Originally Posted by abunaitoo
Friend just got a 2017 limited.
All the bells a whistles.
With so many computer controls, it is going to give problems as it get older.
Still new with 37,000mi on it.
Great condition. Clean.
Shocks have been changed to replace the X-REAS.
We installed a Pedal Commander in it.
It works well.
Other than that, it's all stock.
He replaced the gas cap with a locking one.
Evap code came on, so I told him to put back the old one, to see if the code would come back.
Cap was a Stant.
What kind of common problems should we be watching out for????
Common problems with these ??????
When connecting my scanner, I normally do it key on/engine off.
How do I do it on this?????
No key.
To connect, I just started the engine.
He's happy with it.
I rather have his 1997 Pathfinder.
- Yes it has a few bells more than the other models I suppose but to each their own.
- Computer controls? No different than other models really and I would say problems are highly unlikely especially in the ideal conditions of your neck of the woods.
- Shocks out already? To each their own I guess, again I don't see a reason for that especially in your most ideal area, unlikely they wore out or failed.
- Gas cap situation, yes you learned, cannot do that on these vehicles for some reason, I get a code when I leave mine on for the weekend at the cottage (left at a marina), same type of cap. Just clear the code and put the stock cap back on.
- Common issues? highly doubt you will have one. Sunroof rattle maybe?
- OBDII code reading, button should have an accessory position same as turning the key forward without starting the vehicle.
- No Pathfinders of that vintage left in my neck of the woods they are long corroded into oblivion.
Cheers ....
