Old 02-03-2020, 10:29 PM #16
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
TRD PRO Basket Mods
These straps look promising. I can store multiple items under this.
2019 - newer Toyota 4Runner TRD PRO Base Roof Rack Net – Raingler
YouTube
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 01:22 AM #17
Little Tower Little Tower is offline
Little Tower is on a distinguished road
Originally Posted by mcat707 View Post
Any chance you can post close up pics on how yours looks like? Curious to see how you covered up the front plastic mount cover hole where the top tube mounts down into and also everything else.
The rack comes off fairly easily but, from new, the mounting bolts are very tight with lots of loctite. Just be careful to break one bolt loose then move on to the other before spinning it all of the way out.
For the front foot, I machined a plastic plug that fits tightly into the hole and is held in place from underneath.
For the rear tube, I used a piece of 1 3/4” aluminum tube cut to the same length as the plastic piece it is replacing. I then machined two inserts that were the same diameter as the inside of the stock tubing. Fit them into the tube leaving about an 1 1/2” protruding. I then fit it to the stock rails, drilled through the existing holes. Tapped the inserts and threaded in a new fastener.
For the holes that remained in the top of the rails, I found some grommet plugs and pressed them in.
Hope this answers most of your questions.
Good luck,
Tom
Little Tower is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 01:37 AM #18
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Nice job Tom! You should put some kits together and start selling them.
mcat707 is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 01:48 AM #19
phlawx's Avatar
phlawx phlawx is offline
phlawx is on a distinguished road
phlawx's Avatar
Originally Posted by DallasTRDPro View Post
I hate the way the TRD Pro rack looks. Unfortunately I want a rack half the height so I will probably end up with a Prinsu.
Agree... The new TRD pro racks are a step backwards! Check out GOBI, pricey but worth it IMO.
TRD PRO Basket Mods-53918dc6-a0ca-4beb-b7f2-972352cf3a09-jpg  TRD PRO Basket Mods-5a28dd49-c84f-4112-b850-01a477e90c66-jpg  TRD PRO Basket Mods-990a5f7f-e3d6-45ea-9954-4e3dfc9a031a-jpg
”AIRWOLF” 2017 TEP KDSS MGM
OME BP-51 / bfg ko2 / gobi stealth / rigid adapt / switch-pros 9100 / arb on-board air / OEM audio plus reference 500 / blackout trd pro trim / sunroof / behind grille [rago fab] / next up: kustom54 headlights + winch + skid plates + 2nd battery
phlawx is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 11:19 AM #20
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Originally Posted by Brick Sprickly View Post
There was a thread here just a week or so ago but I couldn't find it just now, of a 5th gen with intense rust on and around the bolt mounting points in the headliner. I as well as others suspected it may have been due to negligence somewhere, but nonetheless this case was a rare one. I think it's always a concern for those with aftermarket racks, myself included. I just made sure to seal every layer as best as I could during installation and periodically check them by lifting back the headliner with a pry tool and inspecting for moisture. There's so many wires in those locations as well as curtain airbag components so one can never be to safe I suppose. I haven't had a single issue with leakage, thankfully, even after some broad seasonal and locational changes.
Here is the thread with the rust damage. It's what took me from not worried to paranoid.
(I live in Seattle so the truck is in the rain ~4 months straight every winter.)
rageandlove is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 03:36 PM #21
great job tom,
would you happen to have more pictures of this?
thx
Old 06-20-2020, 01:47 PM #22
KEH4Runner KEH4Runner is offline
KEH4Runner is on a distinguished road
I know this is an older thread but is anyone running with the BAJA TRD pro OEM drop in basket? Opinions on that basket?
KEH4Runner is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 05:17 PM #23
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
Second that notion...
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 09:22 PM #24
Brancart675's Avatar
Brancart675 Brancart675 is offline
Brancart675 is on a distinguished road
Agreed. I’ve looked at so many options and the Gobi rack seems to be the best looking and the most versatile. Will probably be awhile before I’m able to pull the trigger but that is on my list for sure.
Brancart675 is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 12:41 AM #25
Dr. Wh0 Dr. Wh0 is offline
Dr. Wh0 is on a distinguished road
Are there any new or other baskets that drop into the trd pro rack? does the Yakima basket fit?
Dr. Wh0 is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 11:14 AM #26
Zal4R Zal4R is offline
Zal4R is on a distinguished road
I do not know about Yakima baskets, but their might mount brackets fit. I have been using them to secure my traction boards and am experimenting on mounting a plano case up there for camping gear. The ones I am using are the 23H. Amazon.com : YAKIMA, MightyMount Roof Rack Mounting System for Factory Racks, Set of 4, 23H : Yakima Mightymount : Sports & Outdoors
Not sure if that really helps, but it is at least something.
Zal4R is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 01:36 PM #27
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
Do you have any pictures by chance? I have a pair of plano cases going on the roof for the holiday weekend. It's a shorter trip, so not too concerned with using a combination of cam and ratchet straps with loop attachments to the rails. I have a longer trip coming later this summer, so would be looking at more robust solutions for that one.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 04:45 PM #28
I am essentially doing what you see in the updates here:
TRD Pro (2019+) Roof Rack Install Guide & Parts List - 5th Gen 4Runner
only I am using the mighty mounts instead of drilling the rails and am running a piece of aluminum along each side of the inside of the case and putting the fasteners on top to distribute more of the force than just the 4 points touching.
I have the hardware, but just got back from a different trip and am out and in as work is making me fly again. Should have it done in a few weeks and will post an update. I don't expect an issue as the mounts are the same hardware I use for the traction boards, all be it a bit shorter bolt. Those generate much more lift up there since they have 0 weight and are just big wind catchers. I will toss them up there this weekend and try to get a pick to show.
Old 05-26-2021, 03:12 PM #29
Jkaber Jkaber is offline
Jkaber is on a distinguished road
@little_tower, are you making these upper rail delete kits for the public?
Jkaber is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 04:15 PM #30
Yes.
I am currently in the process of setting up business. However, I do have kits ready to go.
Please PM me and we can set something up.
found , items , pro , rack , trd
Mods. Done With Mods. KISS Khjphoto 5th gen T4Rs 2 10-09-2016 06:09 PM
Cargo Basket Net emsmatt 5th gen T4Rs 7 01-19-2012 02:54 PM
Roof Basket Whackmaster 3rd gen T4Rs 9 10-02-2011 01:37 PM
Rola Basket hunton 3rd gen T4Rs 9 01-19-2011 11:12 PM
Physical Mods Then ECU Mods? liqourish 4th Gen T4Rs 0 09-24-2009 03:00 AM
