Old 11-12-2020, 12:22 PM #61
GripT4R GripT4R is offline
Banned
GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light GripT4R is a glorious beacon of light
Banned
Does Dobinsons make a 14” 650lb coil for 2.5” diameter shocks?
I have Bilstein 6112’s and want to replace the 600lb bilstein springs.
GripT4R is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 12:26 PM #62
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
No, sorry. The only coil Dobinsons makes that would fit those 6112's is the TRD Pro 1" lifted coil, but it's the same rate as stock (550lb from memory)
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 12:27 PM #63
Banned
Banned
Shitty. Looks like i have to buy the Kings...
Old 11-12-2020, 01:14 PM #64
utctscanr75's Avatar
utctscanr75 utctscanr75 is offline
Real Name: Bird Dog Overland
utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light
Anyone know if the MRA59-A575 3-way adjustable shocks work with any of the available shock guards? Rago says if it is under 3" in width, there's will fit.
Not sure when mine will arrive as I just ordered them, but would like to take advantage of the Rago sale (or any other shock guard maker's deals)
utctscanr75 is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 01:36 PM #65
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
bilstein offers a 650lb coil for the 6112 u can purchase seperately...
tm965 is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 01:43 PM #66
redshift83's Avatar
redshift83 redshift83 is offline
redshift83 will become famous soon enough
redshift83's Avatar
So, I ordered my IMS lift setup the other day from Exit Offroad, and now I have to sit and wait till everything comes back in stock, lol. While i'm waiting I've been wondering something.
I ordered the 302 springs up front with the intention of sitting at ~2" lift once i install my winch and other stuff. Unfortunately the winch mount I'm ordering (c4 fab) has a 11 week lead time. Is it possible (rather, will it damage the struts) to adjust the perches lower than the 213mm preset height while i'm waiting? I'd probably only do .5-1" so it'd be around .27"-.55" total perch height drop. I know i'd have to re-do the alignment afterwards, but with that added weight i'd want to anyway.
My thought is it'll be fine because the bump stop position doesn't change relative to the strut's lowest travel position, but there may be something i'm not seeing. I normally wouldn't worry, but 2.5" lift feels higher than i want to go with my KDSS equipped runner, and it may look like it has some reverse lean which i'm not interested in, haha.
10 4Runner Trail - Dobinsons IMS, Spidertrax, C4 Fab Lo Pro bumper, Prinsu full rack, etc.
91 Celica All-Trac - tons of mods
99 Miata -makes supercharger noises
83 CJ7 - 304 swap w/tbi, 33's, still broken
redshift83 is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 02:09 PM #67
Crikeymike's Avatar
Crikeymike's Avatar
You mean the metal lower shock guards? Any of them should work, as the outside body of the shock is 56mm, 2.2".
Old 11-12-2020, 02:12 PM #68
Crikeymike's Avatar
Crikeymike's Avatar
The spring seat height isn't supposed to go less than 213mm, as the sway bar will end up contacting the coil seat. But you have KDSS, and the sway bar can't contact it. It's still not recommended to go lower. For the extra work you'll do of adjusting it first for 2", then higher just a month or 2 later, I don't think it's worth it.
Old 11-12-2020, 07:02 PM #69
Banned
Banned
Correct. The issue is that bilstein springs suck.
Old 11-12-2020, 09:54 PM #70
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I'm running the C302s with KDSS and the coil perches set at the recommended 213mm. I'm actually thinking of bumping them up closer to 220mm to gain an extra 0.5" of lift and be around 23" hub to fender.
I've a good amount of miles on offroading with this and zero concerns with the KDSS being lifted.
My truck is the black one. The white has the C302 coils and C505 in the rear, his rear end is approx. 0.65" lower than mine with C725 coils
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-2-4runners-small-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-4r-jpg
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 10:04 AM #71
4Hundred Payments 4Hundred Payments is offline
4Hundred Payments is on a distinguished road
Yes, rebuildable and re-valvable (I don't think valvable is a real word)
Should expect the same life if not more actually.
Is there a rebuild kit available? I can't find one anywhere online.
Also, WHEN WILL THE NEXT SALE BE??? I'm very upset with myself for missing the November one. I just got back from my first overland trip and might be hooked.
4Hundred Payments is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 11:30 AM #72
Crikeymike's Avatar
Crikeymike's Avatar
There will never ever be a sale ever again, and the price is about to go up 50%, so it looks like you really missed out!!
Rebuild kits are considered spare parts, not listed online. You'd contact Dobinsons for them if/when you need it. I've never sold a rebuild kit for IMS or MRR/MRA in the 4+ years I've been selling them. A few characters have broken hoses from incorrect mounting positions though.
Old 12-04-2020, 01:48 PM #73
krhayes79's Avatar
krhayes79 krhayes79 is offline
Real Name: Kelly
krhayes79 has a spectacular aura about krhayes79 has a spectacular aura about
krhayes79's Avatar
Real Name: Kelly
Hey Mike
Any updated dates on the C59-325 rear springs? Hoping sooner than later
Thanks!
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
krhayes79 is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 02:23 PM #74
Crikeymike's Avatar
Crikeymike's Avatar
Originally Posted by krhayes79 View Post
Hey Mike
Thanks!
Yep, sooner than Christmas 2021, but later than Christmas 2020!!
Late January.
Old 12-04-2020, 04:38 PM #75
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Late January.
Nearly lost my coffee there lol
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
dobinsons , ims , piston , shocks , struts
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 4th Gen Crikeymike 4th Gen T4Rs 30 10-31-2023 03:42 PM
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen Crikeymike 5th gen T4Rs 137 10-23-2023 04:01 PM
Dobinsons Long travel front struts and rear shocks Crikeymike 5th gen T4Rs 48 06-15-2017 03:01 PM
FS: Bilstein 5100 Series Ride Height Adjustable Front Shocks, 5th gen, $80 SLC, UT T4Rdvm For Sale: Suspension/Wheels/Tires 1 08-10-2015 11:57 PM
Bilstein Height Adjustable Shocks 0-2.5 inches 06sr5 Engines / Suspension / Wheels / Tires / Audio / Accessories 30 12-21-2011 05:54 PM
