Old 06-05-2021, 06:35 PM #136
str8flexed's Avatar
str8flexed str8flexed is offline
str8flexed is on a distinguished road
str8flexed's Avatar
Originally Posted by Crikeymike View Post
Yeah, the IMS ride a good bit different than the twin tubes, and if you add the longer ones (Dobinsons IMS59-50574 Monotube IFP Long Travel Front Struts) with those coils, you'll have as much down travel as you can get plus the added 1" of lift height you want to get out of it.
I have KDSS which I believe limits down travel so would you still recommend the "long travel shocks?" I am looking to have a 2.5-3" of front lift. I don't have "extended" anything else and have the coils "C59-352 - 200-240LBS heavy load front weight, 2.25-2.5" lift. 385/385mm, 18mm wire, 730LB"
I guess the question is, will the long travel shocks be smashed at full compression, or will the non long-travel shocks limit my extension at 2.5" of lift? Keeping in mind I have KDSS.
The two shocks in question:
IMS59-50700 - IMS Front Struts - suits 0-3" lift
IMS59-50574 - IMS Front Long Travel Struts - suits 2-3.5" lift
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
str8flexed is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 10:03 AM #137
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
There's no problem running what I recommended to you. It's the rear that can't run the long travel shocks.
You're looking for 2.5-3" lift, which is why you should use the IMS59-50574
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 10:33 PM #138
4Energy 4Energy is offline
4Energy is on a distinguished road
Mike, looking for a shop here in FL that you'd recommend to do the installation. Want to sort that out before I buy. I'm in Fort Lauderdale, but don't mind traveling for a trustworthy shop. I've done some light research and haven't found much. I moved out here from Socal and use to have everything done at Aiden James Customs.
Looking forward to getting some IMS goodies. Want to get the most lift possible without compromising down travel and correct the KDSS lean. Have a full steel CBI front bumper, sliders, Gobi rack, and usually have a lot of gear in the back.
Appreciate the time. Thanks.
4Energy is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 11:15 AM #139
Crikeymike's Avatar
Crikeymike's Avatar
Hey man,
I've never done anything with them, but someone else recommended these guys
Terry's Toppers | Vehicle Accessory Center
and ask for Tony.
There's also Lux Tires down in Doral/Miami that has done a whole bunch of installs, they did mine a few years back.
For what you're trying to do, 3" lift up front with the C59-352 coils and IMS59-50574 struts, UCA's and diff drop, then C59-327 and IMS59-50701 with PS59-4025 spacer in the rear.
That can all be put together here: Dobinsons IMS Suspension Kit Toyota 4Runner 2010-21 | Exit Offroad
The front and rear coils are due in early July
Old 06-09-2021, 08:08 AM #140
Thanks for the detailed breakdown! I'm sending you a PM now.
Hey man,
and ask for Tony.
Old 06-10-2021, 09:35 PM #141
Hey man,
and ask for Tony.
Mike - thanks again for your help here. Sorry about so many questions. I'm taking your recommendations for the shocks but still have some questions regarding the coils.
I'm still undecided on whether the 352 or the 354 coils up front would be best. I don't want to have too much lift so that it affects the IMS shock performance/CV wear as I've heard other getting more lift then expected, but I still want a substantial lift to clear 315/70/17s (already have the other mods required done). Keep in mind that I do have a 200+ pound front bumper and I'm planning on installing the Treaky KDSS brackets front and rear.
Additionally, what rear coil would come as close as possible to the Icon 3" Overland coil? Had some friends say its a great coil for heavier loads. Are there any rear coils that offer 3" lift that also work with KDSS?
Thanks you.
Old 06-11-2021, 11:03 AM #142
Crikeymike's Avatar
Crikeymike's Avatar
Thanks you.
Use the 354's up front then.
The 677V is a little stronger than the Icon Overlanders. With the Treaty Oak spacers installed, you'll be ok with those springs in and the IMS59-50701 shocks. It's the lean produced without spacers installed when lifting 2.5" or more in the back, which is why those springs say "not for KDSS everywhere" so that people don't crap their pants when they have a 1"+ lean.
