Old 02-06-2020, 10:04 AM #1
Snackie Snackie is offline
Snackie is on a distinguished road
Jack-Lift height
Hello....
I'm looking to start rotating my own tires on a regular basis. I've got a fully stocked garage but the lift/Jack that I have is a bit lacking so I'm looking to upgrade. What type of a jack would be my best bet if I'm looking to jack up the entire one side of my car. (I have plenty of jack stands).
My truck has Bilstiens set at 1.75. Besides that, it sits on 265's. At some point moving up to 285.
If there isn't a jack that will dead lift the entire side. What's my safest way to accomplish this for rotation.
Realize this may be an easy question....just trying to not get killed.
Thanks.....
Snackie is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 10:11 AM #2
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
Just get a good quality floor jack and jacks stands and get all four corners up on jack stands.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 10:16 AM #3
choochoo choochoo is offline
choochoo will become famous soon enough choochoo will become famous soon enough
I've got 6112/5160 combo with a ~2.5" up front and ~2" on rear on 265's. What worked for me is a Harbor Freight Daytona Long Reach Jack.
I'm able to lift an entire side of the vehicle at the frame using this jack, and I think there may be a little room to spare once you switch to 285's.
choochoo is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 10:29 AM #4
gainman gainman is offline
gainman will become famous soon enough
I know harbor freight is shit for the most part, but one great item they have is the Daytona floor jack.
Get the orange one that is low profile and lifts to 25" height. It's a 3ton
Sent from my SM-N975U1 using Tapatalk
gainman is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 10:43 AM #5
The exact info I need guys.....that you.
Old 02-06-2020, 11:03 AM #6
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I do the tire rotations every November 7K miles and the oil change /grease drive shafts .. rust fixing ....
what I use is a small bottle jack 12 tons cap.. I jack up the lower control arm front. vehicle lifts up only 1.5 inches that's it..
then I use a low floor jack 3K LBS.. jack up the rear diff pumpkin.lift is about 2 inches .. vehicle is level on the lift .. no need for jack stands ..
you will like this setup very stable .. I do the X rotations of the tires. reason is the tires wear more on the pass side than the driver side .. roads in my area have sand on the shoulders..
then I use solid wood ramps to drive up on them 5 inches .. very easy to drop all the pans on oil changes .. I inspect all fluids and any rust / leaks etc..
after the oil change I keep the pans off a couple of days to check for any leaks .. never brought the vehicle to dealership no problems 2016 runner.
catrains is offline   Reply With QuoteReply With Quote
entire , jack , moving , point , side
Floor Jack Lift Height therealrayy 5th gen T4Rs 14 10-21-2018 10:58 AM
FS: Brand New Hi-Lift Jack XT485 48" Hi-Lift X-TREME Jack ($90) Philadelphia PA Alex T4R For Sale: T4R Items 6 01-20-2018 03:23 AM
what height jack stands for 3" lift ShooterMcGavin 3rd gen T4Rs 18 06-10-2015 04:40 PM
Minimum jack height? Dementedfish 3rd gen T4Rs 4 07-29-2014 01:23 AM
FS Hi-Lift Jack 4X400 4XRAC Jack Mounting System - $25 (SC) superman3043 For Sale: Non-T4R Items 0 05-16-2014 03:07 PM
