Old 01-28-2020, 08:43 PM #1
Bonniem's Avatar
Bonniem Bonniem is offline
Bonniem is on a distinguished road
Bonniem's Avatar
Portable 12v water heater
Do you guys think this will work out from 400W power outlet located in back
Norpro 559 Electric Immersion Heater Warmer 300W For Water Tea Coffee Soup
Thanks
Portable 12v water heater-water-heater1-jpg
Bonniem is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 09:35 PM #2
gainman gainman is offline
gainman will become famous soon enough
Probably not. Look for a 12v one
Sent from my SM-N975U1 using Tapatalk
gainman is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 11:01 PM #3
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I've actually been looking at getting one of those myself. I don't see why it wouldn't work, pulls less than 400w
Sundy is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 11:07 PM #4
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
I have the 110V one and the 12V one.
The 12V is way less wattage (around 120W) and takes way longer to heat water.
The 110V one should be fine at 300W on a 400W inverter.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 11:47 PM #5
JeremyB JeremyB is offline
JeremyB is on a distinguished road
300 Watts will heat up 2 gallons from 60-120 in an hour with no thermal losses. What are you going to use it for?
JeremyB is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 11:46 AM #6
Space King's Avatar
Space King Space King is offline
Space King is a jewel in the rough Space King is a jewel in the rough Space King is a jewel in the rough
Space King's Avatar
The problem is that you can only pull 300W from the inverter when the vehicle isn't running. While it's running, that outlet is clamped down to 100W. 300W is a battery drainer, and could leave you in a no-start condition in relatively short order (depending on the capacity and condition of your battery).
"Sometimes I sit and think. Sometimes I just sit."
Space King is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 12:32 PM #7
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
If this is for small volume consumption or just to take the edge off a jug of cold water for handwash or shower, then its significantly faster and more efficient to just use something like a gas operated Jetboil unit.
If you want to use something like this, regardless of if its inverted DC-AC to direct DC, you are going to need to improve the electrical in the truck, both with an additional battery and or a more capable inverter.
Old 01-29-2020, 01:03 PM #8
Bonniem's Avatar
Bonniem's Avatar
I was going boil some water while camping, got to kids they are not used to cold water
Old 01-29-2020, 08:27 PM #9
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
get a jetboil, you can have boiling water in a little over a minute
jhguth is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 09:07 PM #10
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Boil water for a shower or for consumption.
If it's for a shower - I wouldn't even consider this. The thermal loss from the water container will exceed the ability to warm it very much so you probably won't ever get a hot shower. In that case I'd either get a propane camp shower setup or heat up water on a camp stove. I use a solar shower or a cold shower. The old bushranger water heaters supposedly worked pretty good (they use the heater circuit fluid through a heat exchanger to warm up water).
If it's for food consumption - I'd still get a jeboil.
I have this cheapo kit. $25 plus a can of fuel for another $5ish. Lives in my 4Runner. I use it frequently and it works great. Amazon.com : AnimaMiracle 18 Pcs Camping Cookware Set Hiking Camping Backpacking Gear & Camping Outdoors Survival Utensils Cooking Equipment Cooking pots Mini pan, Lightweight, Camping Mess kit With Fire Starter : Sports & Outdoors
If you're just heating up a small amount of water a little bit - I guess that might work.
Old 01-29-2020, 11:40 PM #11
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
It's cheap, buy one and try it at home.
IMO - The 120v unit should work fine. Engine running, shift in park. It will take 2.5 amps from the inverter and the inverter will take 25 amps from the T4. The inverter is on a 40 amp line and fuse.
I expect the alternator will keep up and the battery will not be discharged. If concerned, run it for another minute after the heater is finished.
BobsTrail is offline   Reply With QuoteReply With Quote
back , heater , portable , soup , water
New Mr Heater , Portable Buddy 9,000 BTU D's Trail For Sale: Non-T4R Items 0 08-02-2016 06:43 PM
New Mr Heater , Portable Buddy 9,000 BTU D's Trail For Sale: Non-T4R Items 5 05-03-2016 09:15 PM
portable/camping heater for use inside my 4Runner G.I.G. Engines / Suspension / Wheels / Tires / Audio / Accessories 10 09-01-2014 07:42 PM
Portable Heater for Truck Camping EHNWI General Discussions 8 11-28-2013 11:38 PM
Tankless water heater. nevada General Discussions 19 09-13-2012 08:40 PM