Old 06-18-2021, 09:56 AM #143
Order placed, thanks for the help Mike! I opted for local pick up in Doral since I'm pretty close by in Fort Lauderdale. I'm going to be checking my email for updates every 5 minutes now, lol!
Old 07-01-2021, 11:27 PM #144
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
I wanted to come here and provide some feedback on my lift. This may be long (first time I’ve ever said that…) so I’ll break it up by topic.
Exit Offroad/Mike - Mike at Exit Offroad was awesome to work with. Extremely quick to respond. I even changed the rear shock I wanted after placing the order and he got with the warehouse and within hours my order had been changed. (The warehouse ended up not sending out the right ones but Mike hurried out the correct ones and I had them in two days. He was quick to make it right.) Definitely recommend Exit Offroad!!
What I Got - I ordered an IMS lift for front and rear. 302 front springs (2.5” nominal lift stock), 505 rear springs (1.5” nominal lift stock), 50700 IMS front shocks and 50705 IMS rear comfort tuned shocks. Also got the front and rear passenger side shims to address KDSS lean. I wanted a softer riding suspension than what is typically found in a digressive tuned shock (these are progressive tuned) and something high quality that would last.
Install - Not going too detailed with this since there are tons of other write-ups. But these are some things I learned that I don’t recall seeing in other instructions. I bought new strut top plates so I could pre-assemble my coilovers using my spring compressor. These springs are stiff but mine aren’t HD so my compressors worked but may not work for everyone. (Be careful with compressors!!) Drivers side front went in super easy with no KDSS disconnect. Passengers side front was a pain and I disconnected sway bar from LCA and from the fixed link. With a jack and leverage went back together pretty easily. I set the fronts a little high so I could easily clean the threads and lower the seats as needed to dial things in.
Rear was pretty easy as well. Was able to leave both sides of the sway bar connected since I used spring compressors to remove and install springs. (Thanks @Jetboy ) I installed the spacers/shims front and rear on passenger side to address potential lean.
I’m pretty mechanical and I had help so it took about 5 hours total and that was not being in a hurry and enjoying some cold beverages. Looking back, it was easier than I was expecting. YMMV. Also, get some flex head ratcheting wrenches. Makes life so much easier!!
Results - I over analyzed what to get because I didn’t want to screw around with this multiple times! My Numbers are below, hub to fender.
Pre Lift
Front
19.25 19.00
Rear
21.75. 21.75
As you can see. Fair amount of sag up front exaggerating rake and a little lean up front and no lean in the back.
After Lift (After a couple of days and 200 miles)
Front
22.75” 22.75”
Rear
24.25 24.75”
I knew it hadn’t finished truly settling but it was clear to me the rear didn’t need the spacer. I had read the lift could exaggerate any lean so that’s why I installed it in the beginning. So I removed it. And that eliminated the rear backwards KDSS lean. I was surprised the front was high on the passenger side but would correct by lowering seat rather than removing the shim. My camber was way off and since I had gotten an extra 1/2” of lift in the back than I was expecting with the 505’s, I was going to have to leave the front a bit higher. So I decided to get UCAs to ensure the correct ride and good alignment since I would be pushing or over 2.5” lift in the front.
Went with Freedom Offroad on that per @Sundy recommendation. After that install it drove and handled much better even before an alignment. But what was weird, the UCAs affected what I was measuring for lift. Strange but perhaps the extra camber created a measurement of more lift?
After UCA install and after the alignment and my current numbers are below.
Front
22.75” 22”
Rear
24” 24”
I’ll drive it for about a month and then if it all stays pretty much the same, then I’ll lower the front left a little and should be good!!
Performance
The initial imbalanced bouncing I experienced is completely gone. While the ride is firmer than I was hoping/expecting, it’s ride is predictable and stable. And on larger bumps and dips it handles it well. It’s almost smoother the faster I go over dips. There are some RR crossings that used to be quite rough, but it floats over them at speed. Wish it was softer over smaller road bumps… I haven’t gotten off road yet, but hope to soon.
