Old 12-12-2023, 04:48 PM #31
fvlewg65 fvlewg65 is offline
fvlewg65 is on a distinguished road
Electrical fluctuations
I’m having basically the same issue. My volt meter jumps up and down and when it finally drops below 9 volts everything shuts off for less than a second and then powers right back up. No chewed wires that I’ve notice and we don’t have rats in Alberta. I’m at a loss.
December 12, 2023 - YouTube
fvlewg65 is offline   Reply With QuoteReply With Quote
Old 12-12-2023, 05:06 PM #32
Humble Leader's Avatar
what do you have that is aftermarket on your rig?
Old 12-12-2023, 06:25 PM #33
I have aftermarket led headlights and a light bar installed for the last 7 years but this issue has only started 3 months ago. It even happens when the leds are off.
Old 12-13-2023, 01:26 AM #34
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
First things first.
To clean your battery connections, best is to undo them and dip the cable ends into a baking soda solution and wash the battery posts with same solution.
When all bubbling stops they are clean.
I like to coat the posts with copper antiseize to prevent bad connections down the road.
Battery connections don't always look bad.
Now you can trouble shoot further.
seatia is offline   Reply With QuoteReply With Quote
Old 03-30-2024, 07:18 PM #35
Firehouse1 Firehouse1 is offline
Firehouse1 is on a distinguished road
Originally Posted by CentcomPete View Post
Twice in the last 7 days while driving my 4Runner, the truck's electrical system has completely "shut off" for just about a second (maybe less) and immediately turned back on. Each incidence happened while driving, each time lasting for a quick second - gauges and displays go out, radio off, etc. Power returns immediately after this "blip".
I have a 1 year old battery, no mods under the hood. New head unit radio installed last summer but that was at least 7 months ago and this gremlin just started. I do have LED backup lights I installed in late December. No recent 4wheel driving or off road use.
Any ideas or suggestions?
Thanks!
Pete
I am having the very same issue. 2011 4runner. Checked all battery terminals, checked all wiring and fuses. Only Seems to happen after vehicle has been running for a few minutes and when I hit the brake pedal. Has anyone found a fix?
Firehouse1 is offline   Reply With QuoteReply With Quote
Old 03-30-2024, 07:37 PM #36
Bombguy Bombguy is offline
Bombguy is on a distinguished road
Worth getting your alternator output checked. That was the cause of mine.
Bombguy is offline   Reply With QuoteReply With Quote
Old 03-31-2024, 12:09 PM #37
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Electrical Troubles 4RUNNER
Hi CentconPete,
I've had the very same thing happen to my 2012 4Runner LE, back in 2019. The prognosis was a "Yaw rate acceleration, Centerpoint calibration" was in order; see link below to how it's done:
Yaw Rate and Acceleration Sensor Zero Point Calibration
My tachometer & speedometer would drop out when I stepped on the brake and the ABS & slip light stayed on constantly... but that all changed when I did this calibration!
Best to you, rigtec!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 04-02-2024, 06:40 PM #38
CentcomPete CentcomPete is offline
CentcomPete is on a distinguished road
It just quit happening for me. I never got it diagnosed. It only happened 3-4 times and always when I was driving at least 40+mph.
I was hit and truck was totaled about 8 months later.
2023 TRD ORP 4WD Lunar Rock
2013 SR5 4WD Mag Grey (Totaled in 2022)
CentcomPete is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 04:14 PM #39
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
And mine.
Was originally loose terminals. Addressed that and it worked for a bit.
Then the alternator went. Dealer replaced under extended warranty, even with the ARB dual and an accessory fuse panel tied to the battery. They even covered the battery.
Warranty paid for itself already.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 05:32 PM #40
Chumly Chumly is offline
Chumly is on a distinguished road
Were you driving by MacDill AFB while they were testing an EMP “Device”?
Chumly is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 08:55 PM #41
No but it would have made more sense if I had been!
driving , immediately , installed , radio , system
2010 4R LTD - nav system/electrical reboot while driving RLKF10 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-12-2019 11:18 AM
2001 4runner shut off while driving ironsights 3rd gen T4Rs 4 10-07-2018 03:34 PM
Shut off while driving!? Rear Main Seal Leaking - Advice please Mutant 3rd gen T4Rs 0 10-06-2017 12:55 PM
Shut off while driving 984RunnerBlue General Discussions 2 06-23-2015 12:41 PM
