Old 01-28-2020, 10:00 AM #1
stephan07 stephan07 is offline
stephan07 will become famous soon enough
Dead battery-2 weeks
Just back from 2 weeks in HI and the 4runner wouldn't start. I've an upgraded X2 group F battery which is 92Ah deep cycle and has been great.
In terms of a drain, just the light from the factory installed remote starter. Is that thing enough to draw down the battery after 3 weeks of non starting it and having some cold weather here in the northeast?
The other pain in the A$$, is you cant open the rear hatch with just the key if the battery is dead. Putting it in the key slot and durning doesn't work. Is there a release from the inside that is mechanical? Without opening the rear hatch I could not access my ARB drawers. They are bolted to the floor. Fortunately I had another Noco jumper in the wife's car and she was home. Those remote lithium jumpers have been awesome when I have jumped others. Have never failed to jump a vehicle including some big diesel trucks.
I may have to see if I have a drain somewhere else, though my fridge and portable lithium "power pack" are in a heated garage and I cant think of anything other than the light that blinks on the remote starter.
2017 TRD PRO Barcelona Red,RCI Sliders,RCI Alum Skids +C4 Fuel Skid, 285 Nitto Ridge Grapplers, Icon Rebound 17x8, HID, SSO Slimline Front Bumper/Warn Zeon 10s Plat, SSO High Clearance Mod, ..King 2.5 Res, Total Chaos UCA & LCAs, ARB Fridge, Battle Born Second battery with RedArc& Solar, ARB Drawers..Frontrunner Full Rack and CVT Mt Ranier RTT, C4 Ladder, Sprint Booster
2021 Audi RS6-Tuned 820hp
2017 F12 Berlinetta
stephan07 is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 10:23 AM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
From what I gather deep cycles aren't the best for a starting battery. They don't like short trips or sitting for extended time, especially in cold weather. I have an X2 hybrid starter/deep cycle and I check the voltage quite often and put a tender on it when it's not being used like it should. I have 3 X2s, the hybrid and a deep cycle secondary for my fridge and off road lights in my 5th gen, and another hybrid in my 4th gen. They're good batteries and with a smart charger they always come back up to good voltage and have been good for years now. I don't think the remote start by itself would draw it down that far, but you never know. Good Luck!
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 10:49 AM #3
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
the "deep cycle" batteries people talk about in this context are generally all dual purpose batteries with more than enough CCA to start a vehicle, they are just better at being cycled than a normal starting battery.
i'd guess either a drain or the battery isn't healthy
i think you can pop a panel off from the door and get to the latch from the inside, but there is no quick simple release or anything
jhguth is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 12:13 PM #4
Good lesson to know, cant access my drawer system with the jumpers or Noco jumper in it! Glad it was at home.
2017 F12 Berlinetta
Old 01-28-2020, 12:26 PM #5
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I'm assuming dead battery was the original.
Time to toss it anyways. I don't think I've had much factory batteries last more than a couple years.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 01:12 PM #6
The X2 isnt a factory battery, but the factory Panasonic is really good and should last at least 5 years. The X2 is also really good and should last at least 5 years, but it has different charging requirements than what the factory charging system provides so might be damaged
Old 01-28-2020, 02:25 PM #7
I had the same issue with the original. This is the X2, which is a great battery. I dont use the vehicle often except for off-road camping trips, and summer on the cape sand dunes. In the winter I do drive it when weather is bad, and when I drive to some business sites in upstate NY and Burlington, VT. I run it with studded Nokians.
Dont get me wrong, I love driving it, but I write off a daily as my business vehicle, and don't mind saving the highway miles on the 4Runner. I'll give it a good charge with the Noco Genius charger. Guessing that the alternator may not be able to fully charge the AGM.
2017 F12 Berlinetta
Old 01-28-2020, 02:37 PM #8
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I let my truck sit for months at a time because I only use it off-road, and I have had the starter battery die even with a dual battery setup.
I installed a very convenient quick-disconnect charging port external to the vehicle in the front grill so when its sitting at home, I can just plug in a battery maintainer which charges both starter and accessory battery.
Old 01-28-2020, 03:05 PM #9
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
good point brought up about keeping our mini portable jump starters accessible in the cab/glove box and not locked in our drawers.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 04:03 PM #10
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
toyota charger is most all the time 13.5volts. AGM does require 15volt charger with a computer to sense the proper charge.
I am not hot on AGM... since you have this AGM you need to keep it on the computer controlled charger because you do not use the runner much in winter in the cold north.
I installed these AGM batteries in $250K sport cars and keep these chargers on all the time. the millionaires loved my work they had no problems. boston area..
since I use my vehicles often I only use lead acid batteries. last for me 7 yrs.
catrains is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 04:30 PM #11
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Mine ran down after setting almost 2 weeks but our other car was OK. I had a telematics unit from Auto Club that was taking power from the OBDC port when the T4 was off. I did a current check and read 350ma. Removed the unit and the draw went down to 125ma. It sat for 11 days last month with no problem.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 04:31 PM #12
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Don't know if Toyota cuts the power to the OBD port when the car is off.
My Ford Transit van does not- noticed one night when I slept in it the LED was lit up on the bluetooth ODB adapter I leave plugged in to communicate with the Torque app. I don't think the adapter draws much but it all adds up.
EDIT> BobsTrail posted it does stay on while I was typing my post....
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
battery , drain , lithium , remote , weeks
car battery dead after 2 weeks normal? rockwind1 5th gen T4Rs 19 07-29-2023 12:47 AM
'99 Battery dead, then not...? Heyduke 3rd gen T4Rs 3 03-05-2019 02:14 PM
What to do if your battery's dead? Ray Dunakin Maintenance/Detailing 5 02-19-2016 12:15 PM
Battery dead BOSMECH 4th Gen T4Rs 8 07-17-2013 03:58 PM
Dead Battery westwind77 5th gen T4Rs 16 01-05-2011 09:36 AM
