Old 01-31-2020, 02:32 PM #1
Runnin4MO Runnin4MO is offline
Runnin4MO is on a distinguished road
2016 SR5, is there a Brake Controller already installed?
Hi all,
I picked up a 2016 SR5 used about 2 years ago. Just got a trailer with electric brakes on it.
First, is there a Brake Controller pre-installed on it from the Factory? Because it has a 7 and 4 pin connector already. From searching on this I'm seeing both yes and no answers.
If there isn't one Factory installed... where do I check to see if there is an aftermarket unit already installed from the previous owner?
Thanks all!
Runnin4MO is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 02:46 PM #2
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
There was a plug/wiring in my glovebox to use for a brake controller. It's a Toyota part.
I can get you the part number when I get home from work. Unfortunately, that will be Sun or Mon.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 02:53 PM #3
Elite130 Elite130 is offline
Elite130 is on a distinguished road
To answer your questions. No. There is no brake controller preinstalled from the factory. However, that said, the wiring is all there. The wiring is all there from the 7-pin connector at the hitch all the way to the front under the dash near the driver's left footrest. All you need to do is order yourself a brake controller (I suggest a Prodigy P3) and the pre-fabricated harness (Brake Controller Install Harness for 2016 Toyota 4Runner | etrailer.com). Then all you need to do is mount the brake controller, connect the harness to the brake controller and then into the plug under the dash and you are good to go. I believe the required relay in the engine bay fuse block is already there. This is what I did and was very easy.
2016 4Runner Trail Premium...Delivered 1/22/2016. Mods: OME Lift, Husky WeatherBeaters, Interior/Exterior LED, Console Vault, AVS Hood and Side Window Deflectors, 275/70/17 BFG KO2, Rigid Dually SAE fog lights, Rigid 20" E2 Hyperspot, Garmin Dash Cam 55, ToyTec HIDs, Aiden James Saber Pro LED high-beam bulbs.
Elite130 is offline   Reply With QuoteReply With Quote
brake , controller , factory , installed , sr5
installed new brake controller - now light always on mpechner 4th Gen T4Rs 1 04-24-2012 10:30 PM
Brake Controller Help stiner0931 4th Gen T4Rs 1 05-08-2011 10:55 PM
Installed a "Brake Force" brake controller...one issue 2003Can4runner 4th Gen T4Rs 2 10-29-2010 08:52 PM
Which brake controller does everyone use? gkatmar General Discussions 5 09-08-2008 04:04 PM
Brake Controller jclark 4th Gen T4Rs 13 05-13-2004 12:32 PM
