Old 02-01-2020, 09:31 PM #16
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Maybe an adjustable light bar inside the rear hatch?
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 10:08 PM #17
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
I have a set of baja S2's in my bumper. Easily screwed in with no issue. Then ran the wiring harnesses they came with straight to my sPod. You more than likely don't have one, but with the harness you should be able to just run it straight to the battery and the switch into the cabin.
Honestly I used to be scared of wiring, but there are so many ways to get around soldering and stuff now that you shouldn't be. For instance you can use these and it's a solder/shrink combo: Amazon.com: Kuject 120PCS Solder Seal Wire Connectors, Self-Solder Heat Shrink Butt Connector Waterproof Insulated Electrical Butt Splice Wire Terminals for Marine Automotive Aircraft Boat Truck Stereo Wire Joint: Automotive
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 10:35 PM #18
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Originally Posted by KF4R2011 View Post
This is the setup.
Mount auxiliary lights on the back or anywhere else on the trailer. the wires to power it are already hot at the 7pin connector. easy and done
ForRun is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 10:54 PM #19
KF4R2011 KF4R2011 is offline
KF4R2011 is on a distinguished road
The 7-pin can work with a switch mounted somewhere else?
KF4R2011 is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 11:38 PM #20
ForRun's Avatar
ForRun's Avatar
Provided your trailer is using the 4pin connector?? That would leave a couple options.
Tap the ground for the (-) wire, then put a weather tight switch on the trailer itself for the (12vt charging) wire. turn lights on/off at the trailer?
Not always wise but I've done it to test trailer reverse. Put the em brake on and put runner in reverse, tap the backup light center pin for the (+) wire
Old 02-01-2020, 11:41 PM #21
gSwift's Avatar
gSwift gSwift is offline
gSwift has a spectacular aura about gSwift has a spectacular aura about gSwift has a spectacular aura about
gSwift's Avatar
He could also do the Diode Dynamic tail-as-turn and get the additional backup light. I haven't seem them in person, but people seem to love the backup light since it adds so much light.
2020 Army Green TRD Pro- Icon Stage 7 2.5 CDCV / SCS BR6 Bronze 17x9 -38 / Cooper Discover STT Pro 295/70-17 / Shrockworks Sliders-Angled Up / SSO Full Length Roof Rack / Diode Dynamics SS3 Pro Yellow Fogs / Morimoto XB LED Headlights / Unique Style Racing Black Housing Taillights / Weathertech Floor Liners / Canvas Liners / LED Interior Lighting...More to come
gSwift is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 02:13 AM #22
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
You’re overthinking this. We have the technology. Carry a handheld flashlight.
Old 02-04-2020, 04:43 AM #23
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
How about a rechargeable flashlight?
Flashlight technology has gotten amazing these days.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:13 PM #24
2 wires. Battery, DPDT switch, reverse lights. Can't use a skull lamp or a flashlight when backing my 700lb 60" zero turn into the trailer. Why are you backing it in you ask? Because the weight is biased on the rear tires and so it tows better when backed onto the trailer. Tried to post this earlier but the forum blew up and it didn't save.
Lighting and Ranch Gates-img_6099-jpg
Old 02-04-2020, 05:06 PM #25
Banned
Real Name: Mark
Banned
Real Name: Mark
Uhhh... I’m not so sure about this.
Have you wired this up yet?
Did sparks fly?
If this is a standard DPDT switch you’ll be connecting +12v to ground.
Lighting and Ranch Gates-c7959b37-16b4-4144-9bbe-1e68f7c41f93-jpeg
Old 02-04-2020, 07:55 PM #26
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
Did sparks fly?
It also doesn’t make sense to use a DPDT if your just going to connect both poles together?? And the bat jumper does nothing at all.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 08:43 PM #27
Space King's Avatar
Space King Space King is offline
Space King is a jewel in the rough Space King is a jewel in the rough Space King is a jewel in the rough
Space King's Avatar
I'm not even sure what's going on anymore...
I guess we lost some posts after the forum was reset. Anyway, I thought we'd agreed that the OP was going to train a capuchin monkey to live the glovebox, and pop out with a flashlight when needed.
"Sometimes I sit and think. Sometimes I just sit."
Space King is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 09:34 PM #28
cb1111's Avatar
cb1111's Avatar
True dat
Old 02-05-2020, 04:43 PM #29
Originally Posted by cb1111 View Post
True dat
Unhelpful. Thanks for commenting. Maybe there are other threads you can contribute to.
Unhelpful. Not funny. Thanks for commenting. Maybe there are other threads you can contribute to.
Did sparks fly?
I have not wired this. I'm just trying to block the signal from the transmission when I need the reverse lights on. If I hop in, put it in drive and don't turn the new switch off, I could momentarily send 24V to the lights and I'm not sure they would appreciate it. That was a screenshot from Amazon for someone selling a DPDT switch. I would need help to know what the actual terminals needed would be so I don't backfeed the transmission computer.
Old 02-05-2020, 05:16 PM #30
cb1111's Avatar
cb1111's Avatar
So you've gone from "what lights do I use?" to "how do I wire this up?"
Since you haven't said what you want to wire up so we thought we missed some posts when the forum went down.
What lights are you using? Thereafter, we can tell you how we think it is best to hook this up.
area , due , gates , night , ranch
FS: 4th Gen V8 Gates timing belt kit $100 stir_fry_boy For Sale: T4R Items 3 03-30-2017 11:47 PM
FS: 4th gen V8 BNIB Gates Timing Belt Kit blackoutt For Sale: T4R Items 4 08-16-2016 08:34 AM
oem vs gates timing belt..? kennyb3030 3rd gen T4Rs 5 12-19-2009 08:53 PM
Shame on Prof.Gates Thai Off Topic 16 07-31-2009 09:03 PM
