02-06-2020, 12:36 AM
KDSS question
This is probably discussed somewhere but here goes....
I know KDSS is supposed to decrease body roll on road. But is it possible for KDSS to actually increase body roll at low speeds?
I have a 19 TRD ORP with KDSS. I liked it when I test drove it (mostly on the interstate) - it seemed firmer and more controlled than the non-KDSS 4runners I have driven. But now that I own the car I’m experiencing it under different conditions. I’ve got a couple places in my work commute where I have to take a left turn at very low speeds, one of them coming off a bit of a hill. On both turns I notice very excessive body roll. I know various sensors, including speed sensors, are involved in engaging KDSS. Is it possible the system is just giving extra articulation in those instances since I’m going slow? The body roll is far greater than other trucks and SUVs I’ve driven on this same route. Since I’m new to KDSS I wanted to see if anyone else had similar experiences making low speed on-road turns. Is it something I need to get used or something I should check into?
I’m on the stock Bridgestone tires, which I realize are pretty squishy. But I do have them at 35 psi. I look forward to replacing these tires with better ones eventually...
Thanks.
02-06-2020, 01:11 AM
I guess I'm not fully understanding your question...
Usually a "turn at very low speeds" and "very excessive body roll" would be mutually exclusive. I have the exact same setup as you (2019 ORP w/KDSS) and haven't experienced any abnormal body roll on the street.
"Sometimes I sit and think. Sometimes I just sit."
02-06-2020, 02:13 AM
KDSS is automatically engaged at any speed above 12 mph. Seems like you'd have to really work at it to take a corner sharply enough to induce body roll at a speed of less than 12 mph.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
02-06-2020, 09:41 AM
I don't think you're quite understanding how the system works. Check out this video:
YouTube
02-06-2020, 11:39 AM
Yes. KDSS rigs will have more body roll at low speeds relative to non-KDSS, but the rig will be going less than 12mph, so I don't see how it would be excessive unless maybe you are really top heavy or cranking a very tight turn at a weird angle.
2018 TRD Off Road Premium - Barcelona Red
02-06-2020, 11:45 AM
Real Name: Derrick
Real Name: Derrick
What you're experiencing is what 4Runners without sway bars feel like. At very low speeds, KDSS is disengaged (very similar to not having sway bars), so you basically have a very tall vehicle making a turn without say bars. The KDSS isn't making your truck sway more, it just isn't doing anything to help it sway less. Make sense? So you have nothing to worry about, it is "normal" for our 4Runners that are equipped with KDSS and since you have to be going very slowly for this to happen, it should never be an issue.
2015 Toyota 4Runner Trail Edition
Havik's Build Thread
02-06-2020, 06:20 PM
"is it possible for KDSS to actually increase body roll at low speeds?"
Yes. Not possible, but actually engineered that way. You basically have have no sway bars below 12 mph.
02-06-2020, 06:43 PM
Real Name: Derrick
Real Name: Derrick
Umm... no. It is not engineered to increase body roll. It is engineered to allow more flex in the suspension so it is not increasing body roll, it is just allowing for it. But again, that does not mean it is engineered to increase body roll, it doesn't do anything to actively increase body roll.
02-08-2020, 12:27 PM
What makes you say that? All KDSS does is allow more wheel articulation in situations where the wheels are at different levels, which essentially means when opposite corners are at different heights. It does this by using the hydraulics to allow the sway bar to drop a few inches. The sway bars are always working when on a flat surface.
02-08-2020, 01:40 PM
Here is how I interpret it.
The difference in a KDSS sway bar and a regular sway bar is that one end link / swing arm is replaced with a piston, on opposite sides front and rear. The hydraulics that drive the pistons is not pumped, but pushed from the piston that is being forced in at the opposite corner, through a balancing valve (accumulator) with electronics, to the piston that is extending.
The sway bar does not disconnect, it just has further travel and dampening, and one endlink /swing arm is still present on each.
Also, where is the engagement speed reference coming from? I have never seen that written, but i really havent looked either. My understanding of the system is that it engages when a wheel drops and force changes allowing the fluid to push to the extended cylinder. When you are driving on normal flat roads, the drops don't occur and pressures / forces are mostly equal.
When i replaced my shocks, I had to unbolt the sway bars and raise and lower the pistons. It's really a pretty simple system aside from the electronics in the accumulator / valve.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
02-08-2020, 06:44 PM
The KDSS computer also looks at steering angle and lateral acceleration, not just speed, so no the KDSS isn't increasing body roll
02-19-2020, 01:57 PM
Lots of bad info in this thread
This is as simple as I can make it: The KDSS sway bar has two hydraulic pistons (one front and one back) attached to the frame rail. These pistons become the 4th connecting point when charged/firm. When traveling at lower speeds/off road, the pistons un-charge/loosen, basically turning the sway bar into an unconnected flopping bar. This lets the suspension fully-travel (droop/compress) without causing opposite-side force via sway-bar.
So, yes, when traveling at lower speeds, the pistons effectively stop the sway bars from doing their anti-sway job. At speeds below ~12 mph, this will make the driver perceive MORE body roll. It is engineered this way. This is why the model is called the "Trail or TRD OffRoad" model. Toyota assumes you want more articulation when you travel off road at low speeds.
Understanding Sway Bar Technology - Tire Review Magazine
Anti-roll bar - Wikipedia
02-19-2020, 02:36 PM
Real Name: Derrick
Real Name: Derrick
Then goes ahead and basically repeats what people have posted in the thread. You are basically restating what I and others have said. No idea why some people insist they are experts and others aren't. You've adding nothing that wasn't already said here, why do you have a need to act like your information is so much more valid than others?
02-19-2020, 03:01 PM
Reading this thread and I don't own a KDSS 4runner... Grabbing my coffee and cookies for this one.
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
02-19-2020, 03:04 PM
[meme] someone is wrong on the internet [/meme]