Pics. I’ll try to load in order. Pre-lift, then after lift but before new tires, then after new tires.
Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-4b2fcf1e-42da-41cc-b89c-d537e7b58872-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-240ccd06-aee9-4468-b098-49f636c13951-jpg  Dobinsons IMS Struts and Shocks - Adjustable Height Monotubes - 5th Gen 4Runners-923c8892-24b3-4e5d-a6b3-757c623f797f-jpg
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 03:01 PM #145
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
Originally Posted by BlueRidge77 View Post
Rear was pretty easy as well. Was able to leave both sides of the sway bar connected since I used spring compressors to remove and install springs. I installed the spacers/shims front and rear on passenger side to address potential lean.
Front
22.75” 22”
Rear
24” 24”
Maybe I read this wrong. You installed a shim on the front passenger side and it's 3/4" lower than the driver side? Have you considered the Treaty Oak KDSS front and rear spacer kit? That may help solve the front lean without using different preload settings, and it should also help you to get full extension on the rear passenger side by avoiding interference with the panhard rod. That's what I did on mine. No lean in the front and it's at +3.75".
Glad to see your rears went on at only 1/2" high with no lean. I could live with that all day long.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 04:24 PM #146
Real Name: Michael
Real Name: Michael
You read that right. 3/4” higher on front left even with the 1/4” spacer on the passenger side. But the left is actually at the correct height for the spring and the seat height I used. (216 seat height instead of 213 so it should be 2.75” over baseline. Passenger side is actually low…)Perhaps the Treaty Oak spacers would be a good idea to finish correcting all the geometry. May lengthen the life of my swaybar bushings as well… How does it impact the skid plate? I still have my stock skid plate….
Old 07-02-2021, 04:33 PM #147
Tuco S.'s Avatar
Tuco S.'s Avatar
I've read the stock skid plate may require some cutting if you use the front KDSS spacer, but I honestly don't know. I have a KDSS compatible front skid from C4 Fab which has no interference.
If you got a diff drop kit with your lift, the small spacers are intended to be used to lower the stock skid plate to avoid interference. If not, let me know and I could probably send you the ones that came with my kit since I didn't need them.
Old 07-02-2021, 04:45 PM #148
Real Name: Michael
Real Name: Michael
I had originally ordered the diff drop kit, but it was on back order so I canceled it and decided not gmto get it after all. For my height, I’m skeptical of the benefits… If you don’t mind shipping, I’ll be happy to cover the cost for the spacers. Thanks! PM me.
Old 07-02-2021, 05:25 PM #149
Evo03 Evo03 is offline
Evo03 is on a distinguished road
I'm looking at this lift for when I get my new 4Runner. What size are your Falken Wildpeaks?
Evo03 is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 05:53 PM #150
Real Name: Michael
Real Name: Michael
In the first two pics, you see the Falken Wildleaks which were SL 265/70-17 (stock size) and had 60k miles on them so they were wore out. My new tires in the 3rd pic are SL 285/70-17 Toyo Open Country AT3.
dobinsons , ims , piston , shocks , struts
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 4th Gen Crikeymike 4th Gen T4Rs 30 10-31-2023 03:42 PM
Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen Crikeymike 5th gen T4Rs 137 10-23-2023 04:01 PM
Dobinsons Long travel front struts and rear shocks Crikeymike 5th gen T4Rs 48 06-15-2017 03:01 PM
FS: Bilstein 5100 Series Ride Height Adjustable Front Shocks, 5th gen, $80 SLC, UT T4Rdvm For Sale: Suspension/Wheels/Tires 1 08-10-2015 11:57 PM
Bilstein Height Adjustable Shocks 0-2.5 inches 06sr5 Engines / Suspension / Wheels / Tires / Audio / Accessories 30 12-21-2011 05:54 PM
