Old 02-03-2020, 11:34 PM #1
p_j_o's Avatar
p_j_o p_j_o is offline
p_j_o is on a distinguished road
p_j_o's Avatar
Frozen door and hatch actuators???
So I just came back from 4 days up in the mountains where it was -15C (5F). On the morning to come home, both the rear passenger side door and the hatch wouldn't unlock... I couldn't hear the unlock "unlock" from those two locations. When I manually "unlocked" the lock on the rear door, no issue to open. Obviously I couldn't do that with the the rear hatch - and I couldn't open it, for about an 2 hours. Eventually, everything thawed enough work though...
The question is, is it possible for those actuators to freeze? if not, wtf happened? Any ideas????
pjo
p_j_o is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 11:32 AM #2
filoufil's Avatar
filoufil filoufil is offline
filoufil is on a distinguished road
filoufil's Avatar
I had the exact same problem last year. I did uninstall the actuator and greased it but it eventually came back when we had really cold temperatures in the same year (at about -30C).
Hopefully someone else had the same problem and found a good solution.
filoufil is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:00 PM #3
medelstein169's Avatar
medelstein169 medelstein169 is offline
medelstein169 is on a distinguished road
pjo
I didn't have this issue with cold temps but I did have all four actuators fail and replaced under warranty. Apparently its a known issue with this age T4R
2014 T4R TE, Barcelona Red, V6, 3" Toytec lift, Smittybilt XRC winch, Southern Hybrid front bumper, ARB Alum roof rack and rear ladder, BFG All Terrain T/A 285/70/17 with 1.5" spacers
medelstein169 is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:13 PM #4
catrains catrains is offline
catrains will become famous soon enough
your problem is the door weather strips are shrinking breaking down. then water gets into the door cavity.. then the freeze up on the actuators.
I use a silicone paint/plastic safe spray to reduce the water intrusion .
I do live in snow country but in the cold northeast not a problem this year. LOL... planet is warming up ....
look at the weather strips if shrinking you could replace or add a sealer in the shrinkage areas.
catrains is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:24 PM #5
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I'll second @catrains and suggest (After thawing) doing a silicone treatment to the seals. I've used a heavy coating of armorall.
If you do take latches/locks/etc apart a big problem, IMHO, is that dirt/grease can accumulate over time. I've seen this in the bike industry as a tech where old shifter's grease gets so thick that it appears that the shifter needs to be replaced. In actuality the old gunk just needed to come out.
A secondary problem becomes the type of lubricant and the quantity of lubricant used. I'd suggest a thinner lubricant that only coats the parts needed and nothing more.
I'd love to throw all my latches, locks, etc into an unltrasonic cleaner to get it them really clean and use a PTFE based lubricant.
Just like chains on a bike drive-train: less lubricant is best in ALL cases.
1997 4Runner SR5- ~370k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 142k Miles - Automatic - Brake Controller.
2011 VW JSW TDI- 104k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 06:54 PM #6
p_j_o's Avatar
p_j_o's Avatar
Thanks everyone for the insight. Your right, this probably has to do with the door seals - I had the kids yank on the door last time this happened and it did pull the seals away from their mounting.
Looks like it might be time to replace them
pjo
door , hatch , open , rear , unlock
power lock, door actuators not working jjdurnwald 4th Gen T4Rs 2 09-27-2019 03:54 PM
Blend door actuators part numbers firefoxed 4th Gen T4Rs 0 07-16-2019 12:36 PM
Door lock actuators..... shawn474 5th gen T4Rs 9 03-06-2018 08:03 PM
door lock actuators 3bears 3rd gen T4Rs 20 08-06-2016 12:07 PM
Door lock actuators carmcanc Classic T4Rs 0 10-28-2005 10:35 AM
