Old 02-06-2020, 11:39 AM #16
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Originally Posted by RedRunner_87 View Post
@Crikeymike two questionsfor you:
1) How much adjustability do you get with these? "Threaded bodies on struts allow for fine tuning of height and offer further improvements in cooling."
2) Do the Long Travel(IMS59-50574) add an additional 1" of lift?
The whole body is threaded, so you could go from 0" to 4" technically, not that you can go that high without causing other issues.
The 574s also have a fully threaded body so you can set them to add 1" of lift or not.
Sent from my SM-G973U using Tapatalk
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 11:46 AM #17
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Based on this, any reason to not get the long travel versions? I'm not looking at a ton of lift, just curious. Will likely go with the 2" coils after lo-pro / winch bumper, was concerned about pushing it to 3" as I'd like to try and not replace UCA's.
Sundy is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 05:45 PM #18
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
Awesome! I was trying to stay around 2.5/1, that is why I was asking about adjustability. The closer to 2.5 in the front the better for me. Thanks for the info. I think this just moved up to #1 on my list.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 10:04 AM #19
Crikeymike's Avatar
Crikeymike's Avatar
Had a few people ask about this, so I just wrote this up, and also added it to the first post.
Setting coil seat height
The IMS59-50700 come with a full threaded body, and the coil seat height needs to be set prior to installing the coils onto them. A proper strut coil compressor is required. Regular rental compressors can have teeth that hold the coil which are too thick, they won't work, as you probably won't be able to get the teeth out once the coil is on the strut. We offer the assembly of the front coilovers with new top mounts for an extra charge.
2 base options:
213mm - Base setting, same as OE, for coil seat height. Use this with lifted coil springs to let the coils do the lifting only
226mm - Taller setting, adds 1" of lift to whatever coil springs you're using. Use this setting with a 2" coil to produce 3" of lift, for example.
  • Spin both collars down on the strut almost to the bottom. Never use any locktight, it will gum up the threads and it's not necessary once you see the step below.
  • Slide the coil seat onto the strut, with the flattest side facing down (notch facing upwards for coil to sit against)
  • Using a tape measure, hold the tape against the lip/notch of the coil seat (where the pigtail of the coil will sit) and measure down to center of the lower mounting hole. Raise or lower the top adjuster collar until the coil seat is in the correct position.
  • Once the height is set, take both adjuster tools that were supplied. Hold the top adjuster in place, and bring the 2nd adjuster up to the top one, and lock them together. This is the same as "double nutting". This is insurance to keep the top adjuster in position and keep the height where it is.
  • If ever you need to adjust the coilover up or down, ALWAYS undo the lower adjuster FIRST, slide it down out of the way, then adjust the upper adjuster to the correct position. If you try to move both adjusters at once, the threads will most likely get damaged and you won't be happy.
  • I'll be making a video and posting it up when I get a chance, as it's a pretty simple process, but worth getting a visual for too.
Old 02-12-2020, 11:05 AM #20
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
If you don't have aftermarket upper control arms you are likely to exceed the range of angle built into the stock upper control arm. So you could damage the upper control arm ball joint. I don't know the full extended length of these though so it's hard to say on whether they'd cause an issue or not.
Also FWIW - most other shocks that come in regular or extended length like Fox or King are actually all the same shock. The regular travel versions have a rubber bumper inside that limits the down travel by a little bit. So if you have them apart to rebuild you can remove that bumper to make them extended travel down the road. Maybe Mike can help with some details on the internals.
The internal reservoir is usually called and IFP or Internal Floating Piston in the other popular brands. It's a tried and true solution.
In my experience with Fox - the service interval is about 15,000 miles and the reason is to replace the spherical bearings. They don't last very long. I would much rather have rubber bushings like these. Every time I have to pull them out to replace the bushings I consider machining out the shock eyes to fit some sort of rubber instead. Rubber is simply better for this application. Otherwise if the build quality is similar - I'd expect the life of these type of shocks to be longer than the OEM due to better seals and better materials throughout. So 100k or more.
