Old 02-05-2020, 11:48 PM #16
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Can't figure out why Toyota deleted the cover on that compartment. My '08 had a snap in cover that let me store lots of stuff back there. Good job, OP.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 10:51 PM #17
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
To meet CARB specs, they were 42 grams over weight causing MPG excess, so they left out the cover. ;)
/joking
zonzin is offline   Reply With QuoteReply With Quote
Old 03-21-2020, 08:58 PM #18
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Hey, thanks for this idea. Those open holes always drove me kind of nuts. For my shelter-in-place project I went to my local Tap Plastics store and got a 24in x 24in sheet of 3/16in black ABS with one textured side. It was about $25. I could have ordered a sheet from Amazon for about $16 but I didn’t want to wait.
I cut out patterns from cardboard and trimmed them to fit. For the lower small cover I cut the ABS with a jig saw and trimmed and cleaned up the edges with a sure-form shaver tool and sandpaper. Since I’ll never need to remove it, I glued the cover into place with E6000.
I cut the larger cover out and spend a lot of time trimming and shaping it. I beveled the inner edges with the sureform to fit a little better against the channels in the side panel.
I cut two grabber tabs, placed them in a vise, carefully heated them with a propane torch, and bent them to shape quickly with a block of wood. Two bends were needed. After test fitting and measuring I glued them to the lower edges of the cover with ABS cement.
At the top of the cover I glued a neodymium magnet to match a magnetic drawer catch (from HD) that was screwed into the inner ceiling of the larger opening. After some adjustments it gripped and worked ok.
To make the cover sit snug in the opening I used a hair dryer to heat and bend it in various places. That made the fit ideal and the magnetic latch held it snug. An extra push in the proper spot and the cover pops open a little for removal. It looks good and hides my tools.
Rainy day project with ABS and bits to make rear compartment covers-2b2394d7-93d3-4e89-b9df-a0e81d877164-jpeg  Rainy day project with ABS and bits to make rear compartment covers-47a82dfa-78b7-4888-9239-7653b237ef8c-jpeg  Rainy day project with ABS and bits to make rear compartment covers-d7f2da6c-fb24-4211-b2ea-701928bc8b67-jpeg  Rainy day project with ABS and bits to make rear compartment covers-d71b7ca0-1ad6-4906-ba62-03381ccd89c9-jpeg  Rainy day project with ABS and bits to make rear compartment covers-4e42a4a5-6423-4dfc-ad18-c0865a0e2383-jpeg  Rainy day project with ABS and bits to make rear compartment covers-9aeb878b-59a5-4abb-af82-a702765a2f5e-jpeg
Old 03-22-2020, 12:34 PM #19
Blue 4ever Runner's Avatar
Blue 4ever Runner Blue 4ever Runner is offline
Real Name: Jim
Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light
Real Name: Jim
I just ordered the necessary stuff to do this. Since I'm an old bastard, I'm sheltering in place so this will be a good way to pass some time. I'll post pics when I get it done.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
Blue 4ever Runner is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 02:09 PM #20
Real Name: Jim
Real Name: Jim
I received the ABS sheet and cut it to fit. A lot of fitting and sanding with the belt sander clamped in my bench vise but it's pretty good. I'm leaving the small opening as is for now, if I find a need, I'll do that at a later date. I'm waiting for the ABS cement to get here, Amazon is not sending things too quickly unless it's an item that's really necessary. As soon as I get it I'll post picks of the cover. It'll be pretty much like others here but I'm going to try a different latch. It might not work, we'll see.
Thanks to all you guys who already did this and posted it.
Old 04-02-2020, 08:12 PM #21
askdrtodd askdrtodd is offline
askdrtodd is on a distinguished road
That's awesome! I'd buy em!
askdrtodd is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 11:18 AM #22
zonzin's Avatar
zonzin's Avatar
Nicely done!
Old 04-28-2020, 04:53 PM #23
Real Name: Jim
Real Name: Jim
Finally!
I finally got the ABS adhesive and put the hooks on the bottom of the panel I made. It really holds the cover tightly in the opening so I'm going to leave it as is unless it pops off during driving. If so I'll figure out what clasp I'll use to hold it in. I just cut a piece of the ABS to fit inside of the small opening and slid it in there. It's held in place with the stuff in there. Good enough for me for now at least.
Update: These are the "hooks" that are holding the cover in place.
Rainy day project with ABS and bits to make rear compartment covers-dscn5484-jpg  Rainy day project with ABS and bits to make rear compartment covers-dscn5486-jpg
Old 04-28-2020, 08:29 PM #24
shdw03 shdw03 is offline
shdw03 will become famous soon enough shdw03 will become famous soon enough
Great work guys. Motivated to make me one for my subwoofer cover now.
Question. Would it be unwise to use expanded pvc vs using abs?
shdw03 is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 11:54 AM #25
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Nice work. Looks great.
<<<< is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 01:36 PM #26
Real Name: Jim
Real Name: Jim
Thank you. I don't have the patience I used to have and this was a pain to sand off a little bit, go fit it, sand it more, etc. It still isn't perfect but good enough for me. Thank goodness I'm pretty good with the belt sander, doing this by hand would be too much. It's the details that get ya.
Old 04-29-2020, 08:04 PM #27
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Nice work and great idea!
itr1275 is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 04:50 PM #28
All in a day's work. Thanks for the great ideas. My panel was a little easier to construct. Didn't need to be perfect. It's rear mounted with tabs that screw into the stock trim mounting points on the back side.
Sent from my ONEPLUS A6013 using Tapatalk
Old 05-04-2020, 07:21 PM #29
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
I have some old kydex from my holster days, might as well give this a shot. Would be kewl to see the "M.O.L.L.E. fabricators do something like this.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 06:07 PM #30
Charlievee's Avatar
Charlievee's Avatar
Only real thing i did a little different, was the lower cover. Cut it to accept the MOLLE bag i hang there and was able to fab a clip to hold it in place.
Rainy day project with ABS and bits to make rear compartment covers-20200518_164706_resized-jpg  Rainy day project with ABS and bits to make rear compartment covers-20200518_165227_resized-jpg  Rainy day project with ABS and bits to make rear compartment covers-20200518_165410_resized-jpg
abs , compartment , cover , covers , cut
Wanted - 3RZ bits KidVermicious Want to Buy/Trade 1 03-10-2014 11:30 AM
Moisture on inside of windshield etc. when cold/rainy cstorms 5th gen T4Rs 7 01-01-2014 09:27 PM
Rainy Day Pics: 06 T4R SE 4WD w/18 Ltd's & Revo 2's 4runnerjack 4th Gen T4Rs 16 01-01-2011 08:39 PM
A little rainy day fun (A picture book) durrell 3rd gen T4Rs 22 12-24-2010 12:58 AM
Rainy Day in Arizona MickeyMouse Gallery 4 11-23-2004 03:06 AM
