Old 11-17-2022, 10:58 PM #196
MP486 MP486 is offline
MP486 is on a distinguished road
My newly installed Dobinsons IMS 50574 Front with C59-300 coil & 50701 Rear with C59-325 Coil.
MP486 is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 11:08 AM #197
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Thanks for sharing man, it looks really good!!
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-04-2023, 05:59 PM #198
Crikeymike's Avatar
Crikeymike's Avatar
Dobinsons just announced today that the IMS59-50705 rear shocks have been discontinued and replaced by the IMS59-50701 shocks. They have been re-valved for better all around performance and reducing the amount of parts to have to stock and keep track of. Anyone with any backorders of IMS59-50705 will be sent the new version IMS59-50701 shocks when they arrive in another week or so.
Old 02-25-2023, 07:48 PM #199
TRev0r TRev0r is offline
TRev0r is on a distinguished road
discontinued IMS59-50705 for family hauler?
I came here looking for info on the IMS59-50705 and just saw they are discontinued. A front coil on my TRD FJ kit just snapped. It was super cheap and has been great for 80K KM or so, but I welcome the excuse to finally order an IMS kit for my 2015 4Runner.
Truck is a family hauler for vacations and loads of mountain biking locally, where we have a lot of logging roads.
With the FJ TRD kit, 1/4" top plate spacers, and C59-599 rears, I reckon the old lift was about 1.75" front and 1.25" rear from stock. Great for us. Then I added a pelfrey hidden winch plate, Warn M8000s winch, and group 27 AGM battery.
I need to avoid going much higher this time. For the front we are pretty sure we go with:
  • IMS59-50700
  • C59-302 (for ~2" with winch plate & battery ?)
Questions about the rears:
  • Was interested in the IMS59-50705, since kids back there, but I haven't found much info online. We are in Canada and there is still stock of 50705 up here. Should I just get those, or order the IMS59-50701 and gamble that I get the new ones?
  • Is there any way to identify the re-valved IMS59-50701 vs previous ones?
  • Was going to get another set of C59-599, but with C59-302 up front I am worried about sag. Can I run C59-599 with C59-302 in front, or do I need C59-505 in the rear?
Thanks!
Trev
TRev0r is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 10:58 AM #200
Crikeymike's Avatar
Crikeymike's Avatar
  • IMS59-50700
Thanks!
Trev
You can keep the coils you have now, change the fronts out and see how the rake is when it's done, and then change out the rear coils if you need. There's only 1/2" difference between the 599's and 505's.
The 302's will probably still be about 2.25" with just a winch plate and winch.
Just go with the 50705's that are up there and in stock. I don't have a breakdown of the build code on the shocks to isolate old/new, but I know I've only been selling the new ones and they just sold out again on Friday.
Old 05-01-2023, 02:01 AM #201
Nexitus Nexitus is offline
Nexitus is on a distinguished road
Hello!
My friend and I installed a strut and spring for the front over the weekend.
I was going through a few sources. I thought there was a mention that you'd just bottom out on the top nut for the strut so there shouldn't be an issue with overtightening...
However, it looks like with the top bushing bulging, I either did that or used the wrong washer. Thoughts?
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-img_6819_s-jpg
Nexitus is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 09:34 AM #202
Crikeymike's Avatar
Crikeymike's Avatar
Originally Posted by Nexitus View Post
Hello!
Attachment 404406
Could be the wrong top washer, as that end uses the bigger OD of the ones that come with it.
How does it look with the vehicle back on the ground?
Old 05-01-2023, 02:27 PM #203
This is actually the look of it with the vehicle on the ground. I'll assume I had the two washer's backward then. The slightly larger one in the top hat and this smaller one on top.
Old 05-01-2023, 02:48 PM #204
Crikeymike's Avatar
Crikeymike's Avatar
Ok.
The smaller washer will dig into the rubber if that's what's on top. You can relieve some turns on nut so it's not bulged out so bad, but definitely worth checking your work as it's not usually that bulged out
Old 05-04-2023, 08:34 PM #205
Ok.
Thanks! All fixed up.
Would you know the best way to install the rear spring and coils for a 4Runner with KDSS? I think after trying it, it might be best to disconnect the rear sway and kdss mounts from the axle. Thoughts?
Old 05-04-2023, 09:33 PM #206
Crikeymike's Avatar
Crikeymike's Avatar
Great.
Yeah. Take the mounts off where it attaches to the axle. Then do one side of coil at a time. You can have someone push down (stand) on the end of the axle to get it to flex down a little more to get the coil in place. Be sure they're rotated against the notch in the coil seat properly too
Old 05-04-2023, 09:42 PM #207
Great.
Do I need to free all the ABS and Brake line brackets?
Old 05-04-2023, 10:17 PM #208
Crikeymike's Avatar
Crikeymike's Avatar
Good idea to do that. Depends on the lift height you're going with. I've done it with them still connected
Old 05-04-2023, 10:53 PM #209
Did you remove the sway bar as well?
Old 10-31-2023, 03:28 PM #210
Crikeymike's Avatar
Crikeymike's Avatar
Black Friday deals start tomorrow. Check out the post here for any and all deals we will be offering. We'll update it if any other brands add a deal.
2023 Black Friday Deals & Discounts - Exit Offroad
dobinsons , ims , piston , shocks , struts
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 4th Gen Crikeymike 4th Gen T4Rs 30 10-31-2023 03:42 PM
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen Crikeymike 5th gen T4Rs 137 10-23-2023 04:01 PM
Dobinsons Long travel front struts and rear shocks Crikeymike 5th gen T4Rs 48 06-15-2017 03:01 PM
FS: Bilstein 5100 Series Ride Height Adjustable Front Shocks, 5th gen, $80 SLC, UT T4Rdvm For Sale: Suspension/Wheels/Tires 1 08-10-2015 11:57 PM
Bilstein Height Adjustable Shocks 0-2.5 inches 06sr5 Engines / Suspension / Wheels / Tires / Audio / Accessories 30 12-21-2011 05:54 PM
