Old 05-05-2021, 11:12 AM #106
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Originally Posted by 2Parc View Post
Thanks again, Mike. I am new to this stuff and really appreciate all the info you provide.
No problem. Just remember that the front IMS are height adjustable, but for the rear, the coils are separate from the shocks and the coils themselves do the lifting while the shocks have no effect on the lift height.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 03:25 PM #107
MikeYQM's Avatar
MikeYQM MikeYQM is offline
MikeYQM is on a distinguished road
MikeYQM's Avatar
Hi Mike,
I’m running OME 885 front and 889 rear springs on 5100s netting a 3/2.5 inch lift. Would 574 front and 575 rears work out if I wanted to ditch the 5100s?
Thanks,
MikeYQM is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 03:43 PM #108
Crikeymike's Avatar
Crikeymike's Avatar
Originally Posted by MikeYQM View Post
Hi Mike,
Thanks,
You can run the 574's up front, but in the rear, your coils will fall out potentially since they're not long travel coils. You'd use IMS59-50701's in the back unless you change out to LT rear coils, which are the only type of coils that can be ran with LT rear shocks.
Old 05-07-2021, 04:07 PM #109
MikeYQM's Avatar
MikeYQM's Avatar
Ok thanks. Can you recommend a rear spring that would work with LT with moderate weight?
Old 05-07-2021, 04:14 PM #110
Crikeymike's Avatar
Crikeymike's Avatar
These are the 4 different LT rear coils Dobinsons offer. You'd probably be looking at the 677V's
C59-675V - Variable rate comfort option, stock rear weight, 3" lift. 470/470mm, 16mm wire, 157-230LB variable
C59-677V - Variable rate comfort option, 400+LB heavy rear load weight, 3" lift. 500/500mm, 16mm wire, 157-230LB variable
C59-701V - Variable rate, 600-700 LB heavy rear load weight, 3" lift, long travel. 500/500mm, 17mm wire, 210-245LB variable. Designed for those with heavy full rear bumper, tire carrier, roof rack, RTT, drawers, and fridge. Rides very well with all that weight, as well as when loaded even further.
C59-749V - Variable Rate, 800-1000 LB super heavy constant rear load, 3" lift, long travel. 520/520mm free height, 18mm wire, 198-300LB variable rate, usually around 270LB at loaded height
Old 05-10-2021, 06:38 PM #111
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
Originally Posted by Big Daddy K View Post
Okay I finally hit the go button. Even though I know they are out of stock I'll still be watching my email like an ebay auction..
Woot. Got my shipping notice today. Thanks for all the input Mike.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 09:18 AM #112
Crikeymike's Avatar
Crikeymike's Avatar
No worries bud!!
Old 05-13-2021, 10:27 AM #113
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
Maybe it’s mentioned somewhere but I missed it. What is the shock body and threads made of? I read somewhere this: “DOM seamless tubing body” which would mean steel, not aluminum. Just wanting to confirm.
(I’m asking because I would be concerned with tweaking the perch adjustment rings for height while on the truck if it was aluminum because of thread strength. I’m talking adjusting shortly after install while threads are clean to get lift right, not after 10k miles of mudding...)
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 10:44 AM #114
Crikeymike's Avatar
Crikeymike's Avatar
Yes, they're steel bodies. The adjuster rings are aluminum, softer than the steel so that the threads get saved in case the adjuster gets jacked.
Old 05-13-2021, 10:59 AM #115
Real Name: Michael
Real Name: Michael
Ok. Thanks. I’ll just be very careful!
Old 05-13-2021, 02:19 PM #116
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I would be very careful about making any adjustments after driving more than the initial settling, without disassembling the shock and coil. I recently raised the front of my 4Runner (I added a lo-pro bumper and winch), the amount of crap behind the coil perch was astonishing. Had I tried to adjust with it on the truck I would have been in for a BAD DAY.
I think I've got my coils about maxed out for preload, I raised the mounting point approximately 5/8" higher than the recommended. I've got C302 with the standard length shocks. There does not look to be any contact of coils on full compression but it's got to be close. Just something to consider when raising the height.
Overall it was pretty quick to disassemble. If I were to adjust after a fresh install, I'd make sure to drop a bit of oil on the threads (before would likely be a good move) to help the adjusting rings move easier.
Good luck!
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 03:43 PM #117
Real Name: Michael
Real Name: Michael
Good luck!
Thanks for the heads up. I’m still waiting on my kit to be delivered, but preparing. I was thinking of only increasing the lift above the amount of the spring in the range of 1/2” to 3/4” (296 spring which is 1.5” so I should achieve 2” to 2.25” lift) which would mean a perch adjustment of approximately 1/4” to 3/8” in the beginning. I was thinking of running past that a little and shoot for 1” additional lift which is 1/2” above the minimum setting on the shock, then lowering as needed after initial settling. That way, I’m reducing preload and not fighting the spring as much. Make sense? Wouldn’t that be easier than raising it more...? The threads could be cleaned as well since the rings will be lowered. And I have access to those threads unlike raising where the threads are hidden behind the perch.
Old 05-13-2021, 04:16 PM #118
I think you have a great game plan. Setting the perches 1/2" high will give you approximately an extra 1" of lift, go drive it hard for a few hundred miles and then get your hub to fender measurements. It will be TALL at first, but things settle.
I like the idea of lowering the adjustment rings rather than raising them, I think you'll have better luck. You can lower the bottom ring the amount you want, then do the top ring. Still do them separately as they are acting as a "double nut". I wouldn't be surprised if you end up liking the 2.5" lift up front and leave it - what did you go with for coils in the rear?
Old 05-13-2021, 05:27 PM #119
Real Name: Michael
Real Name: Michael
Rears are 505’s which are 1.5” but it seems the consensus is an actual 2” in reality. We'll see. I was hoping to reduce the factory rake by at least 1/2” to 3/4”, but it will be hard to reduce it by 1/2” I guess.
How is your ride quality after putting so much preload on it? Still good? I went with the IMS because they are progressively tuned, which should provide a compliant ride. They are also large enough to stay cool for my usage.
Old 05-13-2021, 10:10 PM #120
I think with the 505s you'll be very happy raising the front more - my buddy has 302/505 combo and it looked perfect for rake.
I've noticed ZERO change in ride with the preload - I had about 25K on the shocks / coils before adjusting (I drive a lot). I've taken it wheeling since raising the front, also no disenable difference. For the rears, I've got the C725s (C325 with built in offset for KDSS) which were supposed to be approximately 2" in the rear - they are holding around 2.5", which is why I ended up wanting to bump the front up more.
Once I get my roof rack and RTT things might change again, but I'll assess at that time! My hub to fender measurements are 23.0" F / 24.3" R.
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-pxl_20210424_012037861-mp-jpg
dobinsons , ims , piston , shocks , struts
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 4th Gen Crikeymike 4th Gen T4Rs 30 10-31-2023 03:42 PM
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen Crikeymike 5th gen T4Rs 137 10-23-2023 04:01 PM
Dobinsons Long travel front struts and rear shocks Crikeymike 5th gen T4Rs 48 06-15-2017 03:01 PM
FS: Bilstein 5100 Series Ride Height Adjustable Front Shocks, 5th gen, $80 SLC, UT T4Rdvm For Sale: Suspension/Wheels/Tires 1 08-10-2015 11:57 PM
Bilstein Height Adjustable Shocks 0-2.5 inches 06sr5 Engines / Suspension / Wheels / Tires / Audio / Accessories 30 12-21-2011 05:54 PM
