Old 01-27-2020, 05:46 PM #1
RoyAndyMN RoyAndyMN is offline
RoyAndyMN is on a distinguished road
Q) Locking Differentials Front & Rear? on 2010 SR5
Question) What is my stock Locking Differentials setup for Front & Rear on my 2010 SR5? It has a manual H2, H4 & L4 stick shift.
I do feel in 4WHI(H4) the steering feels hard & front tires chirp on tight turning on no snow asphalt. This surprised me as I thought it would only happen on 4W Lo(L4).
RoyAndyMN is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 05:52 PM #2
Whippersnapper02's Avatar
You don't have locking diffs. Shifting into 4wd splits power 50/50 and doesn't allow for the front and rear axles to spin at different speeds like they normally do when turning. Each tire follows a different path which means it's rotation speed is different. This causes binding in 4wd because there is no center diff like in AWD vehicles unless it's a vehicle equipped with both modes.
Old 01-27-2020, 05:54 PM #3
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough
You are locking the center diff not the front and rear.
If you are driving on dry road and enter a turn you are probably hearing the tires chirp. This happens since the front and rear are traveling at different speed a turn but are locked together in 4wd. AWD does not have this issue since the center diff can vary the front and rear speeds.
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 06:01 PM #4
mtray mtray is offline
mtray is on a distinguished road
An SR5 won't have the rear locking differential from the factory like the TRD OR/P or PRO unless they are aftermarket. The chirping is from being in 4H/4L on dry pavement as there isn't anything for the inside wheel to "slip" on in off-road or snowy situation. simply the front and rear wheels trying to go the same speed in a tight turn will put it into a binding situation and it will hop/buckle/chirp. Not very good long term.
mtray is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 06:28 PM #5
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
4hi and 4lo are the same, they're just geared differently. 4lo also turns off all traction assists. neither should be used other than in situations where you have low traction.
as noted, only the trail/off-road/trd pro have locking rear diffs from the factory, and no 4runners have locking from diffs
llDemonll is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 03:19 AM #6
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
came here for the air locker questions
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
differentials , front , locking , rear , sr5
locking differentials mamukaok 3rd gen T4Rs 12 04-17-2022 10:28 AM
locking differentials delloro Engines / Suspension / Wheels / Tires / Audio / Accessories 9 05-19-2015 04:15 PM
TSB: 75w-85 GL-5 ok for front & rear differentials GasGuzzler Maintenance/Detailing 0 08-19-2008 09:40 PM
Locking differentials and hood scoops kingofavondale 3rd gen T4Rs 45 11-07-2005 09:15 PM
Do 4runners have locking differentials? 4x4Hokie 4th Gen T4Rs 7 07-19-2004 01:19 AM
