an aftermarket device that your dealer must've installed. It's not a standard feature from the factory. My '19 TRD ORP does not do that.
There should be a brake shift interlock that prevents you from shifting out of park without pressing the brake pedal. It is a safety feature. I just checked mine to verify and yep, I can't shift out of park without pushing on the brake pedal.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 04:40 PM #3
well this just got weird then. I'm a 19 ORP straight off the showroom floor...
Old 01-26-2020, 07:57 PM #4
Dynamo's Avatar
Dynamo's Avatar
The 3rd brake light flasher is one of those things like pin stripes, window tint, and protection packages that some dealers will put on every vehicle they receive into inventory before it is sold.
2019 TRD ORP
Old 01-26-2020, 08:14 PM #5
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
^This.
To the OP: your truck didn't leave the factory that way.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 09:18 PM #6
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
OP- where did you buy your 2019?
Where I am the Southeast Toyota Distributor sticks all sorts of crap on and charges big time for it.
For example mine came with 2 Iphone charging cords, USB C cord and a cig lighter USB charger for $73. I don't have an Iphone.
All in all they stuck $3500 worth of mostly crap on it, I would have declined if I could.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 10:20 PM #7
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Do none of the 5th gens have auto headlights, or just some trim levels? Could've sworn my '03 had them, know my 07 GX does. Even my 00 Camry did actually, weird they'd drop that.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 10:56 PM #8
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Oh, and just for informational purposes, the flashing third brake light is a violation of Federal Motor Vehicle Safety Standards 108 and the dealer can be fined under 49 U.S. Code § 30165 for installing that.
The definition under the regulation is as follows. Bolding is mine:
High-mounted stop lamp means a lamp mounted high and possibly forward of the tail, stop, and rear turn signal lamps intended to give a steady stop warning through intervening vehicles to operators of following vehicles.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 10:58 PM #9
cb1111's Avatar
cb1111's Avatar
Just some trim levels
Old 01-26-2020, 11:01 PM #10
[email protected] Evan@B.I.B is offline
Evan@B.I.B has a spectacular aura about Evan@B.I.B has a spectacular aura about
Oh god..you again???? Take that moral high ground out of town already.
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
Evan@B.I.B is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 03:27 PM #11
cb1111's Avatar
cb1111's Avatar
And you can stick your head in the ground and then act like an ass when you get pulled over for something.
Old 01-27-2020, 03:42 PM #12
I welcome interaction with law enforcement! I a lot of my friends are LEO's. I am fully aware of any real or conceived illegality of things I do. Doesnt mean I act like an ass. If I get cited for something I have done.. I take the consequences of my action. We dont need someone spouting off on every modification like you are some saint saving us from ourselves. Get over yourself... you dont matter that much and no one cares. Same as I dont matter much and no one cares about me. This is an auto forum on the internet....
Old 01-27-2020, 03:51 PM #13
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
My dealer installed one of those flashing rear lights on my Limited. I bought used but the dealer installs them on all their cars. They actual tried to get me to pay for it, pfft.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 05:21 PM #14
spartacus's Avatar
spartacus spartacus is online now
spartacus's Avatar
Some of us like knowledge. That's why we are on this forum. Thanks
spartacus is online now   Reply With QuoteReply With Quote
Old 01-27-2020, 09:51 PM #15
cb1111's Avatar
cb1111's Avatar
Thank you for reading my post in the way it was intended.
The OP believed that his new car had a hidden feature. Now he knows that the feature no only isn't stock, but may also cause him to get a ticket or fail inspection (if his state requires inspections).
What he (and anyone else) does with that information is up to him (them).
brake , car , ground , light , wire
Turn signal light clicks rapidly but no light flashes Cumby Problems & Warranty Issues 1 02-19-2016 12:26 PM
Brake warning light flashes intermittently Boomer8404 Classic T4Rs 6 06-08-2013 12:31 AM
Air Conditioner light flashes sundog 4th Gen T4Rs 2 05-13-2009 09:22 PM
AC light Flashes PolkManiac Problems & Warranty Issues 1 10-08-2007 05:19 PM
E Brake light intermittently flashes MomsGreen95 Classic T4Rs 4 12-29-2005 02:04 AM
