Old 01-26-2020, 07:21 PM #1
G-Cam G-Cam is offline
G-Cam is on a distinguished road
Transmission Cooler Line / Winch Mount
Hey guys, working on installing a BudBuilt hidden winch mount on my ‘12 Trail. See pictures below, can someone confirm that the line running though the middle is a transmission cooler line. If it is, any reason I couldn’t replace the metal line with rubber? Thanks for the input guys!
Transmission Cooler Line / Winch Mount-2898f351-4a72-4c49-850f-37b10576986e-jpeg  Transmission Cooler Line / Winch Mount-e46b00df-2a04-414f-9e4d-3b3f3521b1a7-jpeg
'12 Trail
Icon Stage 4 Billet
Stealth 6 Wheels with KO2's
Sliders
G-Cam is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 08:10 PM #2
doctorres112's Avatar
doctorres112 doctorres112 is offline
doctorres112 is on a distinguished road
Yes, that's a coolant line. Replace it w/ rubber.....why? Is it in the way? When installing my SSO low pro bumper I just slightly bent/moved it so it did not interfere w/ my bumper.
-Chris
'19 Pro in Voodoo Blue -- Xenondepot HIDS
285/70/17 KO2s -- ToyTec Boss Aluma 2.5 Performance Lift -- FR roof rack
SSO sliders/Low-Pro bumper/high angle clearance & Exp-One rear bumper
instagram: @adventureswith6
doctorres112 is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 10:39 PM #3
ScoMey's Avatar
ScoMey ScoMey is offline
ScoMey is on a distinguished road
ScoMey's Avatar
...I believe the hard line going across the front is the power steering 'cooler' line, and not an AT cooler line. On the 4Runner, the AT cooler is integrated into the radiator.
Replacing the hard line with a flexible hose could lead to problems with the power steering fluid temps. Yes, that's really a thing.
What is this???
Good luck
2023 Lexus GX 460 Premium
Sold - 2014 LE Barcelona Red
ScoMey is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 07:42 PM #4
Coyotegray's Avatar
Coyotegray Coyotegray is offline
Coyotegray will become famous soon enough
Coyotegray's Avatar
I'm getting ready to install a similar bumper by Victory 4X4.
Since the line connects to hose on each end, my plan is to just loosen both ends and the brackets and rotate it up... Worst case replace it with a new hard line bent to clear a winch. I would keep it hard line ether way to protect from impact from road debris..
2017 Toyota 4Runner TRD Off-Road Premium, Dual Battery with Blue Sea Switch, 2" Lift with Eibach Coilovers & ICON 2" Rear Springs, GOBI Stealth Cargo Rack, BFgoodrick KO2 Tires, weBoost Drive 4G-X OTR 470210 Cell Phone Signal Booster, Goose Gear Rear Plate, ARB CKMTA12 On-Board Twin Air Compressor, ARB Differential Breather Kit, Yaesu FT-891 & ICOM IC-2730A Amateur Radio Transceivers, Victory 4X4 Blitz Bumper and HF APEX 12,000 lb Winch.
Coyotegray is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 08:45 PM #5
Great idea! Thank you, I will look into making a new piece. I am going to try flipping it around first, pushing it up or bending slightly will not allow clearance of my winch.
'12 Trail
Icon Stage 4 Billet
Sliders
Old 09-25-2020, 11:21 PM #6
fajitas fajitas is offline
fajitas is on a distinguished road
Did you ever do this?
Also, I installed my winch today with the SSO hybrid bumper, and it's touching that line. I ziptied a bit of drawer liner around the tube and it's gently leaning against the solenoid of the winch.
Looking for options, but if the line doesn't get too hot (i'm reading like 120 degrees or less), it's probably not a problem.
Thoughts?
fajitas is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 02:46 AM #7
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Thoughts?
That be a power steering line if I can recall, I just bent mine away. Originally it was leaning on the control box but never had any issues. I can take pics of it later. I have since relocated the control box for accessibility.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 09:40 AM #8
phillyd2's Avatar
phillyd2 phillyd2 is offline
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
phillyd2's Avatar
Real Name: Dave
No need to overthink it - just bend it slightly out of the way. My build thread as pictures.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 10:44 AM #9
Cajun_TRD's Avatar
Cajun_TRD Cajun_TRD is offline
Cajun_TRD is on a distinguished road
Cajun_TRD's Avatar
If you can't bend it out the way enough, 4x4 labs makes a real cooler to put in its place. It is a "cooler" for the power steering so don't just replace it with hose.
Power Steering Cooler kit – 4X4LABS
TRD OFFROAD PREMIUM WITH SOME STUFF BOLTED TO IT
My Fuelly Log
Cajun_TRD is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 11:28 AM #10
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
Thoughts?
You'll be fine. I zipped some old motorcycle innertube around it, put a old Tacoma mudflap on top of that, and then spilt my winch so the control pack is actually riding on top of the line. No issues.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 12:23 AM #11
K5to4R K5to4R is offline
K5to4R is on a distinguished road
Running into similar issues with my SSO slimline bumper on my 21 4 runner. I tried to bend the brackets for the cooler line but it still rubs against the winch. I’ll send some pics to the yota dealership in town and ask if they think it’s an issue. I might buy longer soft tubing to extend the height of the cooler tube and mount higher. All I need is 1 inch of clearance...sigh
K5to4R is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 01:54 AM #12
Jeremy556's Avatar
Jeremy556's Avatar
You need to bend the hard lines below the rubber hoses - pickup a brake line tubing bender to prevent kinking the tube when you bend it.
cooler , guys , line , transmission , winch
which ATF "front" oil cooler line is the return line to the tranny? keakar 4th Gen T4Rs 5 11-12-2017 07:59 PM
Re-Routing Trans Cooler Lines In Line With Rad Cooler Questions nc-grayson 3rd gen T4Rs 3 12-07-2016 09:09 PM
Rusted out transmission cooler line? M1911 4th Gen T4Rs 6 01-30-2015 01:50 PM
broke trans cooler line loose from radiator. how do i flush the transmission homeinspector 3rd gen T4Rs 6 12-01-2014 06:51 PM
Transmission cooler line leaks. TechWrench 4th Gen T4Rs 6 10-15-2009 08:39 PM
