01-26-2020, 07:21 PM
Transmission Cooler Line / Winch Mount
Hey guys, working on installing a BudBuilt hidden winch mount on my ‘12 Trail. See pictures below, can someone confirm that the line running though the middle is a transmission cooler line. If it is, any reason I couldn’t replace the metal line with rubber? Thanks for the input guys!
'12 Trail
Icon Stage 4 Billet
Stealth 6 Wheels with KO2's
Sliders
01-26-2020, 08:10 PM
Yes, that's a coolant line. Replace it w/ rubber.....why? Is it in the way? When installing my SSO low pro bumper I just slightly bent/moved it so it did not interfere w/ my bumper.
-Chris
'19 Pro in Voodoo Blue -- Xenondepot HIDS
285/70/17 KO2s -- ToyTec Boss Aluma 2.5 Performance Lift -- FR roof rack
SSO sliders/Low-Pro bumper/high angle clearance & Exp-One rear bumper
instagram: @adventureswith6
01-26-2020, 10:39 PM
...I believe the hard line going across the front is the power steering 'cooler' line, and not an AT cooler line. On the 4Runner, the AT cooler is integrated into the radiator.
Replacing the hard line with a flexible hose could lead to problems with the power steering fluid temps. Yes, that's really a thing.
What is this???
Good luck
2023 Lexus GX 460 Premium
Sold - 2014 LE Barcelona Red
01-27-2020, 07:42 PM
I'm getting ready to install a similar bumper by Victory 4X4.
Since the line connects to hose on each end, my plan is to just loosen both ends and the brackets and rotate it up... Worst case replace it with a new hard line bent to clear a winch. I would keep it hard line ether way to protect from impact from road debris..
2017 Toyota 4Runner TRD Off-Road Premium, Dual Battery with Blue Sea Switch, 2" Lift with Eibach Coilovers & ICON 2" Rear Springs, GOBI Stealth Cargo Rack, BFgoodrick KO2 Tires, weBoost Drive 4G-X OTR 470210 Cell Phone Signal Booster, Goose Gear Rear Plate, ARB CKMTA12 On-Board Twin Air Compressor, ARB Differential Breather Kit, Yaesu FT-891 & ICOM IC-2730A Amateur Radio Transceivers, Victory 4X4 Blitz Bumper and HF APEX 12,000 lb Winch.
01-28-2020, 08:45 PM
Great idea! Thank you, I will look into making a new piece. I am going to try flipping it around first, pushing it up or bending slightly will not allow clearance of my winch.
'12 Trail
Icon Stage 4 Billet
Sliders
09-25-2020, 11:21 PM
Did you ever do this?
Also, I installed my winch today with the SSO hybrid bumper, and it's touching that line. I ziptied a bit of drawer liner around the tube and it's gently leaning against the solenoid of the winch.
Looking for options, but if the line doesn't get too hot (i'm reading like 120 degrees or less), it's probably not a problem.
Thoughts?
09-26-2020, 02:46 AM
Thoughts?
That be a power steering line if I can recall, I just bent mine away. Originally it was leaning on the control box but never had any issues. I can take pics of it later. I have since relocated the control box for accessibility.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
09-26-2020, 09:40 AM
Real Name: Dave
Real Name: Dave
No need to overthink it - just bend it slightly out of the way. My build thread as pictures.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
09-29-2020, 10:44 AM
If you can't bend it out the way enough, 4x4 labs makes a real cooler to put in its place. It is a "cooler" for the power steering so don't just replace it with hose.
Power Steering Cooler kit – 4X4LABS
TRD OFFROAD PREMIUM WITH SOME STUFF BOLTED TO IT
My Fuelly Log
09-29-2020, 11:28 AM
Thoughts?
You'll be fine. I zipped some old motorcycle innertube around it, put a old Tacoma mudflap on top of that, and then spilt my winch so the control pack is actually riding on top of the line. No issues.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
02-27-2021, 12:23 AM
Running into similar issues with my SSO slimline bumper on my 21 4 runner. I tried to bend the brackets for the cooler line but it still rubs against the winch. I’ll send some pics to the yota dealership in town and ask if they think it’s an issue. I might buy longer soft tubing to extend the height of the cooler tube and mount higher. All I need is 1 inch of clearance...sigh
02-27-2021, 01:54 AM
You need to bend the hard lines below the rubber hoses - pickup a brake line tubing bender to prevent kinking the tube when you bend it.