Jetboy is online now   Reply With QuoteReply With Quote
Old 02-12-2020, 02:54 PM #21
Jetboy - thanks for the insight! Good to know the bushings are usually a big reason for the rebuilds - tearing apart a truck every 15K isn't on my to-do list (I drive almost 30K a year).
Old 02-25-2020, 04:19 PM #22
Crikeymike's Avatar
Crikeymike's Avatar
Just updating ETA's here.
IMS59-50700 and IMS59-50701 have arrived and will start shipping out any day now.
IMS59-50574 and IMS59-50705 are still due in late March.
IMS59-50575 still don't have an ETA as they aren't out of production and on the way yet.
Old 02-27-2020, 05:48 PM #23
Crikeymike's Avatar
Crikeymike's Avatar
Those who ordered first receive first!!! First set of assembled Dobinsons IMS struts and shocks going out the door yesterday.
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-ims-assembly-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-ims-assembly-b-jpg
Old 03-11-2020, 12:47 PM #24
Crikeymike's Avatar
Crikeymike's Avatar
Showing the different coil color options that can go along with the IMS struts and shocks.
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-dobinsons-ims-4runner-kit-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-dobinsons-ims-4runner-kit-all-black-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-ims-kit-red-jpg
Old 03-19-2020, 12:19 PM #25
Crikeymike's Avatar
Crikeymike's Avatar
Stock update - March container arrived today.
These are now in stock.
IMS59-50700
IMS59-50701
IMS59-50574
IMS59-50705
Any backorders awaiting shipment are leaving today or tomorrow. I'm also posting a video to my Youtube page today on how to adjust and set the height on these. I'll post a link later.
Old 03-24-2020, 10:07 PM #26
FedEx dropped off a package full of goodies today! These things look great, I can't wait to get them installed!
On a side note - do you know of any mounts that would work to mount the air compressor under the hood? Thinking it could maybe fit in the passenger side back corner.
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-shocks-jpg
Old 03-24-2020, 11:13 PM #27
Crikeymike's Avatar
Crikeymike's Avatar
Looks great!!
I don't know of any mounts to be honest. Any that fit the ARB twin could probably take this but the compressor must sit upright, not at any other angle.
Old 03-25-2020, 03:50 PM #28
4boer2's Avatar
4boer2 4boer2 is offline
4boer2 is on a distinguished road
4boer2's Avatar
Talk to heftyfab, he's in your backyard! He was able to fab a mount for my smittybuilt which looks like the dobnisons compressor. It's rock solid. I have mounted it the other way since I took this pic and it works better, just don't get the hose caught in the fan.
4boer2 is offline   Reply With QuoteReply With Quote
Old 03-26-2020, 12:29 PM #29
Crikeymike's Avatar
Crikeymike's Avatar
A better view and some close up views of the details of these.
Old 04-10-2020, 11:30 AM #30
jbl911 jbl911 is offline
jbl911 is on a distinguished road
Interested, PM sent
jbl911 is offline   Reply With QuoteReply With Quote
dobinsons , ims , piston , shocks , struts
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 4th Gen Crikeymike 4th Gen T4Rs 30 10-31-2023 03:42 PM
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen Crikeymike 5th gen T4Rs 137 10-23-2023 04:01 PM
Dobinsons Long travel front struts and rear shocks Crikeymike 5th gen T4Rs 48 06-15-2017 03:01 PM
FS: Bilstein 5100 Series Ride Height Adjustable Front Shocks, 5th gen, $80 SLC, UT T4Rdvm For Sale: Suspension/Wheels/Tires 1 08-10-2015 11:57 PM
Bilstein Height Adjustable Shocks 0-2.5 inches 06sr5 Engines / Suspension / Wheels / Tires / Audio / Accessories 30 12-21-2011 05:54 PM
